AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › BENQ PE8700 DVI Problem with any device
post #1 of 6
hi all, i hope someone can help me..
I read a lot off Thread on this projector, but i can't find any solution on my issue ...
I'm using since 2 years now my pe8700 with PS3 in HDMI with DVI conector.
IT run nice..in 1080I/60h
since 3 days, DVI stop working . always message "Searching DVI-I"... (without doing anything)
however, I do off course several test with other device (LCD TV) and my PS3 Work Fine...
other input on my pe8700 works fine.. (V,SV...)
is it possible that i must reset something or need to reload a firmware ?
It seams like there is a problem to initialise this DVI interface, because if i plug a dvi cable from a running pc, it's ok i've got a picture on pe8700 but if i reboot the pc, display on projector never appear..
please help me .. I don't have any money to buy another one..
thx in advance..
post #2 of 6
Handshake rule is display on first then turn on the device. Test it with a different cable a shorter one if you have it. Make sure your PS3 isn't at 1080p the BenQ probably can't handle it, 720p would be best anyway.
post #3 of 6
hi, thx for this , but i already done this test and nothing..
I force 720 on ps3, and projector still in "searching dvi-i"..
post #4 of 6
I had a similar issue where the EDID info on the 8700 was corrupted. At the time I used a registered version of Powerstrip to update the EDID info.
I found an old post that explained the procedure.
BENQ 8700+ EDID Issue
post #5 of 6
thx, i will try this option.. but.. I can't find "update EDID" in Powerstrip tools, maybe it's because i'm using a trial version ? I had purchase a registratiton code but not receive yet ..
if I understand, this tools can overwrite EDID on Benq Projector via DVI interface ? it's correct ? writing directly on projector ?
thx for your help
post #6 of 6
it's ok now ! I read all thead & I found the topics on DVI_Recover_CDIMAGE.iso, download it, and after put it on a cd, restart my computer .. and everything was solved.. DVI-I start on my PE8700 and HD is on.. (1080i/60)
It's a real pleasure to see that there is always someone can help you all over the world..
thx for all..
like we say in french " Trop de la Balle" !
