AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-93 Owner's Thread
Official OPPO BDP-93 Owner's Thread - Page 53
post #1561 of 25196
Will I be able to send my computer screen through the BDP-93 to watch past TV episodes?
post #1562 of 25196
Your current choices are Netflix and Blockbuster streaming services, with perhaps more to come in the future. If you have video saved on your computer as media files, you can serve them yourself with DLNA.
-Bill
post #1563 of 25196
Well finally got around to hooking it up. Have the following setup:
OPPO 93 HDMI 1 out to HD Fury III to tv. Works fine with the limited BD titles I have played so far. Need the HD Fury to convert the HDMI to component for my aging 1080i component in RPTV.
HDMI 2 out to my Denon 4806 via LPCM. No problems with SACD playback. Did not and do not plan to use HDMI 1 to my Denon.
Was able to play a FLAC file from a USB thumb drive that I downloaded from HD Tracks dot com. I converted the same file to apple lossless with XLD, and even though it showed up in the browser, it would not play.
I was also able to connect to my wireless, and it found my NAS, but not any file or directories. No server software running on it yet. Used for my backups
post #1564 of 25196
I set up the BDP 93 using the same cables that I used with my BDP83. I sent the Hdmi 1 to my UMC-1 and from there to my projector and HDMI 2 to a sony TV. I get video only on the hdmi 1 and both video and sound thru the TV. I designated in the set up wizard primary Hdmi 1. I reversed the cables and Hdmi 2 provides sound thru the UMC1 and video while I still only get video to the TV. I dont get access to primary video output in the regular set up menu. In order to change video settings I have to reset factory default and start all over. Any suggestions
post #1565 of 25196
Originally Posted by rinnan@online.no View Post
Thanks NewPannyGuy.
If I have a good DAC already, does the Oppo not have digital outs so I can skip its dac and use my separate one instead?
Does the whole downmix to stereo process in any way modify/degrade the signal, or is it kept in its purest form? I mean, comparing to a SACD / DVD-A player which is meant for high-end 2-ch. audio, is this downmix solution a disadvantage?
Thanks again for all the help!
From their website:
post #1566 of 25196
See the FAQ: Why is Primary Output greyed out?
-Bill
post #1567 of 25196
Does a DLNA server exist that allows streaming a podcast from a webpage to the BDP-93...or even an Xbox 360? I tried twonky manager and twonky beam but the Manager program closes automatically after 2 mins.
I want to stream this website: http://www.trancearoundtheworld.com/tatw/349
post #1568 of 25196
What was the extension on the file name?
-Bill
post #1569 of 25196
Try the Oppo BDP-83 DLNA/UPnP thread.
I know Twonky server has features like that but I have not explored them.
-Bill
post #1570 of 25196
Sounds like we did the same experiment...with the same results. I was able to play the FLAC, and the same tracks converted to WAV using MAX, but the Apple Lossless files (.mp4 extension) show up, but the Oppo just skips through them w/o actually playing them.
I have not tried an AAC compressed .mp4 version, since I am not interested in playing lossy files.
Brian
post #1571 of 25196
-Bill
.m4a, just like the AAC file. I think in the apple lossless file , it is wrapped in the m4a.
The AAC compressed file worked fine
post #1572 of 25196
I'm not very familiar with how things work on Apple, so check me here:
Two .m4a files. One is AAC lossy and plays, the other is ALAC lossless and doesn't play.
I don't have an Apple lossless example in my test suite. Could you post a small example somewhere? I don't know if this is supposed to be supported or not.
-Bill
post #1573 of 25196
-Bill
As I understand, yes. I will try to get spot to post and get back with you unless someone beats me too it.
post #1574 of 25196
Originally Posted by slimoli View Post
You can't have DTS HD through coaxial/optical. If you have HDMI1 to the display and HDMI2 to the receiver, however, you get all the HD audio. Why are you using coax/optical if you can use the HDMI2 to output any audio mode ? The best you can do is HDMI1 to the VT25 and HDMI2 to the Integra, nothing else should be plugged.
Thanks, I thought that might be the case and have disconnected the optical.
post #1575 of 25196
I really wish Oppo had included dedicated 2 ch analog outputs on the 93. It would make things so much easier to use with my Zone2 2 ch configuration.
On the 93, using both HDMI outs (one to a MC pre, one to an LCD TV), can HDMI-1 be set to output MC (5.1) and HDMI-2 set to down-mix to 2ch, or is the downmix applied globally to both HDMI outs?
Using FL/FR anlaog outs and constantly switching from MC to down-mix is a PITA and not a working solution IMO.
post #1576 of 25196
I know its been discussed before but now that people have units in hand can someone confirm if the 93 will or will not strecth 2.35 content in 3d? There is another thread that vaguely suggests that they are accomplishing this task. Since that thread isn't an oppo 93 thread, I figured it would be best answered and explained here. Thanks!
-Sean
post #1577 of 25196
Originally Posted by ElwayLite View Post
Watched Tears of the Sun, and Karate Kid 2010. Everything going very well, but realized another drawback from the wifi reconnect issue. After Karate Kid, clicked on BD Live because I wanted to check it out, and the box told me to check my connection. When having the Nflix problem earlier, I did not even consider this an issue with BD Live. So, FYI, you may need to connect to the wifi, before booting the movie, if you plan on using BD Live.
You can bring up Setup and force the wifi reconnect that way while the disc is playing if you have to. That won't work for Netflix, but it's available during disc playback.
--Bob
post #1578 of 25196
-Bill
For watching what's on a computer, is there any reason that a DLNA server to the Oppo would be better than simply connecting the computer directly to the display (in my case, a projector, with the audio going through my AVR)? With Netflix, it looks like higher definition is available when going through the Oppo compared to the computer, but with Youtube, etc., is there any benefit to using the Oppo?
post #1579 of 25196
You could return it and wait for the BDP-95.
Downmix does not apply to HDMI at all. Only analog.
-Bill
post #1580 of 25196
-Bill
Just sent a PM with a link to some files. Let me know if it works. I plan to send to OPPO also.
post #1581 of 25196
Originally Posted by Grampa View Post
Does anyone know whether Netflix streaming on the 93 supports the option to add subtitles? I watched parts one and two of Red Riding Trilogy on DVD, both of which had the option for English subtitles (the films are performed in a thick, Yorkshire accent). I then streamed part three, but it did not have this option. I'm wondering whether subtitles are available for foreign films, or perhaps they are automatically turned on, with no option to turn them off.
As to quality, streaming over the 93 is MUCH better than streaming from a PC (connecting to the projector via RGB). Was PC streaming limited to 480i? Looks like it.
I thought I would bump this question from a few days ago in the event someone has an answer.
post #1582 of 25196
It's hard to advise. They will look and operate differently, but if you are happy with the computer connection then why not use it. On the other hand a lot of people have found DLNA easy to set up. It won't do everything a computer can do.
-Bill
post #1583 of 25196
I'm running the FL/FR outs into the analog inputs of an older Yamaha receiver and did not use the down-mix setting but left it at the default setting. I'm not noticing any loss of information and the music quality sounds good to me. You might give that a try and see what you think. YMMV.
post #1584 of 25196
it does not. I know that you cannt do it on the ps3 either. I was able to rent the 3 movies on dvd and then watch them with the subtitles on. I also had the same problem.
Jacob
post #1585 of 25196
-Bill
In my current setup, I do have a computer connected to the projector via RGB. I'm getting a new PJ which lacks RGB, but it does have a component input, so I guess an adapter will work. Regarding DLNA, I think there may already be a server on my WD network drive (My Book World). At least, the Oppo is able to see and play MP3 files and a home video stored there.
post #1586 of 25196
Jacob
What about foreign language films? Even if there is no option, you would think they would be automatically turned on for U.S. audiences.
post #1587 of 25196
it does with foreign films, but not with the red riding trilogy. you canask netflix to send you the disc. that is what I was able to do. sorry. I meant to asnwer ealier but the thread went too fast.
Jacob
post #1588 of 25196
Jacob
Thanks, Jacob. After two discs of Red Riding, I think I finally got used to the accent.
Just to clarify, however: with foreign films streamed to the Oppo, are you given an option to turn on subtitles, or are they on automatically and can't be turned off?
post #1589 of 25196
On the PS3 there is an option to add subtitle on some movies, not all of them. This has been introduced together with the 5.1 audio on the new firmware. I think that's what Grampa was asking. I believe the Oppo will have the new Netflix interface in near future.
post #1590 of 25196
Hi All
I finished my rack today and thought I would show you some pictures with the AV7005 and Oppo 93.
Moderators Note: Image deleted. This type of post should go here: http://www.avsforum.com/avs-vb/forumdisplay.php?f=29
