Originally Posted by
LoopinFool
Bob P,
Can you please verify that the 720p scaling fix works when the player is set to the explicit 1080i output resolution?
That's how I have mine set up since my display does perfect IVTC in all cases if I just feed it a steady stream of 1080i.
- LoopinFool
For HDMI 1 (Primary) output, 720p upscaling to 1080i output works fine. The output will of course be 1080i/60 regardless of whether the content was 720p/24 or 720p/60.
Another poster asked about DOWN-scaling 1080p or 1080i content to 720p output. Again for HDMI 1 (Primary) output, 720p output works fine. The output will be 720p/60 regardless of whether the content was /60 or /24. (HDMI signal specs don't support 720p/24.)
Please note, that even though it may be counter-intuitive, it is sometimes the case that 720p or 768p native resolution displays actually WORK BETTER with 1080i or 1080p input. This has to do with design compromises made by the manufacturer. If forced to choose, manufacturers will tilt towards making 1080i or 1080p input look better because that's how the sets are shown off in stores.
The bottom line is that if you have a 720p or 768p display you should find the time to calibrate for BOTH 720p player output and for 1080i or 1080p player output (if your display will accept 1080p), and see for yourself which works better on YOUR display.
NOTE: It may be the case that the "best" settings in your display are DIFFERENT for 720p input than for 1080i or 1080p input. This shouldn't be the case -- if it happens it is likely due to a bug in your TV -- but it does happen. So CHECK both ways and don't just assume the settings for one way must also be the correct settings for the other way.
--Bob
