AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-93 Owner's Thread
Official OPPO BDP-93 Owner's Thread - Page 819
post #24541 of 25200
Originally Posted by comfynumb View Post
My 93 is having a hard time recognizing my esata hard drive. There's only music on it and it seems I have to tuen the HD in and off for it to show up on the Oppo several times. Is there anything I can do to solve this?
eSATA is not hot pluggable. The player should be off, then turn on the HDD, then turn on the player.
post #24542 of 25200
I was reading about it in the book, and it explains it, thanks for wording it so I understand better. Works good now, except it won't play my ripped cd's, only downloaded music, damn always something.
post #24543 of 25200
Originally Posted by jimbotron View Post
So my question - will the BDP-93 allow me to watch the 3D disc in 2D mode (I do not own a 3D TV) with no issues or picture downgrade?
It depends on how the 3D disc is authored: some permit playing the 3D as 2D, some do not (those that do not usually have a separate 2D disc).
Unfortunately the Oppo can not force a 3D disc to play as 2D, if it has been authored to prevent that. The only way you could do it is to rip the 3D disc and remove the prohibition, then play the copy. This is easier with ISO capability on the Oppo, otherwise you generally have to burn a disc. BDMV folders may or may not work with 3D, but it will take up more space than the original 3D disc or ISO.
post #24544 of 25200
It will depend on whether you ripped the CDs in a format the Oppo understands: that includes container, codec inside the container and parameters of the codec, being supported.
post #24545 of 25200
That's what I was just thinking, I just ripped to iTunes with standard settings. I wonder if I can just change the format or if I'll have to rip them again and specify what format I want? And will it change the sound quality?
Ok in my import settings in iTunes it's set to apple lossless encoder. Isn't this the same as their downloads?
Edited by comfynumb - 2/7/13 at 8:58am
post #24546 of 25200
Originally Posted by baniels View Post
I believe eSATA drives are not hot-swappable. Meaning you must plug them in when the Oppo is off. Turn on the drive, then turn on the Oppo. If your drive also has a USB port, that would be an easier route. There is no appreciable difference in performance between the two - not that I've noticed. USB can be plugged in and swapped for another while the Oppo is still on. But if only eSATA, give it a try as I described.
Works perfect like you described, thanks.
post #24547 of 25200
If you have ripped your CD's to ALAC, then you have ripped into a lossless format. You can convert from ALAC to FLAC with zero difference. Some searching should find you some methods.
I don't really know about purchases from iTunes. This page might give you some clues to the type of files your downloaded if you purchased in itunes. This may be treading on off-topic territory (?). It seems you've got the Oppo side of the equation sorted out.
post #24548 of 25200
Yeah I'm good, I'm converting to WAV, thanks everyone for their help!
post #24549 of 25200
Keep in mind that WAV files won't include the metadata like FLAC files will (e.g. album art, song name, artist name, album, etc.). So if having that info displayed on your screen when playing your music, then you might want to consider converting to FLAC instead(plus there is a substantial savings in file size with FLAC compared to WAV).
post #24550 of 25200
Originally Posted by Jacob305 View Post
Originally Posted by htwaits View Post
Is this one of the problems that have been found with the new Total Recall? Our BDP-93 still has it's ISO capability. Last night I played Total Recall from a HD, and had no audio problems. Several times during the movie there were narrow flashes of bright color across the screen. The flashes didn't seem to enhance the movie at all, so I'm wondering it this is a "new" Total Recall glitch.
It's the first strange event we have run into since we stopped updating our 93's firmware.
are you asking about the camera lens flares like in the latest star trek movie? total recall remake has that. there was audio issues with the trueHD where you would get audio drop outs.
Jacob
It must have been lens flares. I haven't seen the latest Star Trek movie. The audio was fine because I always output LPCM. Thanks for the information about Total Recall.
post #24551 of 25200
Ok, I'm going to try some in each format before I put everything I own on in WAV form. Thanks!
post #24552 of 25200
I have more questions about which format to rip and convert my music too. I can't find much in the forums, unless I'm searching in the wrong place. Anyone know where to look?
post #24553 of 25200
sure. no problem.
Jacob
post #24554 of 25200
For the BDP-93, FLAC is the best choice for lossless compression. That assumes you mean to play it from attached storage.
post #24555 of 25200
Ok, I'm going to try some in each format before I put everything I own on in WAV form.!
I really can't stand Apple proprietariness and how it locks you into certain paths: open source wherever possible is my motto.
FLAC will give around 50% lossless compression over wav (and sort of like a zip file for music).
post #24556 of 25200
I wanted to do that, but my music was all in iTunes, so I ended up going with WAV. I know it's a bigger file, but I really liked the sound and honesty I couldn't tell the difference from the original. But just like the post above me states damn apple tries handcuffing you. Unless someone knows a easy way to convert them to FLAC from iTunes. I have NERO 10 and I know I can rip them in FLAC, but I'm unsure how to convert them, and that would be a long process.
post #24557 of 25200
Agreed, I'm getting a little tired of having to bow to them. FLAC just wasn't an option. I have a terabyte external hd so at least space isnt a problem.
Edited by comfynumb - 2/7/13 at 5:56pm
post #24558 of 25200
comfynumb,
Just google it! "Convert alac to flac". You will quickly learn that:
Foobar can do it. It's free.
Dbpoweramp can do it. Trial then pay.
Xrecode can do it. Free with "nag" screen.
post #24559 of 25200
comfynumb,
I'm going to look into it today, thanks.
post #24560 of 25200
HERE is a great site to get you started...
As others have mentioned FLAC is the way to go.
post #24561 of 25200
I use dbpoweramp. It's awesome and would be perfect for converting all those wavs to FLAC.
post #24562 of 25200
Exactly what I was looking for thanks!
post #24563 of 25200
Cool, I'm going to try a couple different ones out today. Thanks.
post #24564 of 25200
Originally Posted by Neuromancer View Post
Unfortunately no. This was added to the BDP-10x series of players but is not supported in the previous generation of players.
ah, ok. Thanks for the reply...
post #24565 of 25200
FLAC is a lossless compression of the source file and so can never be better quality than the source, so is dependent on the source quality.
AFAIK, FLAC is basically a compressed form of wav file, so any conversion from other file types to FLAC probably involves converting that format to wav internally before compressing to FLAC.
Therefore it's perfectly fine to convert your wav files directly to FLAC, but the question is whether the wav file is a lossless representation of the original source. For example, it is possible to rip a CD track to an mp3 file and then convert mp3 to wav, but that wav file will have lower quality than a wav file ripped directly from the CD, because there has been lossy intermediate steps. Thus it is important to know the compression history of the files you are obtaining from iTunes.
post #24566 of 25200
Hi, with all of the conversion from one form to another, it seems like I'm better off picking one way to convert my ripped cd's and leaving it alone.
post #24567 of 25200
Yes. There's every reason to rip to FLAC going forward. But for the case of the files you already ripped to ALAC, it is fine to just convert them without re-ripping. ALAC is just another less-univerally-playable lossless format. You could rip a cd to FLAC and the same CD to ALAC, and then convert them both the WAV. The resulting WAV files would be identical. Converting between the two formats will be the same.
What IanD has said willl apply to the songs your purchased in iTunes. I don't know what format they come in, m4a/AAC? iTunes downloads are not lossless, and converting them to FLAC will probably increase their file size, but yield no benefit other than playability with more hardware/software. If this is still current, then the downloads are 256kbps compressed (lossy) files.
OH - I just reread the 93 FAQ - AAC and m4a are both supported, so no need to mess with the files you've purchased/downloaded in iTunes.
post #24568 of 25200
Yes iTunes downloads are ACC. I'm more concerned with ripping my cd's than the downloads. I also have NERO, which I don't use much, but I can rip them to FLAC in that program. I read that too, my only problem was the cd's I ripped in iTunes the past couple of years showed up in the 93, but wouldn't play them. I think it's called apple lossless. Weird but I had to convert them to play.
post #24569 of 25200
Hi all,
I am a newbie here, please do excuse me if similar has already been asked before.
I have bought BDP-93 for over a year but never had a 3D TV to test out its 3D capability.
I have recently bought a Sony HX850 and have connected BDP-93 to it using HDMI, but I am unable to play 3D content on TV using BDP-93. Here are some things I have tried:
1. I could play 3D media content from SEN
2. I have plugged the same HDMI cable to a PS3 and I could play 3D content using PS3, so seems the HDMI class type is not the issue here
3. I have set the 3D setting in BDP-93 to Auto already; from the TV side, the settings for this HDMI connection is the same as what I used for PS3
Has anyone ever experienced similar problem? I am really out of ideas at the moment, any troubleshooting tip would be welcomed!
post #24570 of 25200
CDs effectively store the songs as wav files on the disc: ripping them to wav or FLAC is lossless and the quality of either will be identical to that which is on the CD.
If iTunes provides songs as AAC (a lossy compression), then they have taken those original wav files from the CD and compressed them, throwing away some quality in the process, which you can never get back. AAC is similar to mp3 in this respect. Converting AAC or mp3 to wav or FLAC will never equal the quality of the original wav files on the CD and is sort of pointless, unless AAC or mp3 is not supported in the player and wav or FLAC is.
Apple also has their own version of FLAC called ALAC. It is possible to convert between wav, FLAC and ALAC without any loss of quality.
The problem with downloading any file is that you never know whether any filtering was performed on the original wav files from the CD before it was output to FLAC, ALAC, wav, etc. Although improbable and pointless, it is technically possible to rip a CD to mp3, convert the mp3 to wav and then convert the wav to ALAC or FLAC: although the output format is lossless, it does not tell you the quality of the data inside it, only that it reproduces that quality without further loss. Just as Bluray is a technically high quality format, it doesn't stop the studios from issuing a crap encode in that format, compared to the original film frames.
I guess the Oppo 93 does not support ALAC, so for playability you could convert them to wav or FLAC without additional quality loss.
