Thanks for your reply bro.
Is it easy for me to make an ISO from all those files? Can you recommend any software that I can use to make an ISO from the extracted data I have?
I have quite a few that I bought retail just a couple of years that I'm amazed are going for ridiculous prices. Maybe there will be a day that some of these will be released again on blu-ray or from a hi-rez download site, but in the meantime, the limited supply is quite a windfall for some folks.
... I am really starting to feel disheartened even a bit upset to be honest about the Blu-ray 3D playback.
The following 3 setups are all OUT OF THE BOX with no picture adjustments First (MAIN) setup 55" LG Passive Cinema3D LED TV Oppo DBP-93 Second Setup 55" Full HD Series 8 Samsung LED Panasonic DMP-BDT110 3D Blu-ray Player Third Setup 50" Full HD 3D Panasonic Plasma Sony BDPS470 3D Blu Ray Player I first noticed this on Monsters VS Aliens Blu-ray ACTIVE 3D (For my third time viewing it but the FIRST time on the Oppo - Actually this was the first blu-ray movie I watched on the Oppo) I thought my eyes were playing tricks on me. When there was a sudden change in brightness/contrast I would notice on 1 certain point (In some cases a larger point or even the whole screen) Would artifact (Go a blurry Faded transparent black) It would be like a flicker in video, like I said usually on 1 point of the picture usually 10-20% of the full TV screen size but as I mentioned earlier in some scenes it would be A LOT larger and sometimes the WHOLE screen. I opened another copy of Monsters VS Aliens (I am a re-seller) Still the same issue. I tested several other titles. The worst being 1. Gnomeo & Juliet Blu-ray 3D All through this movie but considerably noticeable for the first 10 minutes then also the 5 minutes around the time the gnome gets his hat cut off, 2. Alpha and Omega Blu-ray 3D Multiple times throughout this movie considerably noticeable on the golf Scene, Open Season Blu-ray 3D it happens at some points throughout the movie. This is where it gets interesting. I plugged in my old 3D blu-ray player Panasonic 110 and I skipped to the main problem areas of each disc and I noticed it was still happening BUT BARELY! Because it was so minor I didn't even notice it on my other players until I knew what I was looking for but until now It never actually bothered me. The Oppo is the worst out of the 3 Players we have here for this problem I have even tried mixing up all of the setups. For example trying the Oppo with the Panasonic and Samsung TVs. Trying the other 3D Blu-ray Players on my LG TV with the exact same results. I am talking at least 50% more noticeable. |
Discussion about the Blu-ray 3D quality: Yes I am that guy! - I don't even use this for music, streaming, DLNA etc. I use the oppo for DVD and Blu-ray / 3D playback. Now before anybody says anything I will let you know what I have done.
I purchased this device as I love movies and I was told this is the best player I could get for under $1000 AND I think it is for DVD/Blu-ray but I am really starting to feel disheartened even a bit upset to be honest about the Blu-ray 3D playback. The following 3 setups are all OUT OF THE BOX with no picture adjustments First (MAIN) setup Latest Monster 1.4 HDMI cables (Have tried the Oppo Cable and 2 Other HDMI Cables all supporting 1.4 55" LG Passive Cinema3D LED TV Oppo DBP-93 Second Setup Latest Monster 1.4 HDMI cables (Have tried the Oppo Cable and 2 Other HDMI Cables all supporting 1.4 55" Full HD Series 8 Samsung LED Panasonic DMP-BDT110 3D Blu-ray Player Third Setup Latest Monster 1.4 HDMI cables (Have tried the Oppo Cable and 2 Other HDMI Cables all supporting 1.4 50" Full HD 3D Panasonic Plasma Sony BDPS470 3D Blu Ray Player /end rant |
I have a pretty difficult time extracting much of anything from this extensive post. But it sounds a bit like a description of an issue with 3D glasses, or just a display that is fairly poor at displaying 3D.
I've done a great deal of 3D watching on the Oppo and have never seen anything like this. There's not much in the way of cogent testing in your post, and perhaps you have made things too complicated. I'd suggest limiting yourself to the Panny plasma for testing, since it has the best reputation for 3D display. Then start by reviewing the settings in the plasma WHILE a 3D title is playing. Start by setting it to 60Hz and turn off all extra processing in the display. The 48 and 96Hz settings in the Panny are known to cause processing issues. Use only Panasonic glasses and be certain there are no obstructions to the IR pathway from the TV to glasses. |
Let's see if I've got this right. You have three different displays from three different manufacturers. You also have three different 3D players, again from three different manufactures. You are using high speed HDMI cables for all three setups.
There are several 3D movies you've watched that all exhibit an artifact that you first noticed using your OPPO BDP-93, but on later examination found that you were able to find the same problem with the other two players, only it's 50% more obvious with the OPPO. It's possible that no one else has reported the same problem with their OPPO players. After your post, maybe others will report something similar. It seems safe to say that what you're experiencing probably isn't a wide spread OPPO problem. Notice the qualifiers. ![]() Therefore, the first two things to examine might be your setup, and the possibility that your player is defective. Keep in mind that OPPO binds over backwards doing exchanges. I would present OPPO with relevant information and see what they have to say. I would also try to reduce the setup down to it's bare essentials, just in case your OPPO isn't defective. Maybe someone with 3D experience can spot a setup issue that needs changing. Edit: I don't think you mentioned the firmware version in your BDP_93. |
