Originally Posted by Movieguru22
I had purchased the 65638 for 1299, but best buy had the 65738 for 1099 so cancelled the order and purchased this. Is there a big difference? Any thoughts. Thanks!!!
Yes, you get advanced picture controls for each source input. This allows you to better dial in the calibration settings for the TV. Also, you get the 12.06 firmware that allows the use of most 3d sources without the need of the converter that you would of had to buy for the 65638.
