AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-93 Owner's Thread
Official OPPO BDP-93 Owner's Thread - Page 3
post #61 of 25191
Is there a link to an online manual for the 93 that beta testers and new owners can access?
There is no link yet on the Oppo 93 webpage. Just wondering if the beta testers have access to a pdf manual, or is the only manual available the printed copy you receive with your 93?
I've always liked the ability to study the manual before I receive the player. Makes setup quicker and more informed.
Tom
post #62 of 25191
there is only paper version at the moment.
Jacob
post #63 of 25191
Tom
No, the manual is not online yet.
-Bill
post #64 of 25191
Is there any way to know at what quality Netflix is playing ? Any bar gauge ?
post #65 of 25191
Has anyone tried the DLNA features of the 93 regarding HD audio and full bit-rate mkv (20-40GB) files? The 83 would not bitstream any HD audio (TrueHD or DTS_MA) over DLNA.
post #66 of 25191
Does the 93 recognise the Cinavia watermark that's now showing up on new Blu-Rays?
I prefer to back up my discs into MKVs when I first get them, knowing that they'll get a good amount of play. This protects the discs from family and neihbors.
If the 93 recognises this new protection, it will pretty much kill my ability to keep the originals safe.
post #67 of 25191
Originally Posted by Jacob305 View Post
its reads the what you are playing with the truehd etc 2 channel. on the oppo 83 all the info was together in one display.
Jacob
Cool !
If anyone can post some more pics of the 93 (in action), they are most welcome ! Here in Europe we still have to wait some time...
post #68 of 25191
Originally Posted by HDTV1080P24 View Post
Sending feedback and comments directly to OPPO Digital Inc is important to make the OPPO BDP-93 firmware better
All OPPO BDP-93 owners that have the BETA firmware (pre-release firmware) installed don’t forget to email OPPO digital regarding any bugs you find or features you would like added in future firmware releases.
For example the discontinued OPPO BDP-83 has a 24fps DVD feature in the menu that the OPPO BDP-93 lacks. Perhaps if OPPO Digital Inc gets enough emails they may decide to add the 24fps DVD feature to the OPPO BDP-93 with a future firmware update.
The following is a quote from OPPO Digital
When you receive your BDP-93, please send any feedback and comments directly to BDP-93@oppodigital.com - your input can help shape the BDP-93's firmware further.”
HDTV1080P24,
Not sure if you realize it and hate to be a nitpicker, but please change your post TEXT COLOR to the standard AVS yellow! Black text on a dark background seems tough to read!... Unless of course you choose either the AVSForum.com Default or AVS Mobile setting!
post #69 of 25191
Will the 93 allow me to get rid of my scaler by having the ability to zoom 2:35 to 1:85 to fit my plasma screen? Also will it play 3D better than the other players currently out? I'm trying to justify buying this, so any help would be appreciated.
post #70 of 25191
Just spoke with my supplier, he thinks that the 3D might not work with the Sony VPL-VW90ES that I will be getting with this, because of compatibility issues. Anyone tried the 3D on Sony?
post #71 of 25191
posts deleted
We respectfully ask that you limit posts to technical issues or you may be asked to leave the thread
post #72 of 25191
I picked up my BDP-93 on 11/19/10. So far, I have only one issue with the firmware.
A couple of times, I have closed the empty drawer and the display remained at CLOSE, not getting as far as LOADING.
It doesn't always happen and I'm not sure how to reliably reproduce it.
Has anyone else seen this?
post #73 of 25191
None. Netflix determines what type displays and such are loaded into the player. Oppo has no control over it.
post #74 of 25191
Could be an issue with the loader, contact Oppo if it persists. Of course it might be a result of the type of disc you are putting into it. But you should get either a "loading" message or a "no disc" message.
post #75 of 25191
Jacob
Can you please post some pictures of the front plate of the player in action? With a disc? Also, the set-up menu? Thanks much!
post #76 of 25191
Like the previous OPPO BR players, it has both vertical stretch and full screen zoom modes that do what you want. However, none of the zoom modes currently work with Blu-ray discs that have java. We hope this will be added in future firmware, but there is no promise that it will be.
-Bill
post #77 of 25191
the setup menu is more or less the same as the oppo 83.
I dont have a good camera for pictures.
Jacob
post #78 of 25191
Is the remote identical to the 83? Can I use the 83 to program my Harmony ? Thanks.
post #79 of 25191
Yes.
-Bill
post #80 of 25191
New to the Oppo. Currently have a Harmony One remote controlling my system. Will I find the 83/93 in the Harmony database? I know I should post in another more appropriate forum but I figure someone here has the experience to answer my question. Thanks.
post #81 of 25191
-83 is there. -93 uses the same codes.
-Bill
post #82 of 25191
Yes, I have been doing this with my Harmony 880 since I received and installed the BDP-93 on friday. Works flawlessly and the range is actually better than with the original remote.
Another question - how do I exit the 'Home' menu without either power off or open/close to load a disc? Pressing the Return doesn't do anything.
Netflix streaming has also been flawless so far. I am using a wired ethernet connection. The invocation was fairly intuitive and appreciated by the Mrs, with one glitch resulting in an inadvertent exit to the Oppo standy screen - will try to reproduce the exact sequence tonight. Just wish Netflix would expand the selection of titles available for instant streaming, and provide 5.1
Very hard to locate the buttons on the front panel...does look nice though.
post #83 of 25191
Has anyone gotten the IR port to work on the back? It worked fine on my 83, but not with the 93. Not sure if it's a FW bug or a compatibility issue with my IR repeater setup.
post #84 of 25191
any other questions? feel free to ask.
Jacob
Hi Jacob or any other Owner of the BDP-93,
Can you tell me if there is Internet Radio streaming available from non-subscription based stations like Shoutcast, RadioTime or RadioBox?
post #85 of 25191
Hasn't the cable been changed between the two models?
-Bill
post #86 of 25191
-Bill
Not that I'm aware of. A 1/8" mono cable still fits the 93 but it doesn't react to IR at all, not even through the front sensor when it's plugged in.
post #87 of 25191
don't forget the IR jack on the back of the OPPO is 3 wire: it puts out +5 VDC on the tip (I assume this applies to the -93 as well but have not received my unit)
OPPO has adapter cables to go to a standard 2 wire plug to connect to an IR block: or make your own using sleeve and ground: no connection to tip
post #88 of 25191
I believe that is changed on the -93.
-Bill
post #89 of 25191
sorry if this is in the wrong place. Will their be a place to talk about the upcomming 95 and what great audiophile features it will have?
post #90 of 25191
The IR jacks on the -93 are different than the -83. The -83 has a 3-wire with a hot tip and requires a "stereo to mono" adapter cable to interface with most IR distributions systems. The -93 has a standard mono jack with no power and does not need the adapter cable.
The -93's front sensor is disabled when you use the jack, the -83's is not.
