Does anyone of you have the same problem with HDMI-CEC, in that even with the HDMI(Limited) setting, the Oppo switches on my Samsung TV, when according to the setting description in the manual it should not?
HDMI 1 (Limited) - HDMI CEC is enabled on HDMI 1 output, but the BDP-93 will only respond to playback control commands. It will not respond or issue power on/off and input selection commands. Use this mode if you do not want the automatic setup function to turn on/off your devices.
