There are a lot of different aspects and scenarios that affects the displays 3D performance
and there are not yet any public standards or test discs to 3D performance testing.
This testvideo tests only one extreme situation that is problematic even with plasma TVs.
If you get bad score from this test it doesn't mean that the 3D is totally broken/unwatchable.
Just want to see how well different displays behave in this extreme condition.
Lets gather performance results from our TVs
Download this side-by-side L-R 3D video:
http://www.box.net/shared/lpe35vy1h8
- Place it on USB stick, put the stick on TV and play it. Panasonic VT owners needs to play it from other external device (BD player) to be able to enable the 3D mode.
- Enable 3D and choose the side-by-side mode and open 3D glasses.
- In the middle of the video press pause.
- First close your right eye and write the smaller number which is visible on the top half screen and then write the smaller number which is visible on the bottom half screen
- Do the same procedure then with the left eye closed.
Frank created a .MPO 3D still picture version file of the image from the video which is attached to this forum post.
The side by side jpeg can be downloaded here:
http://3dfrank.com/testpattern.jpg
You can play .MPO 3D picture files with PS3 'Play Memories' program available free from PSN.
Panasonic plasmas can play this from memory stick.
Example how you can answer:
3D TV model: Samsung PN50C7705 50" Plasma
3D glasses model: Samsung original battery powered.
Left eye open/right closed -> top half screen smaller visible number -> 1
Left eye open/right closed -> bottom half screen smaller visible number -> 3
Right eye open/left closed -> top half screen smaller visible number -> 3
Right eye open/left closed -> bottom half screen smaller visible number -> 1
If you can't see the top/bottom half screen you must answer:
Left eye open/right closed -> top half screen smaller visible number -> 4
Left eye open/right closed -> bottom half screen smaller visible number -> NOTHING
Right eye open/left closed -> top half screen smaller visible number -> NOTHING
Right eye open/left closed -> bottom half screen smaller visible number -> 5
With this crosstalk test we can measure how good performs each set 3d tv/3d glasses with high contrast dark background scenes.
The best possible results for crosstalk are:
...Shamelessly copied this topic from other forum that lies in the dark corner of the internet to get more results.
testpattern.zip 135.6015625k . file
