Well, after viewing one build log after another here on AVS and dreaming of my own dedicated theater, I finally decided to pull the trigger earlier this year when we decided to go into a major house remodel. With the support of everything else we wanted to do with the home, I had enough justification to include a dedicated HT room off of the first level.
First off, if you've seen the name "Reel Time" in another thread (http://www.avsforum.com/avs-vb/showthread.php?t=1251515), you're correct. That's the thread that started with the project in March of this year (2010). I realized two things: 1) I didn't use a very good title as most folks have missed the build altogether and 2) I had too much in there about the entire remodel project (basement, new garage, second story of the new addition, family room remodel, etc.).
So, now nine months later, I've decided to stop posting in the old thread in start this one dedicated to items about the HT itself. There will be some info and pics about the addition build. But, only as it applies to the HT. I've got a lot to pass along, and I'll do that over the next couple of days.
Okay, so onto the HT build. I hope you enjoy and learn as I have by others' examples here on AVS. Please feel free to chime in with anything, good or bad. It's all okay as long as it's constructive!
That makes alot of sense. Particularly the need for higher ceilings in the garage. Well thought out.
