AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-93 Owner's Thread
Official OPPO BDP-93 Owner's Thread - Page 513
post #15361 of 25185
Originally Posted by Thrummer View Post
Will my Oppo stream mp3's from my PC via wireless? I currently have a PC/Laptop wireless network in my home.
When I installed the player I skipped the wireless network set up piece and have just been using it for BD/DVD/SACD/CD's up to this time.
We don't have NetFlix/Oppo capability yet (Canada), and some of the other USA services (Pandora).
But it would be convenient to stream rather than download to a usb from the PC to use in the Oppo (which I've done on rare occasions).
MP3's...merde
You will get beter quality streaming lossless codecs such as flac or wav and yes with the oppo you will be bale to tell the difference
post #15362 of 25185
Umm, Netflix on the 93 and the 95 DOES work in Canada with the current OPPO firmware.
--Bob
post #15363 of 25185
Originally Posted by Neuromancer View Post
MKV does not, and likely will never, support lossless audio formats such as FLAC, Dolby Digital TrueHD and DTS-HD Master. This has been requested well before the release of the player to the public, and if it has not yet been implemented into the player at this point, it likely never will.
I've been asking via email about this very issue roughly every three months...followed up the other day (without realising that neuromancer had already answered this) and Oppo's response is...
We have requested from MediaTek that they enable high resolution audio in a MKV container, but so far they have not been willing to do this. We have been requesting this functionality for more than a year, so it is unlikely that high resolution audio in a MKV container will be supported through a future firmware release.
cheers
blairy
post #15364 of 25185
Originally Posted by SeriousHorse View Post
Sounds a little odd. If DVDFab is re-encoding the video, you'll probably notice a difference, but the ISO file should be exactly the same as the original disc, unless DVDFab is using compression (to fit a DVD9 onto a DVD5, for example) by default.
Try making sure the ISO file is an uncompressed copy. You can also try using MKVMerge GUI to simply remux the VOB files (pick one and it will automatically add the others) to an uncompressed MKV file. Again, the quality should be identical.
Thanks for responding, SeriousHorse.
Except for the .avi file, there is no file compression at all. In fact, a .vob file is an exact copy of what is on the disk. (An .iso file is simply a container for all the .vob files.) You don't even require a ripper program - simply copy the files from the disc direct to the HDD. Yet the result is still not as sharp as that played from a disc. I tried all the 4 formats. Everyone exhibits the same pic softness - not much, but easily discernable.
I wonder if the USB connection from the HDD makes a difference. Or is there another factor involved?
Ben
post #15365 of 25185
Ben
Be aware that Fab can output an ISO even when it's using a compression mode. Try using something other than Fab to create a DVD ISO. Or, use Fab in clone mode to make an ISO. I think you should stick with the assumption that there's no difference between an ISO and the disc in terms of quality. Any differences you might see would be either a matter of user error or of perception.
post #15366 of 25185
Ben
That's mysterious. I doubt if the connection can make a soft picture. Try the files on an optical disc. They all should work except for ISO, which is not supported on a data disc. Obviously you can burn it as a disc image, making it normal DVD Video.
Actually, that would be a good test: compare the original DVD with a burned copy made with your method. If there is a difference then there is something wrong with your process.
-Bill
post #15367 of 25185
I upgraded from the 83 to the 93 a couple days ago. I'm into DVD Audio and SACD, and also the idea of playing wav files through USB.
I'm confused about something. DVD Audio has been playing beautifully, through digital optical, on my 83 and 93, but I have just discovered in the owner’s manual: "Due to copyright restrictions and bandwidth limitations full resolution audio from DVD-Audio discs cannot be sent through the coaxial or optical digital output. To listen to DVD-audio in full resolution, please use the HDMI or analog audio connections."
My receiver doesn’t have HDMI input. I listen to SACD through analog – set up for 5.1 (not 7.1). I’ve been listening to DVD Audio through digital optical.
I’ve A/B’d the DVD-A (played through digital optical) with CDs of the same uncompressed music played on my CD player, and I hear no difference. DVD-A sounds equal or better.
So is there really any truth to the above that analog would work much better? Digital optical sounds fantastic.
To listen to DVD-A through analog I’d have to switch the cables around every time I want to go from DVD-A to SACD? I’m reluctant to do that even once, since it’s an enormous amount of crawling and squeezing into position, moving my receiver without disconnecting cables, etc.
post #15368 of 25185
Definitely no compression involved. I compared the sizes of the .vob files inside the ISO container with that on the disc and they're identical. That's what baffles me.
-Bill
That's a good idea. I'll get some hold of some DVD blanks and burn a copy of the .vob files on one and see how it goes. Thanks, Bill.
Ben
post #15369 of 25185
I'm confused about something. DVD Audio has been playing beautifully, through digital optical, on my 83 and 93, but I have just discovered in the owner's manual: "Due to copyright restrictions and bandwidth limitations full resolution audio from DVD-Audio discs cannot be sent through the coaxial or optical digital output. To listen to DVD-audio in full resolution, please use the HDMI or analog audio connections."
My receiver doesn't have HDMI input. I listen to SACD through analog - set up for 5.1 (not 7.1). I've been listening to DVD Audio through digital optical.
I've A/B'd the DVD-A (played through digital optical) with CDs of the same uncompressed music played on my CD player, and I hear no difference. DVD-A sounds equal or better.
To listen to DVD-A through analog I'd have to switch the cables around every time I want to go from DVD-A to SACD? I'm reluctant to do that even once, since it's an enormous amount of crawling and squeezing into position, moving my receiver without disconnecting cables, etc.
All Oppo outputs are always active so you don't have to move cables around. Just select different inputs on your AVR. Just have both analog and digital optical hooked up.
post #15370 of 25185
Maybe I'm missing something. But there is no dedicated stereo output in the 93. You have to use the LF and RF and downmix appropriately.
Since I have the LF and RF on my Oppo tied up for SACD - connected to the multi-channel input on the receiver, I'd have to take those connections from the multi-channel input on the receiver and move them to the stereo input on the receiver. Isn't this true, or am I missing something?
post #15371 of 25185
If moving the cables to another input is necessary to be able to use the player the way you want, RCA splitters would also do the trick.
post #15372 of 25185
Interesting idea. I may give it a try. I wonder if there is any nocticeable loss of signal by doing that.
post #15373 of 25185
I'm now listening to the Beatles entire studio catalog, together with Anthology and the BBC in (uncompressed) WAV format - using shuffle play, through a USB thumb drive. I've never been set up to do that before in WAV format. The possibilities this device opens up are amazing.
The one problem is that when going to songs direct or through random or shuffle play the first split second of each song is cut off. This is true with USB input or with DVD-A discs. (This wasn't the case with DVD-A with the 83.)
Maybe I'll email Oppo notifying them of this -- unless I learn they are fully aware of it and are working on it.
Before I did the latest firmware update, the time display for DVD-A was stuck at 0 after the first song. That was fixed in the latest update. Impressive!! Hopefully these split second drops at the beginning of songs is something they will also fix soon.
post #15374 of 25185
Your AVR will most likely be digitizing any stereo analog input, so there's not much difference between doing that and just using SPDIF for CDs. The multichannel inputs on that AVR will bypass the conversion.
For stereo sources, you may also find that the multichannel inputs works just as well, but it's easy to connect both and compare on the same source material.
post #15375 of 25185
I tried switching to multichannel and back and the MC sounded terrible. Much lower volume, more trebly, and harsher. (And I tried changing the "Down Mix" to both "Lt/Rt" and also "Stereo" - made no difference.) Doing this through the AVR's multichannel would not seem to work well. I'd need to try doing it through the AVR's "stereo" input next, but it sounds so good now through the forbidden digital optical output, that it seems like a waste of time unless someone who's tried both reports back and says the analog route sounds not just outstanding, but super duper, hyper-amazing compared to digital.
post #15376 of 25185
Most likely you are experiencing some limitation of that AVRs multichannel inputs, not necessarily a limitation of that connection in general. I'm not sure that anyone else's experience on different hardware will shed any light on yours. Older AVRs can have a range of issues. Look for setup options in that AVR specific to the m-ch inputs. In your situation I would stick with SPDIF when possible and start saving for a new AVR. A very decent new AVR can be had for less than the cost of the Oppo.
post #15377 of 25185
Not sure but I think the problem may be with the Beatles songs themselves (the ones you purchased via USB stick in the novelty apple - the 20bit/44K versions). I too had this issue but it only seemed to be with those Beatles songs so I am not sure if it is something in the build of the music files or the way they are being seen by the Oppo/AVR or something in the chain. Might even be some issue with the 20 bit......Dunno.
I just moved all my music over to NAS and playable via Twonky but haven't had a chance to see if this issue duplicates there too. Same files and all - just playing through Twonky. I may try this over the weekend and post back. You may also want to try some other music and see if you can duplicate it with other songs or file types.
post #15378 of 25185
The problem is with ANY USB input or DVD-A disc -- even DVD-A discs which played perfectly on my Oppo 83. I didn't buy the Beatles USB stick. I made my own -- EAC'd the 2009 remasters I'd bought and put those WAV files onto the USB. (Apparently you can't make good folder systems with everything in the right order, so I just threw in everything and have that USB file just dedicated to random or shuffle play -- which is what I like to do anyway.)
I wonder if this is related to using digital optical, instead of analog or HDMI. I wonder if folks who have HDMI input on their AVR, and are using that, have this sort of problem.
post #15379 of 25185
Are you using hdmi1 out?
post #15380 of 25185
After all the discussion today on the question of listening to DVD-A through optical digital, as opposed to HDMI or analog, and after my own outstanding experience with the sound quality of optical digital ... I've concluded that the owner's manual is exaggerating in stating:
What I hear sounds SO good that I believe that if there is any advantage in using hdmi or analog, it is so small that it's not worth the effort to take unusual measures to change from optical digital. Optical digital sounds fantastic!!
My only problem with DVD-A is the missing fraction of a second at the beginning of each song when jumping direct to the song. And this is not due to the use of optical digital, since i had the exact same setup with my old 83, and there was not this problem. I believe this is a bug that Oppo can and probably will fix soon.
post #15381 of 25185
The only real disadvantage to using optical or coaxial for DVD-Audio is that you are restricted to stereo only. You will not be able to get multi-channel, like you would using analog or HDMI, from a DVD-Audio source when using optical or digital coaxial.
post #15382 of 25185
Yes, that is probably correct. And that is fine with me, since the only DVD-A discs I'm going to be making are regular stereo or mono. I wish the manual was a little more specific there.
post #15383 of 25185
I am not sure that I understand correctly what I have read in the manual and online. Does HDMI audio need to be set to OFF for DSD to be sent directly to the DAC without converting it to PCM or was this a limitation of a previous firmware?
post #15384 of 25185
I hope someone can help me
I have several BD rips in MKV format on an external har drive connected to the USB of the 93.
When I play a 2.35:1 MKV (1920x804), the 93 is stretching the image to fill the screen, eliminating the top and bottom black bars. This of course distorts the picture by making the people look tall and skinny.
If I play a BD disk with 2.35:1, the aspect is correct, with top/bottom black bars.
Why do only my MKV's get stretched?
post #15385 of 25185
Short answer: because they've been muxed in an incompatible way.
First step, make sure your display is set to "Wide/Auto" in the Oppo's settings.
Second step, remux the files that aren't working properly with MKVMerge GUI (this is available for Windows, Linux and Mac).
There is no third step. That's all you have to do: just remux it with MKVMerge. You don't even have to change anything within that app. After that, the aspect ratio will be just fine.
post #15386 of 25185
I ran into an odd problem last night.
I was watching a MKV video file and all of a sudden the screen saver kicked in. I suppose the mkv could of been broken or something but I have never ran into this problem before.
post #15387 of 25185
Not happy with the BDP-93. I failed to thoroughly read this thread and I don't like:
1) Can't play DVD structures over DLNA without glitches. They play but I have 1GB .VOB files and when the player has to switch to the next file it pauses and if there is more than one audio track it often switches that too. So I'm listening in English and it pauses and switches to Italian The pausing is documented in the guides which I failed to read. Removing the glitches means re-encoding all my movies
2) I don't like that the Optical / Coaxial digital audio outputs are dumbed down to audio only. I don't have an HDMI AVR and I'm not going to be forced into an upgrade. My only solution is to let the 93 do the decoding and output 7.1 to my AVR.
3) Don't like that My Network has no means of showing movie summaries, lengths, cover art, or cast.
4) Don't like that BMP and TIFF picture formats aren't supported.
I'm returning my player and sticking with my Windows Media Server. It's much more wife friendly. I just need to upgrade it to play Blue-ray and I'm all set. The only other thing I can't due is stream Netflix.
post #15388 of 25185
Could you please explain what you mean in number 2 by the coax/optical being dumbed down to audio only? I don't understand what you mean by that.
post #15389 of 25185
@SeriousHorse
Thanks my friend, that did the trick. It took me a while to actually find the software download link, but I finally found MKVMerge GUI version 5.0.1
It took about 5 minutes to run the remux in a 3 hour film. I did have to change 1 setting in the "Format Specific Options" tab, I had to select 2.35 under "Aspect Ratio"
Thanks again and this is a great forum for info.
post #15390 of 25185
I was wondering the same thing. I'm assuming he wasn't expecting the optical / coaxial digital audio outputs to also support video, so I suspect he's talking about the way Dolby True HD, DTS-HD Master Audio, etc. have to be converted to lesser formats / use the core track, SACD isn't available, and so on. Basically, restrictions that Oppo really has no control over and won't be any better with a different player.
Jim - Playing Burays on your PC can work, but a lot of people have found that it isn't as simple as installing a Bluray drive and software (Arcsoft TMT, PowerDVD being the 2 most popular). If you decide to go with that, do yourself a BIG favor and get yourself a copy of AnyDVD HD (or the DVD Fab equivalent). Make sure you do your research on this in the Home Theater Computers forum and try out trial versions of the software before making your purchases as refunds generally are not available after you purchase the software.
