AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-93 Owner's Thread
Official OPPO BDP-93 Owner's Thread - Page 811
post #24301 of 25204
Has anyone found out why passing 1080/24p signals through the Marvell chip causes an intermittent error?
post #24302 of 25204
No one else is really experiencing your issue or is prone to seeing a single dropped frame during a standard movie viewing, so there is no further hypothesis for your errors.
post #24303 of 25204
Agreed. I have never seen what he is describing. I'm writing it of as a non-issue.
post #24304 of 25204
It won't happen in Source Direct mode, just so you all know.
post #24305 of 25204
Not using Source Direct and still don't see it. Not saying you don't, but in my setup (Oppo 93, Anthem MRX, Panasonic 65VT50) it's just not happening whether I go direct HDMI to my display or through the receiver.
post #24306 of 25204
I guess now that I caught it, I look for it.
If you aren't looking for it obsessively, you won't see it.
post #24307 of 25204
post #24308 of 25204
but it really is there, I guess that nobody cares though…
post #24309 of 25204
I'm super picky. It just doesn't happen in my system.
post #24310 of 25204
I see the same intermittent frame skip issue as Fanboyz has been describing. He's not imagining it. Unfortunately, I don't have a lot of time to diagnose and experiment. I think he may be right about source direct fixing the problem, but I haven't spent enough time with it to confirm.
post #24311 of 25204
Had it occurred on my system I would have definitely seen this anomally as I'm quite sensitive to randomness.biggrin.gif
post #24312 of 25204
But it doesn't do it on source direct, proving it's not my other gear or an HDMI thing.
And two different 93s exhibit the same issue. That means everyone is affected.
post #24313 of 25204
It's a curiosity for sure. But 2 93's is not statistically significant. I'll keep reading to see what you find out!
post #24314 of 25204
Fanboyz,
Are you actually expecting a different answer this time than the last times you posted this? There is no new information to work with.
--Bob
post #24315 of 25204
sadness.
I'll just keep it in Source direct
4 EVER.
post #24316 of 25204
What's needed is a readily reproducible case.
--Bob
post #24317 of 25204
Source direct fixes it.
I proved it with 3 weeks of testing.
post #24318 of 25204
I just purchased Judge Dredd on blu ray and tried to play it and the player says unknown disc and then no disc. This came in a one disc "Blu Ray+Digital+Ultraviolet" copy with both 2d and 3d all on one disc. Is there something that needs to be done to play it? I don't have the 93 hooked up to internet as it is unavailable in the room it is in but have never had this problem before. The latest firmware is installed and BD-Live is off, secondary audio is on.
post #24319 of 25204
--Bob
You just need to live with a 93 for a while, eventually you may catch it.
You can't induce it, believe me I have tried.
My guess is the recent changes to the Qdeo to make it do DVDs play at 24p and handle 1080i video "better", may thrown the Qdeo out of whack.
Somehow just passing through 1080/24p the Qdeo overwhelms it, even though it doesn't process the signal it certainly has to acknowledge it and repeat it. There is where the culprit lies...
post #24320 of 25204
Have you gone to Oppo with your suspicion about which firmware update might be responsible for what you're seeing? I seem to remember that in certain cases Oppo might downgrade your firmware for you if you had good reason for needing it. Testing for such a glitch might be considered reason enough.
post #24321 of 25204
The 93's cant be downgraded outside of Oppo doing it at their lab.
All that needs to happen is abilyeu needs to report his experience to Oppo, that way it gets more attention on their bug list.
post #24322 of 25204
Just tried Judge Dredd 3D and got a black screen with a green line in the middle. Hope a new firmware will be out soon to correct this.
post #24323 of 25204
Even if it gets more attention you still run into replication. Bob has already stated that a reliable replication is necessary. It may be possible that they can "count the frames" by comparing the number of frames the player has played versus the number of frames on the source, but most of the testing I have seen OPPO do has always been "eyes on." That is, they have to be able to see if in order to do something about it. OPPO can't really create a fix if they are not able to reliably see the error occur, create a fix, then verify that the error has indeed been eradicated with no additional playback anomalies.
Second, your issues do not need to be reported more than once. If OPPO has said they put it on the bug report list, then that is all that is necessary. No additional reporting will make OPPO work harder on the issue. That is now how they operate. OPPO works completely on: how easy it is to reproduce, how likely it is that they can resolve it, how many resources it may take to resolve it, and what is required to resolve it. If the numbers do not add up, or there is something that limits their ability to work on it, then unfortunately it will remain an unresolved bug.
post #24324 of 25204
DREDD 3D - the 93 continues to default (?) to 2D - disc displays correctly on my Panasonic player - first real blu-ray error I've encountered in 12 months
post #24325 of 25204
Welcome to AVSForum.
Does the disc give you a message about not finding a 3D display?
What happens if you set the player to 3D = Forced?
-Bill
post #24326 of 25204
Hi,
To get around this when the menu appears start the movie in 2D first, after the logo comes up press the menu then switch to 3D the movie will start from where you stopped from and play in 3D correctly.
post #24327 of 25204
Originally Posted by KAZUKI67 View Post
Hi,
Thanks will try in a few
post #24328 of 25204
Just an update- I have an Oppo 83 and an old Pioneer Elite 95 and the disc plays in both of those players -- still says "unknown disc " in the 93. Any suggestions?
post #24329 of 25204
The menu comes up - sometimes with both 2D and 3D options - sometimes with only 2D - once it claimed I didn't have 3D enabled equipment. When pushing the 3D start (when available) it shows the film in 2D. The suggesti
on of starting in 2D then going to the menu and re-selecting 3D did work. I am on auto-3D selection at the moment.
post #24330 of 25204
