Looks like the beginning part of my reply got truncated.
I ordered the 93 on Monday, picked it up on Tuesday. Thnak you Oppo for making the process easy for at least those of us in the Bay Area for the pre-release.
Initial experience is very positive. I currently have the wdtv live for network files and a LG BD-370 for blu-ray and standard DVDs. Setup was very intuitive and easy, I dont think the majority will have any problems at all. I think the netflix and blockbuster should be offered as optional setup as part of the setup and not as separate steps.
However I am having problems playing some files over the network from a Dlink DNS-323 NAS. m2ts files play fine but wmv, mkv etc do not play at all. I copied the same file to a thumb-drive and that played fine. I have filed a bug report with Oppo. No problems playing the same files thu the wdtv live.
The setup menu does not remember the screen you were last at. It would be good to be able to do that instead of traversing the tree again.
The YCbCr 4:2:2 seems to have a problem, picture turns green with my lumagen set to 4:2:2. However if i set it to 4:4:4 it looks ok again. setting 4:4:4 on both devices works fine. The oppo may not be outputting 4:2:2. I only have this problem with HDMI-1, HDMI-2 works fine
The noise reduction feature is getting a lot of attention and more people will be watching online content, the ability to change the NR would be good. Currently I have to go thru the menu tree to do this.
