Originally Posted by
spike9876
Main Idea was to get an IPad to have it as a remote... but at the same time be able to use it to stream music photos to my TV.
Not familiar that much with iRule yet... but it seems similar to Logitech... but instead of RF it connects to the network instead... Looks like some models also have RS-232 outputs but I'll be getting more info on this...
Ok, the iRule works in conjunction with Global Cache hardware to handle learning and transmitting IR codes to the gear you want to control. Note that for any devices that aren't in the iRule IR database, it looks like you would need to purchase the $75 Global Cache GC-IRL to learn the IR codes from the original remote (it looks like they have the Oppo players in their database). That should definitely work fine with the Oppo and Global Cache makes good stuff. How easy it will be to get the iRule software up and running is something you would want to look into. Further discussion of this really belongs in the remote control forum where you might find other people who are looking into or using iRule. One downside these guys share with Logitech Harmony is the way you program the remote online - if they go out of business, you'll most likely lose the ability to change your configuration.
spike9876
Talking about streaming... what is the best way to stream music/pics with OPPO ? Preferably with an IPhone/IPad
The Oppo can only pull content using the UI on the Oppo either from attached drives or from a DLNA server. It isn't a DLNA renderer, so you can't use something like an iPhone or iPad to push content to it. That said, the best way partly depends on what content you want to watch. If you want to watch ripped Blurays and DVD's, your best option is probably locally attached hard drives so you can use the ISO support to get full support for menus and everything else just as if you had put the original disc into the player. For other content, DLNA may be more convenient as it allows you to store your content on a PC and stream it over your home network.
