AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-93 Owner's Thread
Official OPPO BDP-93 Owner's Thread - Page 853
post #25561 of 26595
Originally Posted by merkman View Post
Finally figured out my problem. Turned off ALL my computers, installed the latest firmware on my router, factory reset the router, and setup everything from scratch, plugging one network cable in at a time till I found the problem.
PLEASE NOTE!!! The HDHomeRun Prime and an Oppo BDP-93 can NOT be plugged into the same switch, in the same room. If they are, the Oppo will "pause" for 3-5 seconds, EVERY 30 SECONDS.
My fix was to move the HDHomeRun Prime into the FRONT room. I have MOCA adapters in the Home Theater Room, and Front Room, so it is able to get a steady 35Mbps, and operates just fine. I haven't tested watching TV again yet, but the Oppo is running fine with networking enabled and the cable plugged in... and that was NOT the case a 1/2 hour ago.
Hope this might help others... cause it was AWEFUL to troubleshoot!!!
Sounds like some kind of handshake being conducted by the HDHomeRun, which stamps its feet in frustration all over the switch if it doesn't get an answer.
At least it wasn't boiling away Earth's oceans, trying to get an answer from a humpback whale!
Edited by Philnick - 9/7/13 at 6:27pm
post #25562 of 26595
Sounds more like an issue with the switch.
post #25563 of 26595
Originally Posted by Philnick View Post
I converted 32 Megabyes to Megabits (by multiplying by 8) and got 256. Divided by the 3600 seconds in an hour, it comes out to 0.0711 Mbps, which is less than 0.1 Mbps, as you say.
It works out to about 72.8 Kbps, which is pretty poor, considering that 96 Kbps is the practical minimum for carrying 20-20Khz stereo.
96 Kbps is the sweet-spot for mobile streaming over cellphones - below that you're limited to a top audio frequency of about 10Khz, above that you run into frequent needs to reconnect and rebuffer as you move around.
You'd only need to boost the 72.8 Kbps bit rate by about a third to get to 96 Kbps. At ten times - which I doubt is used by any streaming service - you'd be up to 728 Kbps, competing with Dolby Digital, which used the stream to carry six channels.
It's more likely that the premium service runs in the 128 to 384 Kbps range.
That's right, I didn't say the Premium runs at 10 times, I said EVEN if it does the bandwidth should still be enough on any internet connection. I actually got this 32 MBps from another poster but I did the test myself using an Iphone 5 and my 24 Mbps connection and it's pretty close. Your guess about the Premium is probably correct.
post #25564 of 26595
Jeez! Whaddya gotta do to get a laugh around here? Hijack a Klingon Bird of Prey and land it in a park in San Francisco?
"I didn't see that - and neither did you!"
post #25565 of 26595
Here you go Phil LOL!!!
Edited by comfynumb - 9/8/13 at 11:43am
post #25566 of 26595
You can always make a lower fidelity signal louder, but that doesn't make it higher fidelity.
However, since Pandora is a streaming service, it's not likely to be available in a lossless format even to the 93 - but it may have different bit rates (and thus fidelity levels) available. It may be that the iPhone app can switch between different quality levels appropriate to running on wifi or using your cellular data plan - I assume that the app built into the 93 doesn't downshift quite as far, since it's going to be running either on wifi or ethernet!
If it makes any difference, I have Pandora on my Elite receiver, my DirecTv Genie, and the Oppo 93, and it's easy to tell the Oppo's sound is better. Also, the application just looks better, and it keeps track of played songs. It's the best Pandora app I've used so far!
post #25567 of 26595
Not sure what I'm doing wrong here...bit of a long story though.
I've had a 2TB HDD loaded with music and movies attached to my BDP93 via eSATA for a couple of years now. Recently after a power outage the HDD was fried.
I've replaced the HDD, connected to PC and had it recognised in System settings, it's NTFS formatted, named it Dad's Music, created three folders and loaded it up with movies and music.
I can see the HDD fine on my PC (via USB) but it doesn't come up on the Oppo, either via eSATA nor either of the USB inputs. Shows in Win8 file explorer as 260GB free of 1.8TB.
I've successfully used a 32GB USB stick in the front USB.
Anybody know what I'm doing wrong, I'm sure it's something really simple biggrin.gif
Cheers
blairy
Edited by blairy - 9/9/13 at 2:09am
post #25568 of 26595
I've replaced the HDD, formatted it, named it Dad's Music, created three folders and loaded it up.
Cheers
blairy
When you check on the properties of the HDD in Win8, what does it show for the drive format?
post #25569 of 26595
Not sure what format is? File system is NTFS, when I go into hardware and properties I can't get any details to populate for volumes.
Blairy
post #25570 of 26595
Blairy
We're wondering about the partition tables on the new drive. The -93 supports the older MBR method but not the newer GPT. See the FAQ: What partition tables are supported on attached hard drives?
-Bill
post #25571 of 26595
THanks Bill, I'm trying to figure that out myself:rolleyes:
Model is Seagate ST2000DM001 Barracuda 2TB; I'd presumed as it was (only) 2TB it would be MBR. Will have to look into this. For some reason I can't figure it out via porperties in Win8.
blairy
And after some checking on the web, not much luck...back in to device properties of the HDD in win 8.
Right click on the HDD in file explorer, select hardware tab, select the drive from list, click properties, select details tab. This lists a huge number of properties in a drop down list. One of these is Device class GUID which I'm figuring mean I have a GPT drive and not an MBR...bother.
I'm guessing this can't be reformatted as it's a firmware issue?
Cheers
blairy
Edited by blairy - 9/9/13 at 5:13am
post #25572 of 26595
blairy
I think I've got a Seagate 2TB that was partitioned GPT...
-Bill
post #25573 of 26595
TO check whether its GPT or not while its hooked up to your PC.
Start
Run
cmd and click OK
In the resulting command prompt, type the following in order:
diskpart
list disk
It will bring up a space-delimited list of your hard drives currently connected.
Find the 2TB in there and see if there is an asterisk under the GPT column.
Alternately, instead of diskpart in the above command list, you can also try diskmgmt.msc and press Enter
This will bring you the Disk Management GUI which will list all your drives.
On the bottom where it shows you the blue ribbons with your partitions, If you right-click the square on the left that has the Drive # listing for the drive you want to check, if you see an option saying Convert to GPT disk in the sub-menu, that means the drive is formatted as MBR.
Actually, if you can move/copy the data off of it, you can reformat it as MBR very easily.
AFTER you have moved/copied the data off, run the diskpart command as above and do the following commands in sequence at the diskpart menu to put the drive back in factory condition.
list disk
look for the disk number of the disk you want to work with [referenced as # in the next command] and be very careful to make sure you have the right disk
select disk #
clean
exit
This will completely put the drive back into factory mode and from here you can use diskmgmt.msc and the following commands:
Right-click the square that has the Disk you want to work with and select Initialize disk
Select MBR
Once initialized, right-click the space to the right of the square and select Create Partition and select all the defaults up to the Finish prompt and you are done and you can move your data back on to it.
post #25574 of 26595
Thanks nikonf5. Confirmed it's a GPT. Currently moving data off drive and will follow the next steps once done.
Cheers
blairy
post #25575 of 26595
Took some HD video with my Sony camera creates .mts files tried them on my Popcorn Hour with latest firmware got video no audio. Tried them on Oppo via USB hard drive worked perfectly. smile.gif
Edited by WynsWrld98 - 9/10/13 at 8:59pm
post #25576 of 26595
What a great tuto Nikonf5. It could be helpful, one of these days. Thanks a lot.
post #25577 of 26595
Fine for years, now... audio dropouts!
Hi all,
I have a 93 which is giving me dropouts every now and then... the first time I noticed it was while listening the flac files from my NAS, BUT now that I have played a DVD, it's doing it then too!
Whoa, that's weird! Never done that before...
Anyone have this issue? My player has been rock solid for years with all discs and streaming audio and video... now this!!!
Help?
Phil
post #25578 of 26595
Hi guys, I've been searching around this afternoon for an answer to one question. What firmware version on the BDP-93 removed SACD-R support? I'm trying to track down a used one...thanks!
post #25579 of 26595
There is no firmware on the BDP-93 which disables SACD-R. This applies only to the BDP-10x series since they now legitimately support DSD media on attached and network storage.
post #25580 of 26595
Try an alternative HDMI cable as the one you are using may be defective or not seated properly int he player or your receiving equipment.
post #25581 of 26595
Got it..thank you!!
post #25582 of 26595
Help with 3D MKV Subtitles with OPPO BDP-93
Hi,
I´m looking for some guidance regarding the OPPO BDP-93.
I´ve several 3D MKV files... but I need to add subtitles... and this is something I can´t do it right.
No matter if the subtitle is .ASS or .SSA the subtitle is shown half in the right side of the picture, and the other half, in the left side of the same picture... and in the center is nothing...
The subtitles are converted to 3D, if I play these files on mi iMAC... I can see the double subtitle... but in the OPPO only one in the center, when the 3D is activated... It splits... frown.gif
I´d tried all what was at my hand, read tons of tutorials... but nothing that I can do to make it work with the OPPO BDP-93...
I´m streaming from my iMAC to the OPPO using PS3 Media Server or Universal Media Server... the only problems are with 3D MKV...
Also I copy these files to an USB drive... the same
If it helps, it have the latest firmware installed.
Thanks in advance
post #25583 of 26595
Unfortunately this is a limitation of the player. The player will not split the subtitles, so the subtitles will always be displayed in the middle. So when you do a 3D conversion, the subtitles will be mixed.
post #25584 of 26595
Hi Neuromancer,
Thanks a lot for your response.
There´s no way to make this work? Maybe embedding the subtitle with the video? Or so...
And why in a 3D Bluray I can see the subtitles as it should be?
Nothing at all? Can´t believe this...
post #25585 of 26595
If you embedded the subtitles into the stream, you would need to make sure they are embedded split (ie. duplicate the subtitles horizontally or vertically) otherwise you will run into the same issues. The subtitles are mixed prior to the video processing, which is why the subtitles display incorrectly when converting to 3D.
post #25586 of 26595
I have an issue with my region free 93... I have never had an issue playing ANY region disk until today. I tried to play 2 different french region B discs and could not(one was actually region ABC).
I get an error message stating the TV resolution can not play the disk, please change the resolution.
I tried several different settings but could not play the disk... HOWEVER, I do get sound. is this a PAL issue or something else I am missing?
thanks
Michael
post #25587 of 26595
thanks
Michael
It might be a frame rate issue.
What is your output resolution set at? What do you have TV System set at?
If the disc has 50hz content and you are using Source Direct and your TV does not accept 50hz, many displays will say "Unsupported Mode" or something similar.
Same if you are using 1080p and have TV System set to Auto or PAL.
The solution is to use 1080p with TV System set to NTSC.
If that is not it, please post the exact message you are getting, along with the video settings on the player.
-Bill
post #25588 of 26595
My physical eject button no longer functions. I must rely on the remote. Funny thing is I never use it much as I mostly watch movies at night & it's too dark to find the button.
post #25589 of 26595
^ OPPO offers inexpensive flat-rate service for players out of warranty.
Even if you don't feel like sending it in, give OPPO a call. They may have some things for you to try.
--Bob
post #25590 of 26595
Have an issue with my non-modified player. Once and a while; when playing from Hard Disc, the movie stops, and the player is bricked. Cannot play, stop or skip, it is dead. i can turn it of though, and everything is back to normal, can just continue the movie, where it left off.
I have the old firmware that plays Iso's, maybe that is the problem, I don't know. But it never did this before, and now it happens from time to time. Not with the same hard disc. Another annoying thing is the fact that, when I stop a movie, next day, I cannot resume it, when it is read from a folder and not a disc.
