Originally Posted by
penngray
If a mic is professionally calibrated then its as good as any other professionally calibrated mic. Definitely as good as anything we will ever need.
To an extent, if the mic is accurate and repeatable across the full spectrum range in which you intend to use it. However the ECM8000 has been shown to be down in dB and has high distortion in the LF/ULF range, and also rises and then falls of steeply in the HF/UHF range. In these cases a cal file can only do so much. I think many want to be able to measure accurately down to 10-15hz, which the ECM capsule lacks the ability to do.
penngray
I would think it all comes calibrated, that is an important part of its selling point. NO one needs to do the startup calibrations.
I think this is a Bill Waslo design too (sorry If I go that wrong), he created Praxis and pretty well is known to make a very accurate product.
Yes, the mics are reported to come with individual cal files. But I question whether the startup calibration/baseline adjustments will still need to be performed considering the software will still need to use the soundcard to send the test tones, and whether they have created an Automated mode. I was just thinking, unless the output is run directly into an amplifier, it will still leave a remaining outside control, the AVR volume. However a quick manual level adjustment there is a lot less than the current pre-amp procedure. Guess we'll have to wait and see.
Thanks for the info on the designer.
EDIT: had to take a call, in the meantime many have already commented and explained further. Thanks Mark for the additional info.
