AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-93 Owner's Thread
Official OPPO BDP-93 Owner's Thread - Page 457
post #13681 of 25179
Originally Posted by Bob Pariseau View Post
You can move the emitter to the Oppo just as you describe, but you will need to reprogram your programmable remote. The emitter just acts as a repeater. Whatever flashing infrared comes from the remote gets re-flashed by the emitter and that's what the player sees at its infrared receiver.
However every device uses its own infrared code set -- so that you don't have a remote operating the wrong device for example. So you will have to reprogram your programmable remote to know the infrared code set used by the Oppo remote.
The rear remote control port just provides an electrical wire version of the same thing. Instead of an emitter flashing IR that's picked up by the IR receiver, the rear port takes an electrical signal that skips both those steps. Your distribution system may let you wire directly to the rear port instead of using the emitter placed over the player's sensor, but you'll STILL need to reprogram your remote to know to send the Oppo's remote commands anyway.
There's a whole Forum here at AVS dedicated to programmable remote controls where you can surely get help on how to reprogram your remote. Usually, it's not tough. You can likely also find a user manual for your remote on the web site for the maker of the remote. Typically you'll be able to download that and read it on your computer so the advice your get in the remotes Forum here may make more sense.
In the interim, the odds are your IR distribution system will work with the Oppo remote. I.e., move the emitter onto the Oppo and use the Oppo remote instead of your programmable remote to control the Oppo until you can get your programmable remote re-programmed. You can continue to use your programmable remote for your other devices.
EXCEPTION: Some programmable remotes use radio signals instead of infrared to communicate with the IR distribution system in the space with your devices -- typically for cases were the other stuff is out of sight as in a closet. If that's how yours works then the Oppo remote won't be able to send commands to the IR distribution system since the Oppo remote does not output radio signals -- just infrared light. That would just mean you have to get cracking on reprogramming your programmable remote.
--Bob
Thanks Bob. I had a feeling that I would have to reprogram my remote if I got the Oppo. But I did not realize that I would be able to use the Oppo remote until I figured out how to program my universal remote control. Thanks for the tip.
Cal68
post #13682 of 25179
Cal,
You'll have to reprogram the remote. The codes for Panasonic don't transfer over to Oppo. That being said, if you have your friend's contact information (email, etc), he can change the programming for you and then email the file for you to upload to the MX-3000 (assuming you have the CCP program).
post #13683 of 25179
Originally Posted by marklima View Post
Folks, is there any specific configuration to activate chapters support in mkv files? I can't manage to skip chapters on that kind of files.
I use MKVs almost exclusively for my media and have had no issues at all with my MKVs with chapters. If there are no chapters, the player will create 10 chapter points automatically for playback.
How are you delivering your media? If you're using a server that's transcoding your media, then you won't be actually playing your MKV directly which I'd assume would also render your MKV-specific features, like embedded chapters useless.
All media I stream use supported audio/video so I can play them directly without any transcoding. If your MKVs contain supported audio/video, then turn off transcoding on your media server or try playing them directly from a USB source or physical media like a DVD-R, BD-R, etc.
post #13684 of 25179
Originally Posted by JohnAV View Post
Remember this July 2011 survey . . .
As you said Bob, YouTube is extremely popular.
Another source with a sample of 1380 votes. This one is more focused for full movie/tv show streaming.
post #13685 of 25179
That graph simply depresses me to no end. I have a number of comments about those results but rather than possibly offend someone I'll just keep them to myself.
post #13686 of 25179
That's the problem. I'm playing them directly from an external HD. The chapters were inserted via mkvtoolnix. I can see the chapters, but Oppo can't skip them on "go to" screen. I'll try to reset it anyway.
post #13687 of 25179
Never mind whether it would be more productive to press Oppo or Pandora for the service. We should be haranguing BOTH of them. And, with regard to the audio quality of Pandora service, they do have a high resolution offering for $36 a month, but only through computers. What good does that do anyone who truly appreciates music?
post #13688 of 25179
Forgive me if this has been covered.
Is it still suggested to reset to Factoy Defaults after upgrading to new firmware?
I didn't see it mentioned in the Oppo instructions.
Tom
post #13689 of 25179
It is recommended but never required.
post #13690 of 25179
Originally Posted by rich3fan View Post
Thanks for your support baniels!
SO WHO ELSE IS WITH ME?
Bearing in mind that we'd probably never reach consensus about the message, maybe Oppo could set it up so we can each program our own message into it.
I'm thinking "G'day Blairy" at power on and "Don't go Blairy" at power off
Mind you my old 980 had the feature that allowed you to capture an image (from movie or photo) and use that as the background. That's be nice to get back.
blairy
post #13691 of 25179
blairy
I'll Second That.
post #13692 of 25179
Originally Posted by Dave Vaughn View Post
Cal,
Hi Dave
Yes, I remember reading on one of the forums that one needed some speciality software to program the Universal remote controls. Unfortunately I don't have it, so I guess I'll have to use the Oppo remote until my friend comes back to visit or I pay a dealer to come and program the remote for me.
Thanks for your help.
Cal68
post #13693 of 25179
After spending a few weeks going over every freaking Blu-ray player released within the last year, I keep returning to Oppo 93. All the other players have tons of negative reviews.
My question is, if I only have a 40" LED TV (1080P) and no other audio, could I still benefit from this player? My #1 concern is that Blu-ray discs and DVDs play quickly and without incident. I'm worried that this player might be too technical for me to understand.
If I can afford it, could this be the player for me?
post #13694 of 25179
If u appreciate quality keep bdp-93' you DVD look much better, this one the best out there,
post #13695 of 25179
It will certainly work for you, but I suspect many other players would also. All products have negative reviews. This is the internet -- people say all sorts of things.
It's not too technical when you have a simple setup. A direct connection to the TV is pretty worry free, and it's what I use.
The manual is online. You might browse it and see what parts apply to your situation.
Remember that OPPO is something of an enthusiasts brand, little known in the wider world but generally well-liked here. We tend to go on and on about every aspect, for good and ill.
-Bill
post #13696 of 25179
Hi,
I was wondering, is there any chance that there will be an (paid) app for the iPad soon to control the Oppo with Ã* fancy remote via Wi-Fi.
post #13697 of 25179
Originally Posted by Erik van Voorst View Post
Hi,
In the absence of physical impossibility, the answer to "is there any chance" questions is always "yes".
There is no public knowledge about this; OPPO doesn't usually talk about future features. It's best to presume it will never happen and be pleasantly surprised if it does.
I does no harm to make your needs known to OPPO.
-Bill
post #13698 of 25179
Hmmm, I wonder if it's the latest firmware. Come to think of it, since I updated to the latest firmware, I've only watched MKVs without chapters I think. I'll have to check and see if I now run into the same issue you are. I'll check later today and let you know.
In the meanwhile, I'd recommend cutting a small part of one of the MKVs with at least 3 to 4 chapters and provide it to Oppo support. If it's behaving that way on all MKVs, then Oppo should be able to duplicate, so make sure to email this issue directly to them.
BTW, I use mkvtoolnix too. How do you create the chapters? Using the UI and inputing them one at a time or via an external text file with timestamps? I use the latter.
post #13699 of 25179
Do you guys think OPPO will have a new 3D model BluRay Player this year?
post #13700 of 25179
No.
-Bill
post #13701 of 25179
I find the YouTube interface nice looking but not that useful. I'd like to be able to log-in and see my Favorites or Watch Later.
post #13702 of 25179
Thanks for getting back about mp3 streaming from my network.through the Oppo and how to display album art. I am still a little confused though. Most of the music that is on my hard drive come from orignal CD's that I ripped. Wouldn't the album be imbedded in those files. I use windows media player. The album art appears on my computer, through XBMC...but not the Oppo. Do I still need to imbed album art to get it to the OPPO? I did check out imbedding ID3v2 PIC tags. Is there a setting I am missing somewhere or do I really need to go through the labor of imbeding PIC tags. Thanks for the help.
post #13703 of 25179
Originally Posted by rdgrimes View Post
I'm still scratching my head at the notion of sending compressed lossy streaming audio through an Oppo player. It's not like Pandora offers high quality audio, so what's the big deal?
it is quite easy to mistake the "192kbps" audio as a "192kHz" HD audio, i think
post #13704 of 25179
the easiest way is to download free tag tools like mp3tag, then import your music files and check if there are any tag info shows on the left Tag panel.
Tools like WMP may connect to some music database to auto-download tag message, however, this is not available to OPPO yet.
post #13705 of 25179
please send your suggestions to oppo service and see if they can pass these information to Youtube.
post #13706 of 25179
Originally Posted by martinstraka8282 View Post
Ya I put just a thin (like 1/4" x 2") piece of masking tape over the IR emitter of my TV for the 3D glasses. Colored the masking tape black with permanent marker... voila, all fixed, glasses still work, all remotes work for their devices, and I cant even tell the masking tape is on the TV!
very impressive! any one else could try and confirm this?
post #13707 of 25179
--Bob
Cal,
Bob and Dave
I'm sorry for asking another question that I would normally have asked in the Remote Control forum, but since the two of you were nice enough to answer my first question, I figured that I would ask you one more remote control related question.
When I opened the original box in which my MX-3000 remote came in, I found that there is a CD titled "MX3000 Programming Tutorial, Complete Control". Does this disc hold the software that I need to program the remote? I know that I'll probably have to contact URC to get the recent version of the software which has the Oppo codes in it, but I just wanted to find out if the disc I have has the basic program in it. Thanks for your help. I'll post all future question in the MX-3000 thread in the Remote Control forum!
Cal68
post #13708 of 25179
It seems likely, but I've not used URC remotes myself, so I don't really know.
--Bob
post #13709 of 25179
Originally Posted by Cal68 View Post
Bob and Dave
Cal68
URC most likely won't send you or give you access to updated software as they only give access to their dealers. If you have a version of the software AND the configuration file for your remote (I don't use URC, so I have no idea if it's a single file or a set of files), you most likely have everything you need. There's most likely a way to teach the remote or software codes that aren't in the URC library, so you should be able to use the Oppo remote to teach it. You'll also need to learn how to use the software - depending on how tech savvy you are, this may be easy or nearly impossible. As others have suggested, the Remote Control forum is a better place to discuss this. There's also URC specific discussion at Remote Central.
post #13710 of 25179
--Bob
Thanks for the quick response from both of you. I promise not to ask any more remote control questions on this forum!
Cal68
