AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-93 Owner's Thread
Official OPPO BDP-93 Owner's Thread - Page 26
post #751 of 25267
Originally Posted by adminglf View Post
hi all! Received my new -93 yesterday ;-))) Love the look of the new unit! This is my first Oppo, so anticipating great things! ;-)
Couple of issues found (as expected ;-)...I will be calling Oppo tomorrow (I doubt they are in on Sunday's ;-)
Findings...so far... ;-)
Network - I started with a wired connect using DHCP. No luck. Then tried wireless using WPA Personal (I'm using an old Linksys router)...still no luck. Went back to wired and used Manual setup to enter the IP info. This worked just fine.
SACD - I find that I'm not able to send DSD over HDMI to my Integra DHC-80.2...no output. Works fine using the PCM setting. The Integra is also fairly new, so I'm not sure whether the problem is with the 93 or my 80.2. Anyone else having similar results?
'My Network' - per the manual (page 43), this is an 'experimental feature' and is unsupported. My Integra has similar functionality (playback from servers) so thought I would compare. When drilling down through my server folders, each level was very sluggish to respond (longer than i would have thought), but worked till i got to the 5th directory level, then it just hung up (though i do have a large quantity of folders (900+) at that level, so they may not have enough memory allocated to support this.
CD playback - it seems to me that when advancing/backing up from track to track that the tracks don't start at the beginning (the time counter indicates 00:00, but the music track has already begun). Anyone else notice this?
Remote Controller - I'm not impressed with the new controller...sorry ;-). My -93 is in a built-in shelf unit with a glass front, and is positioned within the rack up near the top...I have to hold the remote up fairly high from my seated position to get the -93 to respond. Note that I don't have this problem with my Harmony One (and yes, the Oppo -83 IR codes work great ;-). Also, it seems that you have to push/hold the buttons down fairly hard to get a response...I'm just use to soft buttons i guess ;-)
Over all picture/sound is awesome! Can't wait to get the 'bugs' worked out ;-)
Glen
Same problem here SACD only work with the PCM no DSD. My 83 works with DSD. I am using a RXV863 Yamaha receiver and the HDMI1 on the OPPO.
post #752 of 25267
I have audio truncation at the beginning of a CD or DVD. If I jump from track to track on a CD, the start of the track is truncated. Oppo support suggested this is a handshake issue and they are working on it.
93 -- HDMI1 --> Denon AVR-4308CI
post #753 of 25267
can someone post how I should have my settings on the 93? I will be using hdmi 1 to the projector which is 3D and hdmi 2 to my Dennon 4308ci avr which is not 3D. I need to know all the other settings please. Thank you in advance.
post #754 of 25267
Speed Report
As I did with the BD85 when I got it. These numbers will be vs the 85, to the menu, skipping trailers with next button:
Time from OFF to tray open, by pressing open button when unit is off:
BD85--3
BDP93--4.5
Time to get to where you can select PLAY in final menu, starting with tray open:
Transformers
BD85--75
BDP93--64
2012
BD85--114
BDP93--77
Iron Man
BD85--87
BDP93--53
VERY good speed IMO.
post #755 of 25267
I have posted this question to Oppo but wanted to double check here.
I notice that when I turn the unit off the wireless connection is not active when I turn it back on. I have let it sit for 5 minutes but still no go. I have to go down to the the wireless setting to obtain an IP address.
Do I need to wait ever longer for this to turn on or did I miss a setting?
post #756 of 25267
The manual has recommended settings for different configurations. If it is inadequate let us know in what way and we'll go from there.
-Bill
post #757 of 25267
To those of you with a pre/pro, here is some food for thought.
When running HDMI1 to the pre/pro, and HDMI2 to the Denon AVR, there was a slight lip sync issue. When all is run thru the pre/pro, it is fine. I imagine going with 1 to the display, and 2 to the AVR, things would be fine, but the pre/pro processing is delaying the video I imagine. So, if you do not have some sort of audio delay in the AVR, you may have issues like I have. I just changed and ran audio and video thru the pre/pro, because I know it works to get them in sync.
This sync problem is not the problem Oppo knows about and is working on, because it's and issue with my chain.
post #758 of 25267
Can you try HDMI 2? That was my workaround and it seems to work perfectly.
Brian
post #759 of 25267
I note that when playing a DVD via Component video, there is a brief stutter when the image first appears on screen, and then the entire image is shifted to the right. There is also a vertical black bar down the left side of the image. I suspect that what I am seeing is the image is shifted to the right and wrapped back around to the left side.
I note however, that I can resolve the issue by manually changing the max screen resolution in the Oppo from the default 1080i to 480p, and back to 1080i. I am aware that pretty much all commercial DVD's can not be upscaled to 1080i, but there does seem to be something that happens when the 93 detects a DVD and tries to switch down to 480p.
I have had Hi-def 1080i players connected to me systems for many years, so I am reasonable certain that whatever is going is is unique to the 93.
I passed that along to Oppo just a moment ago.
Brian
post #760 of 25267
Brian
I test component but don't use it daily. I have seen oddities over the years but not what you are seeing on the -93.
You have Primary Output set to Analog?
-Bill
post #761 of 25267
This was addressed somewhat in gsr and rwinner's posts several pages back (maybe 4 hours ago ) but I'm still not clear. When playing a DVD-A and SACD and setting the Oppo to use the FL / FR analogs as stereo outputs, will any down-rez'ing take place in the digital to analog conversion in the 93?
post #762 of 25267
Originally Posted by Neuromancer View Post
Most BD can't be zoomed yet because of BD-JAVA prohibitions. OPPO still has not offloaded the zoom controls to the Marvell Qdeo. This is planned in another firmware release.
I am confused on this statement since I have read of 83 owners who zoom at their projectors to fill their 2.35 screens being able to use the 1/2x zoom on the Oppo for blu ray menus and extras framed at 1.78 or even 1.78/85 blu ray movies instead of re-zooming the projector for 1.78/85 material.
I just want to be able to do the same thing with the 93.
post #763 of 25267
So say we all.
He was saying is it is not possible on the -93 at the moment. It is done on the -83 and we look forward to it on the -93 with future firmware.
-Bill
post #764 of 25267
-Bill
Yup.
post #765 of 25267
Glad I waited to purchase a 93, I don't believe this is quite ready for prime time yet. 1/2 zoom and subtitle shift are necessary for my planned 2.35:1 conversion, I'll wait until the firmware catches up.
post #766 of 25267
So say we all.
-Bill
Thanks Bill.
post #767 of 25267
Originally Posted by floridapoolboy View Post
1/2 zoom and subtitle shift are necessary for my planned 2.35:1 conversion, .
Same here, but as long as the 93 is doing both of these things properly by the time the 30 day return period is up after release, I will be fine I would have to think both of these issues will be solved by the time there is a official release since these are 2 huge features to this player for many of us.
post #768 of 25267
Try playing it on USB to confirm that it is compatible with the player.
Ensure that the server is not set to do video decoding. Have it send the raw data to the player.
I fired up my other DLNA server, MiniDLNA and it works great. Now I can play every file in my directory! I'll check into Mediatomb's video decoding settings, although, I don't think it was doing any decoding.
post #769 of 25267
Anyone know what manufacturer of the HDMI cables comes with the OPPO?
Just curious if people are using them or something else.
post #770 of 25267
Brian
HDMI2 works perfectly!
When using HDMI1 and changing tracks using track forward or back buttons, I noticed the Input Signal Channel Indicators would turn off/on on the Denon display. When using HDMI2, the indicators remain lit when changing tracks.
I tested with the 83, as well, to verify the indicators remain lit when changing tracks.
Thanks for your suggestion.
post #771 of 25267
Originally Posted by robocox1 View Post
The BDP-93 plays my DVDs,B-R DVDs,CDs very well, but DVD-A do not play continously. The audio is broken up by dead air for a second and then repeats. Has any one experienced this or has a solution?
Nothing with the 3 I just tried (Legion of Boom, Moist (at 96/24) and N.E.R.D.) to my Denon 988. What it bad from the beginning or after you skipped, track change, paused?
post #772 of 25267
There is no "res", analog is analog. When using stereo analog output you should be choosing the stereo track from any SACD or DVD-A. If that's not available, set SACD output to "PCM" and you will get a down-mix of 5.1 to stereo depending on your speaker setup downmix setting.
post #773 of 25267
Sure, people use them. I don't know the manufacturer but they seem similar to the basic Monoprice cable.
See OPPO's comments: Does it come with an HDMI cable?
-Bill
post #774 of 25267
Subtitle shift works now.
-Bill
post #775 of 25267
May sound stupid however, does your HT processor support DSD? Mine doesn't so I set the BDP-93 to do the decoding. Wondering if it senses that your HT processor doesn't decode the DSD?
post #776 of 25267
Originally Posted by PHX HD View Post
So you're able to stream Netflix through the 93 without your AVR shutting down? I'll give that a try tomorrow.
Mine will shut down with no disc and nothing but the screen saver running.
I am able to stream Netflix with no shutdown. I turned off screen saver as suggested by others here but still no luck.
post #777 of 25267
Do you use a subwoofer ? Almost all cases reported about Pioneer receivers shutting off has to do with speakers overloading. I don't know what can be causing this but I would do some tests changing the impedance settings on the receiver and switching phase control on and off.
The reason why I am insisting with this advice is because I use Pioneer receivers for more than 25 years and had shut off problems before. I had a direct contact with Pioneer engineers and they suggested I should try unplugging the speakers one by one to see what could be causing the overloading. In my case, it was a 4 Ohms pair of speaker , clearly not recommended on the manual. Speakers rated below 6 Ohms don't work well with the Pioneer receivers, as explained in the user manual.
I know you had everything working fine before but perhaps some feature/setting on the 93 is causing an overloading on some speaker/non-powered subwoofer.
post #778 of 25267
I use an external amp to power my speakers, so that kind of rules out that option.
post #779 of 25267
I was able to get internet connection with ethernet, but no luck getting it to see and connect with my wireless belkin router. Funny, cause I had no issues with my LG player... My belkin is WPA/WPA2 so exactly which option should I be choosing since none are the exact same?
post #780 of 25267
Is it finding it in a scan? Whats the error?
