I found that document online also. I was hoping that there was one for the 2010 series as those are the ones people are having issues with. As boozcruz has said many people are reporting they don't work with the 638/C10 series and I've also heard issues with the 738/838 series. Unfortunately I can't try to create a hex code since I don't have the actual remote. I'm going to ask in the 738/838 forum and see if people can use the above method for direct access control of those TVs. It is starting to sound like Mitsubishi crippled discrete codes for all of their 2010 DLP TVs.
It doesn't make any sense why they would do it. I could kind of understand them taking it out of the lower end lines to try and entice people to buy the higher end models but you would think they would advertise the point rather than leaving owners SOL.
