AVS › AVS Forum › Video Components › Home Theater Computers › My HTPC build (w/ pics)
post #1 of 6
After much deliberating and trying to think of that "perfect" shortcut to an htpc, I finally just manned up and built one from scratch with the peripherals that I wanted.
Build details:
Silverstone Lascala Series (sst-lc13b-e) (added 2 silenX 80mm fans)
CM 500w PS
Asus P7H55-M Pro
Intel Core I3 540 3.06ghz
Corsair 4gb 1600mhz DDR3
Liteon BDrom
(4) 1TB 7200rpm seagates
Logitech diNovo
Win7 Pro 64bit
pictures of the build:
http://sincitygoats.com/htpc
(huge pics sorry)
Yes, I'm a wire nazi.
Which software to run is also the next burden. Leaning towards wmc, tmt5, mbrowser. Any more insight? I know this part of the build is merely a preference thing now.
Jon Cain
post #2 of 6
Pictures are huge. Any way that you can shrink them down.
post #3 of 6
I like Windows 7 64 bit.
Shark007 regular + Shark007 64 bit.
Mediabrowser.
All free (except Win7, of course). All work great.
post #4 of 6
John,
Just my 2cents.
I took my extra drives out of my HTPC and moved them to a PC/Server.
I found that the extra drives were generating more heat than the stock case could handle.
post #5 of 6
i did a little testing and with all 4 drives spun up (multi copy/paste across drives for testing) and some other processes running in the back (cpu @ 75%) for 30mins, i recorded a max cpu temp of 98*F and 78*F in the case. is that good?
post #6 of 6
37 C.
That's very good. Nice work.
