AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Recommend a 40 or 42 TV for my 200x200 VESA!?
post #1 of 2
I guess this might sound like an extremely backwards way to purchase a TV but here is how I got here. I finally mounted the 32 TV in our bedroom to the wall. Loved the mount from MonoPrice and now I realize I'd like a larger TV. I don't want to change the mount and the max size I have to work with is 40 or 42
Mostly looking for a good deal, 1080P don't watch sports so 60hz I'm assuming is OK.
If anyone has a TV they are fund of that fits the build please shout
post #2 of 2
I just hung a Samsung 40 inch (630) on that type mount.
Check the specs on weight and verify you mounted into studs and you should be fine.
