Originally Posted by
cast away
Oppo BDP-93 vs Spiderman 2 problem.
I face audio problem playing Spider-Man2 from Spider-Man:The High Definition Trilogy Blu-ray box set on Oppo BDP-93. The problem is audio stutter in some scenes e.g. in the hospital scene when Doc Ock's mechanical arms are attacking the surgeons. However I found no problem at all when playing this BD movie with Sony BD player.
Has anyone encounter this problem and how you fix it? Your advice is highly appreciated.
Thank you.
I don't believe we've had any posts here reporting an issue like this for that movie.
Start by checking that you have the latest firmware installed. Check Setup > Device Setup > Firmware Information. The Main firmware version number should end 71-0723. If not, then you should update your firmware and see if the problem still exists. See the Support page on the OPPO web site for the simple instructions.
If you already have the latest firmware, please email the details of your problem to OPPO Digital Tech Support in the US (if you have a US model BDP-93 player) or to OPPO UK Tech Support in the UK (if you have a European model BDP-93EU player). In addition to telling them that you are using the latest, 0723 firmware, please also include the bar-code number from the disc's packaging. That's the collection of digits under the bar code, including the tiny digits at each end. This will enable OPPO to determine precisely which version of this disc you are trying to play -- as movies these days are often sold in many different versions even though the packaging might look identical.
Also tell them how you are cabled for both audio and video. And if you are using HDMI audio, tell them whether the problem exists with LPCM output, with Bitstream output, or with both choices.
If OPPO already has history on this disc, they'll let you know what's going on. If not, there are several things they may suggest such as re-installing the firmware or doing a reset of the player.
--Bob
