Originally Posted by camchow
thank everyone for all the info about this player
just buy this player yesterday(not arrive yet) to replace my panasonic
i have an old stereo receiver without the hdmi input only has the optical input for the audio
so i m going to use hdmi cable output from the oppo to my tv and use optical output to the stereo receiver
may i ask what is the best set up for this should i turn off the hdmi audio out and get the audio signal from the optical cable to the receiver
and what is the best and easy set up to start,and i will do a later set up and adjustment when i have time in the future
thank you!
thank you!
The default settings in the player will be fine to start. Do read the Manual section on cabling choices as suggested above.
Using HDMI direct to your display for Video and Optical Digital to your receiver for Audio is certainly a viable option, and definitely the simplest way to get started.
But if you only have stereo speakers -- or if you have surround speakers AND your receiver has multi-channel analog inputs -- then you may very well get better audio using the analog outputs of the Oppo. This is because the analog outputs of the Oppo use the high bit rate audio tracks from Blu-ray discs whereas the Optical Digital cable uses the "compatibility" lossy audio track instead. Using the multi-channel analog outputs is a little more complicated because you need to do some speaker configuration settings (described in the Manual).
--Bob
