AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-93 Owner's Thread
Official OPPO BDP-93 Owner's Thread - Page 682
post #20431 of 25196
^ Wifi or Ethernet?
--Bob
post #20432 of 25196
Originally Posted by dmusoke View Post
Anyone having problems with Vudu the past couple of days? I keep failing the network connection tests as run from the Vudu app. I connected my laptop directly to the output of my cable modem and went to the speedtest.vudu.com site and run the tests fine at an average speed of 10Mb/s. Oppo's network connection tests also runs fine. Vudu loads fine but fails the speedtests and movie playing just hangs there doing nothing. Any help?
Ironically just ran the test last night...
Full green bar and no problems running the stream.
post #20433 of 25196
Originally Posted by Bob Pariseau View Post
^ Wifi or Ethernet?
--Bob
Ethernet to the Oppo.
Bummer!
post #20434 of 25196
I'm not seeing a problem here either. (Using Wifi)
It's of course possible that you've just a had a spate of bad luck based on which server VUDU is connecting you to. One thing to check is that the DNS settings in the player and in your computer are the same. It is common for these streaming setups to choose a server they think is close to you based on the DNS server your device uses to find them.
Setup > Network Setup > Connection Information > DNS 1 and 2
Failing that, try a general reset. Power cycle your Inernet modem and router.
In the OPPO:
1) Remove any disc. Jot down your personal settings.
2) Erase Persistent Storage. Reset Factory Defaults. When the Easy Setup Wizard finishes, power down the OPPO.
3) Pull its power cord for about 10 seconds.
4) Power up and re-enter your personal settings. Double-check any manual settings you are making for your Ethernet connection.
5) Power down once again. Settings are saved during the power down cycle.
Check VUDU performance again.
--Bob
post #20435 of 25196
Hi, My you tube is not working. The you tube logo only comes and stays there. It is not working.
Is it working for the current official release?
post #20436 of 25196
Thanks Bob:
That did the trick! My DNS 1 and 2 server addresses were out of whack with my the ones on my laptop. I had to use manual servers on my router when i decided to use OpenDNS's faster servers and Oppo didn't "know" about it.
post #20437 of 25196
Been a week now and I don't think they (Oppo/Google) are in any hurry to get to it.
post #20438 of 25196
Well known problem in this thread. Oppo and Google know about it and are working to fix the problem.
post #20439 of 25196
Hmm, Oppo's (old?) offices in Silicon Valley were about 5 minutes from Google HQ ...
post #20440 of 25196
Re the YouTube "Leanback" service:
Fun with 3rd party services.
It seems Google changed the interface between the server and the YouTube app. Apparently, unexpectedly.
As such, it's not a "bug" from Google's point of view. That is, Google are not going to back off the change to what their server is now sending out. And the current YouTube app on the OPPO can't handle that. The app for the OPPO will need to be adjusted to match. That's in process.
As with all the other 3rd party Internet service apps, the code for the YouTube app comes from the service provider -- in this case Google. I've no idea why they changed how their server works before getting an updated app in place.
I can't give any ETA on the updated app (which will have to come as an OPPO firmware update). But it's a fair assumption I think that it will be in the next Public Beta firmware release.
--Bob
post #20441 of 25196
Thanks Bob:
Cool! Glad it worked.
--Bob
post #20442 of 25196
Though 5 minutes away from each other, i wouldn't be suprised if it took weeks to get approvals from management from both sides to work on problems together
post #20443 of 25196
I have a DLNA server (WD) and the OPPO can play content from its folders, except that it "burps" in between chapter or title changes. I forget which.
That's one reason I've not upgraded to the latest firmware, as I assume the OPPO will play cleanly and support working menus from the same content when in the .ISO format. The only thing I have to figure out is how to use it.
The WD live has no problem seeing / playing a .ISO on its local store, but the same file is invisible to the OPPO.
I'm guessing this is because it will only play that content from a local USB or SATA drive.
So I'd like to find out exactly how this works so I can create the right folder names for .ISO content (and ripped BD content while I'm at it).
I know this has been discussed in this thread frequently, but if anyone could point me to several posts and do a particularly good job of explaining everything .ISO for this player, it'd be a great help.
post #20444 of 25196
ISO never worked over DLNA; as far as we know it's not possible.
For ISO on local storage, there is nothing to know. Just copy the file onto storage and attach it to the player. And don't update firmware.
If ISO support is important to you, I suggest finding a different device for that.
-Bill
post #20445 of 25196
ISO is not supported via DNLA. Your DNLA server may be allowing you to access them, but it's just opening the ISO and serving the individual video files. That's the cause of the pauses between files.
ISO was only supported via storage attached to the player, and the player will treat them exactly as it would the physical disc. DVD-V, DVD-A and BD are supported and will be accessible via the "Movies" icon on your home screen.
BDMV folders are still supported at this time, so there's another option for BD besides ripping to ISO. A BDMV folder will also be treated the same as the physical disc.
post #20446 of 25196
So you just name the folder "BDMV" on the local attached storage, or does the name matter?
post #20447 of 25196
BDMV is the name used by BR video; I'm pretty sure you can't name it anything else. You can nest it inside other folders, named by titles, for example.
If you renamed it you would be able to navigate into the folder and play the individual m2ts files, but that's not the same as playing a copy of the disc.
-Bill
post #20448 of 25196
"BDMV" is the folder in the root of every BD disc that contains the movie. Same as "VIDEO_TS" on a DVD.
-Bill
This is incorrect, Bill. As long as the internal file structure is unchanged you can re-name a BDMV folder to anything you like. It still acts like a disc. At least for now.
post #20449 of 25196
Question: Would I benefit by enabling the QTC? If I applied a deep color mode to HDMI 1, will that give me something I'd be happy with?
post #20450 of 25196
No matter what I try, I cannot establish a wifi connection with a non-broadcasted SSID. As soon as I set the SSID to broadcast, the connection works flawlessly but when going back to non-broadcast I again have no connection. All my other devices (phone, printer, tablet, receiver) work without issue except the Oppo. When trying to set up a manual connection on non-broadcast I receive the message:
No matched SSID. Please re-enter SSID.
I have followed the suggestions at http://www.avsforum.com/avs-vb/showt...3#post21317653 but with no luck. What else can I attempt?
post #20451 of 25196
Are there any rumors for PGS-subtitle support in MKV-files?
post #20452 of 25196
Welcome to AVSForum.
There wouldn't be any rumors; those who know wouldn't say. OPPO hardly ever talks about futures.
I've requested PGS/SUP support in MKV, along with hidef VOBSUB.
VOBSUB works now in MKV with standard definition video, but not when sized to hidef. SRT subtitles work now.
PGS/SUP work in m2ts files.
-Bill
post #20453 of 25196
For anyone purchasing an Oppo 93 from Amazon in the last 30 days or so: what version of the firmware was on your unit? I have one coming tomorrow and wonder what are the chances of it coming with the March 2012 firmware. Looks like Oppo direct is shipping with the latest one. Thanks.
post #20454 of 25196
I received my Oppo 93 from Amazon on March 20th and it came with the Sept 2011 firmware. Because I don't care about the .iso capability I've already upgraded to the March firmware.
post #20455 of 25196
April 10th for me and September firmware. Already updated to March firmware without issues.
post #20456 of 25196
Mine came from Amazon (shipped from Arizona) on April 18th and had the BDP9x-61-1219 firmware.
post #20457 of 25196
Thanks for the info. Looks like mine is coming from Indiana. Will know tomorrow. Would like to have ISO support, but I also have a Dune in case I get the later firmware.
post #20458 of 25196
That's exactly the same for me too for last week's order!
I'm all set!
post #20459 of 25196
Does the current firmware only disable the ISO support for BluRay.. or does it disable ISO reading for regular DVD's?
post #20460 of 25196
It disables all ISO playback (Blu-Ray, DVD-V, and DVD-A).
