T-Bone's Theater build
post #1 of 60
I've been dreaming of doing this for 18 years now and I'm finally on a roll. I've worked in the consumer electronics business for 6 years during my years at college and that was really the start of my desire for a home theater. Well do to kids coming early in my married life, college, busy jobs and real life stuff has prevented me from doing it. 4 years ago I bought DIY speaker kits from GR-Research and they've sat since then. 2 months ago I decided to build them and recently finished them.
We bought a new home a little over a year ago after moving from Utah to California. Unfortunately we weren't able to modify the home since it was a track home and the builder didn't allow for structural modifications. We did buy a house that had a spare room with the intent to turn it into a theater. A few months after moving in we tore the room down and basically did nothing to it for almost a year. Well enough was enough and I'm fired up to get the ball rolling. Here is a terrible sketch of the concept. The equipment rack will be in a different place though.
The plan is to have 8 seats in the room so Berkline 088 narrow sofas will be the seating choice.
Additional sheetrock and Green Glue was done a few months ago. Safe N' Sound solid core door was ordered yesterday. I also ordered some Wilsonart Laminate (DEsigner White) 5'x10' piece today for the screen.
Here are the GR-Research speakers I just completed.
I was off this past week so I was able to work on the stage and riser.
More to come
post #2 of 60
Finished the riser today. Well other than the second layer of OSB after I lay the #30 Roofing felt.
Got some goodies yesterday.
Screen material came in yesterday as well.
Now to figure out the front stage false wall and the equipment rack.
post #3 of 60
Got the screen hung today and started on the front wall Linacoustic. . Kind of a nightmare really but it turned out well. I used contact cement to glue it to pegboard but that posed a problem as the seems showed up. I had to take it down and reinforce the seems with 1/4" plywood that was also glued to the pegboard.
More later.
post #4 of 60
Did you do any sound treatment in your stage and riser ? On your stage, did you put dual 5/8 sheets or a single one?
post #5 of 60
The stage has some sand in it as you can see here
The room is on the second floor and I didn't want to risk too much weight. My friend is an engineer and felt that I would be ok with it completely filled but it was pushing the calculated max load and I didn't want to get into a situation that might be disastrous. Anyway I know it's not optimal but I figure the additional mass won't hurt. There's about 800 pounds of sand in there. The stage is decoupled as well. As for the top layers they are OSB 23/32" I believe and there are 2 layers on there. The stage has green glue between the layers. The rest of the stage was stuffed with standard fiberglass insulation.
The riser is framed with 2x12's with a total height of approx 14" with carpet. Each chamber is stuffed with 2 layers of R-30. 2 sheets of the 23/32" OSB with #30 roofing felt between the layers. Hope that helps.
post #6 of 60
With all the theater build threads out there that are actually well done I'm wondering why I even post to this thread. Maybe someone will benefit from something I've done. I've actually finished a lot in the last few months and I'm really working hard on the room at the moment.
Built 2 15" subs recently. They are MFW-15's with SA-1 amps from www.gr-research.com. They came out great and sound wonderful. It's a sandbox design and they are as solid as a rock. They weigh a modest 162 pounds each.
post #7 of 60
Here is the front stage in progress.
Going to start on the soffit tomorrow.
post #8 of 60
You are right. There are a lot builds out there. Don't be too disappointed if you don't get a ton of feedback. I think a lot of people surf through quickly, look at the pictures to see what you are doing then move on. There are truly some amazing professional builds so difficult to do something better or innovative. Still, great to see what everyone else is doing and have your own work seen too.
I must say that I am very impressed with your speaker builds. Wow! Were the mains, center and surrounds built from kits or did you make the boxes from scratch? The solid wood finish is beautiful. Looking at the detail of your sub...once again wow! The bracing is incredible. Great job and I look forward to seeing your progress. Appreciate the speed you seem to be moving at. Hate following a thread that takes 6 pages before moving beyond the 2X4 & HVAC stage.
post #9 of 60
Thanks for the kind remarks on the speakers and the encouragment on the thread.
I built all 9 speakers from scratch. Everything was in a kit when I received them from GR-Research.com. It was A LOT of work building them but they sound amazing! For the couple of grand I invested in them I'm certain I saved at least $3k or more doing them myself. The pride in building them yourself is where it's really at for me. For me they are works of art and I really enjoy wordworking as I rarely get to do it much with a busy job and 3 kids. It's been something I wanted to do when I finally got around to doing my theater room.
More to come....
post #10 of 60
A couple more questions:
  • What type of veneer did you use on the speakers?
  • Have you had a chance to listen to the setup yet? Do you find the front sound field a bit uneven with the center mounted well above the left and right? Always a tough decision with a non-AT screen. The bass must be amazing with those two 15's.
  • What projector are you using?
  • A wife and 3 kids. My situation as well. How did you convince the family that the time and money spent on the theater was a good thing?
post #11 of 60
Those speakers look fantastic! I'm waiting for my Wilsonart laminate and will also be building a DIY screen. Good to hear about the seam issue when you glued it. I was planning on just attaching to the perimeter of a 1x4 frame (braced). What kind of projector are you going to be using?
post #12 of 60
* What type of veneer did you use on the speakers?
Cherry
* Have you had a chance to listen to the setup yet?
Yes many times. Everything sounds great even without acoustic treatments. My brother came over this past weekend and he has a decent system costing about $800 for his speakers (I know it's not much) and has a $500 amp (again not much) but he wanted to sell everything he has and start building speakers after his experience in my room. hehe
This is a tough one for me. I read a post somewhere from Dennis Erskine stating that the placement of the center channel is better served over the screen since our brains have a harder time localizing sound coming from above. I might try it below the screen to see the difference but for the most part I don't notice its location. It sounds central to me. It will probably help when it's hidden behind all the screens I still need to make. That way I won't see that thing staring down at me.
I wanted to go IB but it just wasn't going to work well in this room or should I say I didn't want my entire neighborhood calling the cops on me daily. I was a little reluctant to do 2 subs as I thought it might be overkill but I'm glad I did. After I got 1 done I tried it out and while it sounded good it really filled out the stage and added another dimension having a second. It also allows me to move them around to optimize them. I think a single is fine especially on a budget but I would try and plan for 2 down the road. You can't really have too much bass in my opinion. Those sub-sonic sounds aren't heard but felt. With this room on the second floor there is no need whatsoever for buttkickers. The tactile response in the room is exceptional.
* What projector are you using?
It's an Optima HD70 I bought years ago. I plan to replace it in the near future but I'm content with it at the moment. I want to move up to a 1080P unit with better contrast soon. I have 100% light control in the room and the blacks just aren't very good.
* A wife and 3 kids. My situation as well. How did you convince the family that the time and money spent on the theater was a good thing?
My wife LOVES movies so it was easy really. Also we bought the house almost exclusively on the fact that there is a bonus room over the garage that was a nice 18'x20' with 9' ceilings that would make a nice HT room. As for the money it really hasn't been all that bad. Looking back on the project I could have done it for $3 grand I bet, maybe less. DIY screens are cheap, used PJ is cheap, speakers can add up but you can get nice used setups cheap. Then all you need is furniture to sit on. I think the money really starts to add up with the construction piece of it. If you can't DIY that part it could be a huge cost. Materials for the most part is cheap, labor not so much.
post #13 of 60
Thanks for the thourough response.
Glad to hear your family is on board. Watching movies is one of our favorite past times as well and in general the wife has supported the idea of a home theater, if not its execution. She would likely be happy with your HD70 shining on a cream colored wall with the living room curtains pulled. The need for subs and sound treatment and light control escapes her.
I fully understand what you mean about your room's "tactile response". My theater unfortunately is on a cement slab with no subfloor so there is very little tranmittance through to the seating area. My father in-law however has a similar small sub but in a much larger area on the main floor of his house. The vibration coming through the floor adds considerably to the experience.
Nice to see someone else build a performance theater on limited funds. There is always more costly gear but at some point, at any Godly listening levels, the benefits of pouring in more cash if you have made wise choices must be negligable.
I look forward to following the completion of your theater.
Good luck and have fun. (As per common knowledge, pull your projector out of the room to speed progress. )
post #14 of 60
It's been a long time since I've posted anything and I actually took several months off from the room. Was working on getting my backyard done before the intense summer heat set in. Now I'm back on task in the theater.
Here is an update showing the soffit work I've been doing the last week or so. Pillars will be next up. The wires will not be hanging out of course.
Here is a shot with the firing to allow the linacoistic RC to be mounted before the fabric and Alder goes up.
Fabric installed
Alder Veneer and Trim installed
I still need to install the 9 recessed cans which should happen in the next week. Next up is the columns and wire for rope lighting. Then I'll be working on the front stage trim. I expect the columns to take awhile as I plan to do some pretty detailed wood work On them. My brother keeps telling me to just texture the walls and be done with it but by golly I'm doing this room like I always dreamed I would.
post #15 of 60
Worked on the riser today. Decided to trim it out. Waiting to stain things until I nail down the color scheme for the room. Plan to work on the columns this week. Will be making raised panels for them and topping them with speaker cloth.
post #16 of 60
Looking good. Keep the updates coming.
post #17 of 60
Looks great.
Looking at your build brings back some memories...
post #18 of 60
Been so long since you updated that I deleted your build from my list. Glad I caught in the Forum again. As usual, your wood working skills are enviable. Following along once again.
post #19 of 60
Nothing to show as far as pictures go but I've been working on the columns which is a fair amount of work. I'll post pictures tomorrow. I'm trying to wrap my head around so many things right now I get dizzy at times just thinking about it. I asked a well known forum member for acoustic treatment help before I get too far into this. I realize at this point I should have bit the bullet and just taken care of that before I ever started. I didn't realize the scope of the project until I really started getting into it. Now that I have 2 kick ass subs, 7 nice speakers and the projector up and running I'm bitting off more than I bargained for. It's a lot of fun but i really realize that having a plan and sticking to it is vital! I definitely have some problem areas in the room as far as bass control goes and will need some attention. Mostly the rear row in the corner of the room. Front row is good and that's with acoustic treatment other than the Linacoustic RC on the front wall.
More soon. I know the thread moves slow but I try to keep it simple when I do post. Then again not many are following it so that helps. LOL
post #20 of 60
Looking at your riser, it seems that the rear corner seat is loaded pretty close to the corner. I'm really curious to see how you are going to combat the natural gain in that position without buggering up the other seats. Not very helpful advice when you are shooting for the best build possible, but I would say just don't sit there yourself. The average person is so oblivous to what decent sound is that nothing you have done or will do (sound treatment, custom speakers, sand in the stage, 7 speaker surround) will make an once of difference to their experience. In general your audience will have more comments on the carpet color choice or perhaps room temperature than anything else. Excluding maybe your surprisingly astute brother. (Just sit him to your right when you take the best seat in the house, front row left.)
I am looking forward to seeing the columns that you have been laboring so hard on. Given your wood working skills I expect hand carved trees like those found in the Lord of the Rings elf village.
post #21 of 60
I hear ya on that seating position. That's actually the worst of the 7 seats, for obvious reasons it seems. I realize I won't make them all great but like you said it's not going to matter to most of my guests. They will get caught up in the shock and awe of the whole "home theater experience". I'm sure with the acoustic treatments it ill be better than it is now. I was wondering if placing 1 of the 2 subs in that corner would help or hurt. I really don't want those giant boxes in sight for people to see. They weren't intended to be seen, if they were I would have wrapped them in cherry and made them pretty. I'm good at hiding things so I could always build a screen to hide it I guess. I doubt that's going to be a recommendation when I get some of the experts on here chiming in.
Thanks for the kind words on the woodworking skills. I'm not too sure they are all that great but I am super detail oriented on my middle age years, had a great teacher (dad) and have a pretty good set of tools at this point. The columns will have Alder raised panels on the bottoms then a grill above them with some nice trim work that blends in with the baseboard, chair railings and a cap up top. I plan to have the bootms fixed to the wall and the top part will be able to be removed for easy access to the speakers as well as possibly being used as bass traps. Maybe load them with safe n sound, 701/703 type stuff. I'm a little worried the front columns might actually be in the first order refection spot but I don't think it will be an issue since the base of the columns is only 36" or so and above that will be essentially acoustically transparent so treatments will still be function-able. Off to bed....
post #22 of 60
Been working the Bench Dog over. Love this router table!
Here's a small stack of the panels I've been cutting for the columns.
Here's the base panel for the columns. I have 4 of these done and have 8 side panels to make then on to the top of the coumns. Then I'll make a removable section to access the speakers.
post #23 of 60
For the raised panel did you laminate a few solid boards of alder together then router the edge with a panel bit? My router and I have never been friends so I always hack out the rails and styles on my table saw and use a simple flat panel (1/4" plywood usually). Yours are much nicer, but not sure I have the patience to do it right.
I am certainly no acoustical expert, but as no experts are chiming in I will too.
My personal experience is that subs mesh better out front, rather then behind. I know they are supposed to be omnidirectional and impossible to locate but I always seem to know when the bass is coming from behind, at least with the standard 80hz cross over. If I were you I would find a hiding place in the front of the room somewhere, rather than try to smooth response by sticking one in a back corner.
Placing sound absorbing material in your columns is a good idea, especially if the front ones are in the first reflection point as you say. Don't expect a few inches of insulation pressed up against the wall to provide any bass damping however. The effective low end attenuation frequency is very dependant on the distance the trap stands away from the wall and to some extent the thickness of the material. There is a great objective technical document in the Bass trap forum which measures the attenuation rate at different frequencies for several different bass trap designs, from fancy purchased units to simple home made. For the most part size rules, with the cheap do it yourself "Super-chunk" corner traps taking top honors. Low frequencies are reinforced by corners so trapping is best done there. If you have the space I would definitly place one floor to ceiling trap in that offending back corner.
Nice to see you diligently working on the build again. If your situation is like mine the family probably doesn't agree.
I'm noticing a few design details appear very similar to Lockheed's beautiful theater. (He chimed in earlier in your thread.) If you haven't followed his link yet have a look. Very simple and elegent. There's not much in home theater that hasn't been done before so combining the best elements of other builds is a good way to build a great theater. Maybe next time I will follow my own advice.
post #24 of 60
Everything is solid Alder. Yes it's a panel bit. Kind of a pain cutting raised panels until you get the hang of it. The speed you push them is key to preventing burns. I'm not perfect at it but that's a reason I used knotty Alder as it makes for a bit more of a rustic look. Cutting flat panels out of 1/4 inch is clearly the simpler way to get the job done.
As for acoustics I'll work on them as I go along. I asked for help and I'm still waiting to see if I get an answer but I also realize a lot of the experts on here must get so many questions they have to pass some of them by. I still have a lot of things to do so I have some time.
I'll look at Lockheed's thread now.
post #25 of 60
Not much happening the last few weeks. I'm training for a long bike ride that's happening in a few weeks so until then I'll be riding and not doing much else.
post #26 of 60
Isn't that the truth! At times I'm looking around wondering if I bit off more than I can chew, there is so much to do that it's hard to keep track.
post #27 of 60
Nice job on the soffits. One question though: isn't it going to be difficult to stain the Alder without getting it on the black fabric?
Absolutely. It's your room -- stick to your plan
post #28 of 60
Nah,
I'll tape it off so it should be fine. Didn't have a lot of choice on that part of the staining process. The rest will be stained and varnished before it goes up.
post #29 of 60
Just ordered all the fabric for the walls and screen wall. Wife was wanting to have red/burgundy in the room and I decided to listen to her. The room will be skinned in GOM Anchorage Onyx from the floor to approx. 3' up then transition to GOM Anchorage Mulberry for the next 58" or so then have a final 8" up to the base of the sofit with more Onyx. Transitions will have some sort of wood trim and possible 45 degree bevels to polish it off. Stain on the wood is still to be determined. I'm thinking a dark burgundy black color to tie in with the 2 main colors. Originally was going to go with a medium to dark brown but I'm not leaning that way anymore as it creates more difficulty in blending the colors together correctly. I'm no interior designer but my mom had a great design eye and she taught me a few things. We'll see how it goes when I start getting the fabrics stapled up.
post #30 of 60
Hard to believe how long it's been since I posted to this thread. I was swamped last fall with work and training for a few bike rides. Theater has been ignored for several months. I decided to finish it in the next few weeks so hopefully I can stay on schedule and get it done ASAP as planned.
Soffit is done, cans in the soffit, trimming out walls so I can apply Linacoustic RC and batting. Riser trim done.
One of the areas I've been stumped on is the 2 windows I left in the room due to fire code. I toyed with the idea of using curtains but my craziness got the best of me and I decided to make hidden doors that will hopefully blend in with the rest of the walls. We shall see.... This is a rough start to the finished product.
