AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-93 Owner's Thread
Official OPPO BDP-93 Owner's Thread - Page 403
post #12061 of 25179
Originally Posted by Bob Pariseau View Post
I suppose one thing you could try would be to remove the region free mod, re-install the Oppo firmware, and try a Region A 3D disc (with the player set to PAL output if that's what your display requires).
--Bob
PAL output isn't relevant to anything other than SD-DVD.
post #12062 of 25179
Originally Posted by BSTNFAN View Post
The imegstore "super kit" that can be added internally or externally is currently onsale at their direct website for the price of the regular kit. I believe the sale expires in a week or so.
the superkit is the one I bought
and for a little over $60. A whole lot less than $140-150 for the blueraychip kit
you can install it externally by using its usb & rs-232 connectors into the player. rather than use up the ext connectors, I installed it internally. It isn't hard
post #12063 of 25179
Only true for 3D as the resolution and framerate is still Source Direct or if you have 1080p selected with 24Hz output enabled.
Otherwise, the player will need to be put into PAL or NTSC based on the native frequency of the display, as the player will convert 24Hz to 50Hz or 60Hz.
post #12064 of 25179
Originally Posted by Neuromancer View Post
There is Merlin Audio Design (http://merlinaudiodesign.com.au/) who handles sales and support in Australia. However, as you did not purchase from them, they may charge you to have the player looked at (from as cheap as the shipping fees, to possibly parts and labor).
I can't recommend Merlin Audio highly enough. As far as I know they're the only official Australian Oppo distributor and Ken does an amazing job with customer support. He's a good guy, and even though you didn't buy from him if you give him a call he might have a 3D set and be able to test a disc or two for you.
I'm also in Australia (Sydney) but I don't have a 3D set (I'm one of those backward guys who doesn't want one). All I can say is that I've never had any issues with playback of 2D discs (with a Bluraychip.dk mod kit installed). Everything works as it's supposed to.
I'm guessing your problem is 3D-specific as opposed to electricity-specific, but if you want to check with only Australian users, try dtvforums.info, where you'll find a good number of Australian Oppo owners.
post #12065 of 25179
I've ordered a BDP 93 and anticipate sending HDMI-1 to my DVDO Edge, but I've read that HDMI-1 has its own great video processing. Is there likely to be any adverse interaction between HDMI-1 and the Edge, and are there any special settings I need to make when I set up the BDP 93 with the Edge?
The Edge switches between the disc player (now a PS3) and a DirecTV HD-DVR. Audio is split off by the Edge and sent from its audio-only HDMI to a Cary Cinema 11a, and I assume that will not change with the the BDP 93 in the setup.
PS: In an earlier post I claimed the PS3 sent only PCM, but the updated PS3 OS can now send bitstream. The Cary shows it's receiving DTS of Dolby.
db
post #12066 of 25179
db
I will tell you right now you are wasting your time sending the 93 to the Edge. You will not see ANY benefit versus direct from the oppo. This applies to blu-ray as well as dvd. You may be able to get close on dvd if you send the source direct from dvd to the Edge but I doubt you will think the Edge is beneficial for ANY source coming out of the Oppo. I have tried the Edge with the 83 as well as the 93 with four different projectors on a 120" screen. Of course this is my opinion only...
I also had issues with the audio output on the Edge with the 83 and 93. Sometimes it worked, sometimes it did not. Sometimes a reboot of the Edge cured it, sometimes not..Too much HDMI tomfoolery going on I guess.
Good Luck!
post #12067 of 25179
Just to followup on the noise issue with my bdp-93. Begin Rant: Bottom line: I have really sensitive hearing, and this player is not silent as many here seem to think. I now have two units in my home to evaluate, and they are essentially identical sounding. So I doubt I have two defective units. Basically, if one has a quiet room, you can just barely hear the whir of the disc and the high pitch noise of the laser reading the disc from 10ft away. Both units sound identical in this regard, so I can confirm that this is just as good as it gets with the transport oppo is using. Granted, I'm sure this is MUCH quieter than cheaper blu-ray players on the market (no fan too!). So I'm more than happy that the bdp-93 is as quiet as it is. I have an onix-cd-1 that is dead silent. You can't even hear the disc spinning with your ear 1ft away. I guess I was expecting a little too much for a $500 player. Nonetheless, it's still a very very quiet unit during playback. End Rant.
post #12068 of 25179
maybe a little sound deadening mat might kill the noise completely?
post #12069 of 25179
Or a closet.
post #12070 of 25179
Originally Posted by htwaits View Post
Or a closet.
I recommend developing partial deafness in one ear. It comes in much handier than I ever thought it would, particularly when my wife is talking to me:-)
post #12071 of 25179
My tinnitus is helping me along with that as well! I'm going to try placing some weight on top of the player to see if that dampens the sound a bit. Since it's the transport itself making most of the noise, and the fact that the noise is pretty high pitched, I don't think I can dampen it much further. It isn't really the chassis that's resonating or anything.
post #12072 of 25179
I've never heard of tinnitus and "really sensitive hearing" used together. Hopefully, you'll find a solution to the high pitch noise attributed to the 93. It seems maybe some room dampening materials may be needed in your room.
From Wikipedia: Tinnitus (play /tɪˈnaɪtəs/ or /ˈtɪnɪtəs/; from the Latin word tinnītus meaning "ringing") is the perception of sound within the human ear in the absence of corresponding external sound.
post #12073 of 25179
I have Tinnitus (self diagnosed). I'd rather have sensitive hearing than ringing in my ears.
Off topic: has anyone successfully dealt with Tinnitus? I'd doesn't drive me crazy, but there are times when I just wish I didn't have it..
post #12074 of 25179
Originally Posted by rich3fan View Post
Thanks Bob. I forgot to mention that the tray was open when I held the Enter button down after moving the switch in the remote (Yes I followed the instructions to a tee ). I saw the option in the Setup menu but didn't go that route since it was late and I didn't feel it was too important, but I'll try it that way tonite.
I just found ANOTHER restriction on this trick for changing the Remote Control Code Set in the player: It only works if you are on the Oppo logo "splash" screen (and with the tray open).
If you have any external media attached, the player boots up into Home menu instead of the Oppo splash screen. And then, even with the tray open, holding ENTER for 5 seconds on the remote won't switch the Remote Code.
Since of course lots of folks will have external media attached, I've sent a UI suggestion to Oppo to enable this trick even when on Home menu.
--Bob
post #12075 of 25179
I have a bit of it myself that I attribute to too many rock concerts in my youth. I don't believe there is a cure so I just give thanks that I still have my hearing.
post #12076 of 25179
Interested in the BDP-83? Check the AVS classifieds.
post #12077 of 25179
It's fairly common. It's called hyperacusis.
post #12078 of 25179
I learned something new, thanks.
post #12079 of 25179
To be honest I was about to purchase one from there but I was saving $50 going through Gatti. If I knew what I know now I would have gone through Merlin. I will contact him and see what he says. Thanks mate
post #12080 of 25179
OK ...I downloaded some HD videos(wmv format) using Amazons VOD service to my hard drive. I placed them into my USB flash drive and attempted to play them on my 95. They wouldn't play. Instead, i got this message "Your deice is not authorized to play this DivX protected video" Why???
My DLNA server (PlayOn TV) can log into the VOD service and play them on the 95 but due to bandwidth restrictions, it only plays the in SD and stereo. The HD files i bought are in 720p and 5.1 audio.
post #12081 of 25179
Perhaps there's a web forum where other customers in your area, also using that region free mod, might be able to discuss this? At least you'd find out if your problem is unique to your unit. I know we've got other Australians posting here, and I seem to recall there's another forum that they like to use as well which is popular with folks in your part of the world.
--Bob
I will void my warranty with Gatti if I do that I think. I will call him and ask if I can do that. Looks pretty simple online to remove and install
Thanks Bob
post #12082 of 25179
I am going to contact Merlin now. Thanks for the tip
post #12083 of 25179
The BDP-93 is not compatible with Amazon or iTunes video.
post #12084 of 25179
I understand your problems, though I can't hear the Oppo and was used to putting up with a PS3 before. However although I have tinnitus I can't use mains powered alarm clocks as I can hear the 50Hz mains transformer hum....very annoying!
post #12085 of 25179
Originally Posted by venkatesh_m View Post
I am using the hotway probox 4 bay non raid box with 4 samsung 2TB hdds. I am using usb as since the oppo does not hv a port multiplier for esata I did not even bother (same with the dune prime). Will try esata when I get back home later today but I'm quite sure it will not work.
This is the link to the 4 bay enclosure.
http://www.hotway.com.tw/products/hf2-su2s2.htm
To add to this, I have a (basically) generic StarTech HDD dock that holds two bare drives and connects via USB -- the Oppo sees both 2TB drives no problem. I don't have a NAS at the moment and am using bare 2TB drives full of Blu-ray ISOs that I swap out as needed, not the most elegant solution but fits perfectly with the Oppo's remarkable new ability to play ISOs. I'm really hoping SMB can be added in a later firmware for if/when I do get my NAS set back. But this is already a fantastic addition.
post #12086 of 25179
I have Tinnitus as professional diagnosed by an ear, nose and throat MD. I don't believe there is a cure, although apparently folks seriously affected can wear hearing aids that mask the noise or use other devices under the heading of Tinnitus maskers. There is no cure; depending on the original source of the problem, it may diminish over time.
In any event, I do find myself sensitive to high pitched chatter. But, I don't hear any extraneous noise from the OPPO 93.
Dana
post #12087 of 25179
Dana
Mine probably stemmed from all the inner ear infections and tubes I had put in my ears as a child. Its unfortunate that there is no cure...
post #12088 of 25179
Guys, this thread is noisy enough, can we move on please...
post #12089 of 25179
The Edge uses the same VP chip as the Oppo 83, so the output should be similar and thus little benefit in an Edge in that situation.
The Oppo 93 uses the Marvel Qdeo VP chip, which has different capabilities to the ABT2010 in the Oppo 83.
About the only advantage of using an Edge with the Oppo 93, is for being able to output 24p for 60i or 60p sources, since the Qdeo does not offer that capability.
post #12090 of 25179
--Bob
Good to know Bob. It looks like I'm going to be pulling my 980H out of my cabinet this weekend and switching the remote back to Code 1, because now my Harmony 880 remote is no longer recognized by the 93. This tells me that when the Code gets changed, the receiving end (the player) now interprets/processes the signals differently, as opposed to the signals being sent from the remote changing. Does that sound right?
