I was wondering if you can tell the difference when watching half SBS vs full 3d? Anyone with experience watching half sbs and a full 3d bluray on ps3 or something similar?
AVS › AVS Forum › 3D Central › 3D Tech Talk › half SBS vs full - I know it's less but can you tell the difference?
Featured Stories
AVS Top Picks
post #2 of 74
11/19/10 at 6:17am
post #3 of 74
11/19/10 at 8:24am
- Frank
- Trader Feedback: 0
- 3D experimenter
- offline
- 5,178 Posts. Joined 4/1999
- Select All Posts By This User
post #4 of 74
11/19/10 at 9:38am
There is no difference if both files have the same size.
Also the only real full HD 3D is generated by Games using nVidia's GPU.
The 3D-Blu-Ray's 2D + Delta format is just a gimmick.
Frame compatible Side By Side will deliver the same quality or even better if compression ratios are the same or the file size are the same.
Mathew Orman
http://www.*******************.com/
post #5 of 74
11/19/10 at 12:40pm
- walford
- offline
- 16,779 Posts. Joined 5/2003
post #6 of 74
11/19/10 at 12:52pm
What kind of English is that?
Mathew Orman
post #7 of 74
11/19/10 at 1:41pm
- Lee Stewart
- 3D Enthusiast
- offline
- 19,369 Posts. Joined 2/2007
Mathew Orman
Mathew Orman
Please explain that statement.
post #8 of 74
11/19/10 at 6:01pm
- BlackShark
- offline
- 549 Posts. Joined 6/2010
Mathew Orman
Mathew Orman
I disagree with EVERY sentence you wrote here.
I have 3 BluRay3D movies, they're all stereo FullHD (or the cinemascope equivalent) I also have an ATI GPU and I play my games in FullHD 3D on my dual projectors
MPEG4 MVC's 2D+Delta is the real deal and is the most efficient stereo video compresison format to date, if you have a good encoder you will get better quality for the file size than anything else for stereo video.
There is a difference between full and half res side by side, and yes of course it is visible, but the obviousness depends on the quality of the down and upscaling performed as well as the video compression format.
Compression ratios can be used to compare image quality between a source and it's compressed file, but not between compressed files of different sources.
Different sources compressed with the same compression ratios will also have different quality thus cannot be used directly to compare
If both full res and half res files have the same file size, they have different picture quality
With modern encoders, the picture quality and compression ratios are not proportional, so unless you are using extremely low bitrates if the two files have the same file size, the full res picture will look better visually than the half res picture.
post #9 of 74
11/19/10 at 6:38pm
- walford
- offline
US Engish by senior citizens not the Kings English as used in England.
But my poor keyboard senior citizen US english is no excuse for your totally ignoring the question I asked.
I have edited by post in hopes that you can understand it better.
post #10 of 74
11/20/10 at 3:37am
My apologies.
Can you break down the question to less complex one.
I have a hard time to provide an answer to such question.
Mathew Orman
post #11 of 74
11/20/10 at 3:50am
It is just your opinion based on what you have to play with.
The real truth comes out when one actually does a practical prove of concept using a raw stereoscopic footage as an input.
Mathew Orman
post #12 of 74
11/20/10 at 4:55am
- walford
- offline
Please explin why 3D games played using Nvidia 3D vision are true 3D and movies filmed with IMAX 3D cameras and show at an IMAX 3D theater maybe but if they are enocoded using (2D+Delta) format on a blu-Ray disk they are not?
post #13 of 74
11/20/10 at 5:01am
- walford
- offline
Please explain why 3D games played using Nvidia 3D vision are "true 3D" and movies filmed with IMAX 3D cameras and shown at an IMAX 3D theater maybe but if they are "true 3D and then enocded using MVC(2D+Delta) format on a blu-Ray disk they are not any more?
post #14 of 74
11/20/10 at 5:59am
Simply, nVidia outputs 1920 x 1080 x 32bit color, 60 Hz
without any compression in-between the card and monitor.
Encoded movies have reduced resolution due to lossy compression, motion blurring and camera focus blurring.
Additionally 3D movies encoded using MVC 2D + Delta method have reduced texture specularities and reduced or totally removed low contrast details.
Mathew Orman
post #15 of 74
11/20/10 at 12:05pm
- BlackShark
- offline
LoL icester,
Video games are not perfect sources, they have lots of shader approximations all over, blurry textures, reduced resolution (shadows and reflections), insufficient geometry details (obvious in close ups), insufficient rendering resolution (visible aliasing even with the best anti-aliasing modes enabled) in order to run the games in real time and most recent games even include motion blur and depth of field effects.
If the picture quality of 3D BluRays with MPEG4 MVC is insufficient for you then may I dare ask your opinion on 2D movies ?
2D BluRay (Mpeg4 AVC) ?
Digital cinema (jpeg2000) ?
Film ?
Film ?
post #16 of 74
11/20/10 at 1:05pm
by 2014 every graphically, or just computationally intensive task will be run "on cloud" , this means limitless, supercomputer perfomance. Real time ray tracing will be commonplace very soon, streaming thru web browsers.
The console driven "prevgenHD" era is about to end. Now lets hope for MEMS displays.
post #17 of 74
11/20/10 at 3:44pm
- walford
- offline
Mathew Orman
Mathew Orman
Do you consider programs "filmed" with 3D IMAX cameras and shown at 3D IMAX theaters as "true 3D" or as just a "gimmick"?
Doesn't your statement that "MVC 2D + Delta method have reduced texture specularities and reduced or totally removed low contrast details" depend on the quality of the MVC encoder or is true of all MVC encoders as you imply?
post #18 of 74
11/20/10 at 4:39pm
Since it's inception in 1971 IMAX totally relied on gimmick
that is an adrenaline WOW effect on viewers due to gigantism of scenes and actors in every movie.
It goes for both in 2D and 3D movies. Additionally IMAX productions of 3D movies are no different than competition and it also uses parallax limit driven stereoscopic content distortion techniques which yield totally unrealistic immersion.
Again MVC 2D + Delta technique was originally created in Germany's Fraunhofer Institute.
http://www.hhi.fraunhofer.de/en/depa...sing/overview/
The intention was to create efficient 3D Television signal compression method. It was established that in order to satisfy limited bandwidth compromises such as stereoscopic detail reduction had to be implemented.
The creators also acknowledge that the methods creates 3D artifacts that are not present in original content.
For those who would like to test the MVC codec and it's 3D implementation, here is the source code:
http://iphome.hhi.de/suehring/tml/download/
Mathew Orman
post #19 of 74
11/20/10 at 4:58pm
LoL icester,
Film ?
LoL icester,
Film ?
That is nothing to do with Nvidia's GPU performance and it is only dependent on Game design.
4k textures can be used in rendering of FULL 3D HD format
without any compression between the card and display monitor.
Blue Ray has no magic capabilities and it is not capable of streaming real full HD content in 2D and much less in 3D.
Mathew Orman
post #20 of 74
11/20/10 at 5:03pm
You are very optimistic.
Mathew Orman
post #21 of 74
11/20/10 at 5:15pm
- BlackShark
- offline
The details loss and artefacts you mention sound exactly like the same compromises that all lossy compressed video formats have and which are not avoidable unless you use raw-source/lossless formats (which are not an option for movie retail and broadcast).
Using the JM encoder to decide on the quality of the format would be one of the worst mistakes to do, the JM AVC reference encoder is known to be old, inefficient and painfully slow, It does not show how good the format can really be (relative to the leading encoders) and I bet the JM MVC one has exactly the same problem, i'll wait for x264 to implement MVC to do the tests with my own content, although I already know what to expect.
From all the comments from specialists I've read, MVC encoding allows theoretically lower bandwidth for the same video quality than dual AVC encoding, or using the same usual logic from all mpeg4 encoders : better quality for the same file size, and considering the 2D + Delta approach it makes perfect sense.
And the video quality of the BluRay3D discs I have in my hands is just impeccable, I have no complaints to make.
post #22 of 74
11/20/10 at 5:22pm
- Lee Stewart
- 3D Enthusiast
- offline
Matt - ALL movies are a gimmick in one form or another.Quote:
Mathew Orman
Mathew Orman
Matt:
From your link I see this link:
http://www.hhi.fraunhofer.de/en/depa...cast-with-mvc/
And it says nothing about Blu-ray disc. Just broadcast which would mean CBL/OTA/DBS. Substantial difference in the max data rates between those delivery systems and BD.
post #23 of 74
11/21/10 at 3:04am
Matt:
Matt - ALL movies are a gimmick in one form or another.Matt:
Panasonic have adopted MVC 2D + Delta in Blu Ray 3D adding navigation GUIs and exec code capabilities.
Mathew Orman
post #24 of 74
11/21/10 at 3:15am
Te topic is not about dual AVC but SbS anamorphic vs MVC's 2D + Delta.
Both using the same core compression.
If 2D + Delta File Size = SbS anamorphic File Size then the only difference is nonuniform detail definition in SbS anamorphic and 3D artifacts and reduced low contrast detail in MVC's 2D + delta.
Mathew Orman
post #25 of 74
11/21/10 at 3:23am
JM MVC is a reference based on free C++ library
and if you want to implement it for real time then you must select the target platform and it's optimal minimum processor power. Most of MVC implementations use assembler and processor based RISC features that are stream compression related.
Mathew Orman
post #26 of 74
11/21/10 at 3:36am
- BlackShark
- offline
And by what kind of miracle would the anamorphic SBS file not be affected by stereo 3D artifacts and reduced lower contrast detail ?
There is still a left and right eye view to encode , there are still 2D artifacts in side by side and if they are different between the views you get stereo 3D artifacts. Also the details are smaller with anamorphic SBS, why would the encoder spare them in the anamorphic SBS and not in 2D+delta.
post #27 of 74
11/21/10 at 3:59am
Because SbS anamorphic is compressed as is, without additional image processing.
2D + Delta requires initial image processing in order to reduce low contrast details. If such is not applied the delta would always be as big as 2D and overall no different in size than original Left + Right.
Additionally when decompressing 2D + Delta the newly formed right image has 3D artifacts in form of 3D surface smooving or flattening.
The only step applied in SbS after decompression is horizontal rescaling using interpolation which makes the nonuniform distribution of detail.
As Fraunhofer pointed out one of the main advantages of 2D + Delta was 2D compatibility. Which in 3D Blu Ray simply means that the Delta is ignored when in 2D Blu Ray playback mode.
Mathew Orman
post #28 of 74
11/21/10 at 4:37am
- BlackShark
- offline
Most of the anamorphic SBS encoding I've performed show exactly the 3D artifacts you are describing. Anamorphic SBS is not immune to it at all, the amount and visibility of these artifacts depend on the bitrate.
The initial processing in order to reduce low contrast detail is part of any lossy video compression scheme, including 2D AVC which you are probably using for Anamorphic SBS.
Saying 2D+delta would be as big as 2D left+right is incorrect. Even if taking uncompressed pictures, the similarities between the left and right eye views mean that on most of the picture, the delta requires less bits to define pixel colour, you can achieve lossless 24bit precision with less than 24 bits of data on average across the pixels of the delta picture. It is one of the advantages of encoding similar pictures through a delta.
Add to that all the motion compensation mechanisms of AVC ported into MVC and the lossy compression (the details reduction which AVC and all others MPEG encoders already use in 2D encodings) which allows the video producer to control the size of the encoded file through the bitrate and you get the significant bitrate reduction requirements claimed by the MVC format.
I maintain that at similar bitrates the less efficient 2D AVC encoding and scaling artifacts present in anamorphic SBS makes the picture look less good than native resolution MVC.
post #29 of 74
11/21/10 at 7:09am
I have not said anything about compression related artifacts which are common to both layouts and only pointed out the differences due to an extra image processing.
If you do not believe that on every raw pair of stereoscopic images the Delta is as big as left or right then do the subtraction in Photoshop and see the difference.
The black areas would be the common pixels that are identical in left and right image.
Mathew Orman
post #30 of 74
11/21/10 at 9:41am
- walford
- offline
I understand Matt to be saying that all currently available film based 3D is of poor quality and he refers to this poor qualiy as " a Gimmick".
IMHO the currently used methods to record and play 3D content will continue to exist until some other methods can be developed and be avaiable at prices that are compeitive to "the Gimmick" methods we have today.
Back to Forum: 3D Tech Talk
- half SBS vs full - I know it's less but can you tell the difference?
AVS Top Picks
Currently, there are 1802 Active Users
(437 Members and 1365 Guests)
Recent Discussions
- › 'Mad Men' on AMC HD 15 seconds ago
- › Official OPPO BDP-105 Owner's Thread 28 seconds ago
- › Hawaii Home Theater Construction 42 seconds ago
- › Gorilla's 130" 16:9 AT screen (and false wall) build - XD fabric,... 1 minute ago
- › Official 2013 Sony R550A series TVs (KDL-xxR550A) --- 50", 60", and... 1 minute ago
- › Official Sharp AQUOS LC-80LE844U Owners thread 1 minute ago
- › Nashville, TN - Comcast 2 minutes ago
- › Sunflower State Cinema 2 minutes ago
- › Official OPPO BDP-103 Owner's Thread 2 minutes ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 2 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
