I just picked up a MartinLogan MLT-2 5.1 Home Theater System and would appreciate some advice in selecting a receiver to run them. The speaker specs are as follows:
MLT-2 SPEAKER (front and rear)
System Frequency Response
110-20,000 Hz ± 2db
Sensitivity
88 dB@2.83 volts/meter
Impedance
8 Ohms compatible
Crossover Frequency
2000Hz
Tweeter Type
1 (2.54 cm) soft dome
Woofer Type
4.5 (11.5 cm) high rigidity poly cone
with extended throw drive assembly
Enclosure Type
Non-resonance asymmetrical
chamber format, sealed
Suitable Amplifier Range
15-100 watts
Power Handling
50 watts
Weight
3.4 lbs. (1.6 kg)
Size*
7-3/4 h x 4-5/8 w x 5-3/4 d
(19.7 h x 11.8 w x 14.6 d cm)
MLT-2 CENTER CHANNEL
130-20,000 Hz ± 2db
Sensitivity
89 dB@2.83 volts/meter
Impedance
8 Ohms Compatible
Crossover Frequency
2300Hz
Tweeter Type
Woofer Type
2 x 3.5 (8.9cm) high rigidity
poly cone with extended throw drive assembly
Enclosure Type
15-100 watts
Power Handling
50 watts
Weight
5 lbs. (2.2 kg)
Size*
4-1/4 h x 12 w x 5-1/2 d
(10.8 h x 30.5 w x 14 d cm)
MLT-2 SUBWOOFER
37-200 Hz ± 3 dB. Anechoic in the LFE mode.
Low Pass Filter Frequencies
50Hz-200Hz
Phase
0°, 180°
Woofer Type
10 (25.4 cm) high-excursion, paper cone with
extended throw driver assembly
Enclosure Type
Bass reflex
Amplifier
120 watts RMS (360 watts peak)
Impedance
Left & Right/LFE RCA - 10,000 Ohms
Inputs
Left & Right/LFE RCA Line Level
Mains Power Draw
Standby: 12W
Idle: 12W
Max: 250W
Weight
32.6 lbs. each (14.8 kg)
Size*
16 h x 11-1/2 w x 15-1/2 d
(40.7 h x 29.2 w x 39.4 d cm)
Other Info:
The system will be used mostly for tv, BluRay movies, and PS3.
I'm trying to stay under $300.
And if you can't tell by now, I'm pretty new with home theater setups.
Thanks for any help.
110-20,000 Hz ± 2db
Sensitivity
Impedance
8 Ohms compatible
Crossover Frequency
2000Hz
Tweeter Type
Woofer Type
Enclosure Type
15-100 watts
Power Handling
50 watts
Weight
3.4 lbs. (1.6 kg)
Size*
130-20,000 Hz ± 2db
Sensitivity
Impedance
8 Ohms Compatible
Crossover Frequency
2300Hz
Tweeter Type
Woofer Type
Enclosure Type
15-100 watts
Power Handling
50 watts
Weight
5 lbs. (2.2 kg)
Size*
MLT-2 SUBWOOFER
50Hz-200Hz
Phase
0°, 180°
Woofer Type
Enclosure Type
Bass reflex
Amplifier
Impedance
Inputs
Mains Power Draw
Standby: 12W
Idle: 12W
Max: 250W
Weight
Size*
Other Info:
