Hi,
In my current set up I have all my AV Equipment in a stairs cupboard and the TVs distributed in the various rooms. I currently have IR from the remotes over CAT6 into the cupboard. However I now need to transmit an IR signal from a HTPC in the cupboard back to the rooms.
The device that emits the IR signal uses a low power IR emitter (USB UIRT 3.5mm emitter). I am again going to use CAT 6 to extend the emitter, however I need the signal at the room to blast like a normal remote to control all TV and other room equipment.
Is there any way to amplify the IR signal and convert to a blaster type? Ideally I would like the solution to be wireless.
Thanks for any advice,
Gary
Gary
