AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Which sub is better-bet you can't tell:)
post #1 of 9
Mirage Omni S8 or Mirage LF 100 and last Carver Knight Shadow?
post #2 of 9
Which ever one sounds better to you.
post #3 of 9
None.
post #4 of 9
The Carver should be the best of the three. It should be at 2 1/2 times the price too. are you limited on size? There really is not substitute for size when it comes to subs. It's extremely difficult, if not impossible for any of those mini-subs to outdo their larger brethren. Don't get me wrong, they are nice. Just not what I would call great.
post #5 of 9
well...ok
obviously you've heard all three...
which one is it already...?
post #6 of 9
Originally Posted by lefthandluke View Post
well...ok
No. Just have had some of each of those company's products. I've always had good experiences with Carver products.
post #7 of 9
well...ok
sorry...i was directing that question to the OP
post #8 of 9
I vote for the Mirage S8. I haven't heard the Carver, but it seems like a trick question so i'll rule it out.
The LF series from Mirage could have port noise at high volumes I believe, so the S8 is my vote.
post #9 of 9
You are absolutely right, I can't tell (you any more than your first post about the Carver Knight Shadow).
On paper the Carver is the best of the 3 but if they still have a fixed $425 fix policy, I would pass on Carver/Sunfire.
