AVS › AVS Forum › Audio › Speakers › Logitech z-5500 -> SLS QLine Gold or Fluance SXHTB+
post #1 of 9
So my beloved z-5500s broke after 5 years of use. Got them on sale for $250; best investment of my life. I regularly throw large parties and the huge sub on them really is really crunchy and my friends love it. I have ~12ft ceilings in a very large living room (400sqft i think). Often my DJ friends will connect CDJs or Computers running traktor to my speakers and DJ my partys.
All that being said I need new speakers and I'm looking to upgrade. I have a little money but I would like to spend about $500 if I can get a better system than the 5500s for that. If not I can spend <$1000 for a truly kick ass system. Bass is very important as we all listen to house/electro music mostly. I also plan to watch movies streaming from my xbox 360 and play some call of duty.
So far I've narrowed it down to:
SLS Q-Line Gold -> $330 + Replacemetn 12'' sub b/c the 8'' included looks lacking (about $250?) = $600?
or
Fluance SXHTB+ 5.0 -> $300 + Subwoofer??($250?) + AV Reciever?? ($250?) = $800??
My questions are:
1a) Would the SLS set up be better than my z-5500s?
1b) Would the SLS be better than the z-5500s if I added a sub?
2a) Would the Fluance set up be better than the SLS + sub set up?
2b) Would the Fluance set up be ALOT better than the z-5500s?
3) Which subwoofer could match the z-5500s for the best value?
4) Which receiver should I get if I go with the Fluance system? (Must have HDMI in, Optical in, Good sound quality, dont really care about intense video because my HDTV is a 52' 720p LG plasma)
Thank you in advance for your quick responses. As soon as I hear from you knowledgeable folk I'm placing an order and setting them up for a party not this saturday but the one after that.
-PittedPanda
post #2 of 9
I used to own the SLS system and was very happy with them. However, their strength is not in playing bass heavy music at high volumes. They tend to get a bit sloppy at high volumes. While I have not heard the Fluance system I have to imagine that for your purposes the extra driver area of this set would suit you much better.
As for the subwoofer, I am not too familiar with them. You should try searching the subwoofer forum, they regularly have threads asking for the best sub under about $300. You could find similar threads about sub $300 receivers in the electronics forum.
post #3 of 9
Thanks Eric!
So far this is what I've found to be my best bet:
*Fluance SXHTB+ 5 Speaker Surround Sound Home Theater System
(Center and surround speakers are up to 100W; front two towers are 160W)
$300
*BIC F12 (150RMS vs 188RMS on my old z5500 sub; will it outperform???!!)
$220
*Onkyo TX-SR608 (Will the 100W be enough to fully utilize the 160w on the front tower speakers or should I get a AVR with 160w output?)(I'm finding the AVR selection to be VERY confusing...can anyone advise me as to my best option??)
$350
Total = about $900
If the bass is louder, deeper, and heavier with this set up then my z5500 I'm going to go order it.
Anyone know?
post #4 of 9
Originally Posted by PittedPanda View Post
Thanks Eric!
$300
$220
$350
Total = about $900
Anyone know?
Excluding tax, shipping, cables, etc? No preference for bookshelf or tower speakers? Do you have to have 5.1?
My initial advice would be to buy the Z5500 again for $400. Or another 5.1 system that fits your budget. I'm surprised the computer system was any good for parties, but then again I haven't heard them, don't know what type of party it was, what sounds good to you and your friends, how loud you played them, etc.
Anyway no way you can get a quality receiver, subwoofer, and 5 speakers separately for $900.
I was thinking if you settle for 2.1 or 3.1, then you could get a HSU VTF-1 for 379 (BF sale), a Denon 391 receiver for $189, and a pair of entry lvl Aperion Audio bookshelf speakers for $260. Or those recent pioneer towers and a center for $289.
Edit: Oh btw there's some HSU bookshelves for $129. You could pick up several of those, then downgrade the subwoofer to STF-1.
post #5 of 9
Do NOT buy the Z5500 for anything over $250. You can buy it here today for $200. I got my set for $150 years ago. I think they are fine PC speakers but think they are very unimpressive HT speakers. But to each his own.
BTW, I hope I never have 'crunchy' sounding speakers.
post #6 of 9
I recommend getting a cheap or used receiver, 3 pairs of B2030ps, and an entry level eD or HSU sub. Won't be under your $500 mark, but it'll come in under 1k.
post #7 of 9
Did you get a chance to look into the new Pioneer speakers? If you live near a store that carry them, head out there and see if it fits your taste. Here is a long thread about them:
http://www.avsforum.com/avs-vb/showthread.php?t=1278774
Check some of the refurbished stores such as accessories4less or ebay store and find a nicely discounted refurbished receiver. Hit the subwoofer forum and check out the subwoofer. The Bic and Lava seems to be a hit now on the entry level subwoofer.
post #8 of 9
I have to disagree with this statement. I think you could certainly get 5.1 with a receiver for $900.
Front Towers (2): Polk Monitor 60s Series II = $229.98
Center: Polk CS2 Series II = $99.99
Surrounds: Polk Monitor 30 Series II Pair = $79.99
Subwoofer: BIC V1220 = $172.74 shipped
Receiver: Onkyo HT-RC260 (same as 608, minus THX cert and VGA) = $319.99
Total = $902.69
So it can be done for your budget.
I can tell you that I was previously using the Z5500s for home theater/music duty, and that Logitech sub couldn't even hold a candle to that BIC, which I bought as a budget sub. I'm feeling low frequency extensions from movies and games that I never even knew were there. So while it might not be able to compare to the Epik Empire or anything SVS has to offer, it works wonders for a budget subwoofer.
post #9 of 9
those pio speakers are $79.99 and J&R right now if your interested.
  Back to Forum: Speakers
