goneten,
Not rude at all.
I pointed to that link since it was only 3 pages (I believe). Basically it started with a difference between two mic's and then into the resolution provided by the software.
I believe Bosso's main complaint was Omni did not proved enough data points to accurately graph the information (when none, 1-6th or below smoothing was used). I was trying to discuss with him if running a trace at 1-24th does show the information as would be needed to cover enough data points but do not believe he responded to this. Maybe he will see this and correct me if I am wrong.
On your most basic question on if Omni will work for your needs I guess I could only say you would be best to read the manual and see if it would.
James
Not rude at all.
James
Sorry if I'm coming off as rude, it's not my intention.
