So I received my mic back from PE for the re-cal and was finally able to get some measurements done.
I took reading from 6 different locations. 3 from on the couch (considered back row) and 3 from right in front of it since that is the area I am usually sitting in my chair (considered front row). The area the measurements cover is about 6 wide and 3 deep.
All measurements were taken at -5 MV from the Onkyo 885 with a 1-24th smoothing.
The way I did this was take a measurement from position 1 with only the subs.
Left the mic in that place and then turned on the speaker amp and took a reading for both the speakers and the subs. I did that for all 6 positions measured.
For the speakers only, I just turned off the sub amp and then took the measurements one at time in 6 different locations. Same general position for the mic but not 100% the same as the positions when I did the subs and speaker step.
The three screen shots showing below are (with back row=black, front row=red, blue average of the positions):
1) subs only
2) subs and speakers
3) speakers only (no average in this one)
One suggestion I would like to make in regards to Omni software. When individual frd files are loaded, say I load three and make them all the color red, when a snapshot is taken, it should leave the colors as I selected them. I attempted to get snapshots of these but every time it changed each frd file to its own color and not what I had made them.
James
