WE HAVE STARS!
Set out to unpack the huge crate that held my star field panels from FOSI this weekend, and actually finished it. Everything was very well documented and the instructions were spot on. Now, it did take far longer than I anticipated, but since I have never put one up I really didn't know what to expect.
The biggest issue is working around the star placement and having the blocks behind the panels for mounting in the right position. Then there's the lifting of the 45"w x 10' long 3/4" MDF panels into place and scewing them up. With the help of four 3rd Hand poles and my oldest son, we were able to do it. We did need assistance from my wife and youngest to help hand the poles and steady them.
Below is a stream of photos from beginning to end of the this project.
Opening the crate...
Panels in the crate...
One of them out and ready to go...
First panel up being held by 3rd Hand poles before being screwed up...
Quick pick holding the end of the fibers up to the illuminator...
Fibers coming in through the slot and into the hushbox in the rear of the rooom...
Second panel up and the fibers running back to the hushbox...
I installed blocks to help line up the panels. The screw is not going into the panel, but into the 3/4" mounting block. Once the panel caught onto the biscuits, I removed the blocks and pushed the panels together. I needed to use the blocks (4 total) because the MDF bowed too much making it hard just using the poles...
All the panels up...
View of the wheel in the illuminator and the panel holding the fibers...
Other side of the illuminator with the fiber strips attached...
Just a pic of the illuminator bulb...
A couple shots (albeit poor from cell phone) of the field...
Pic of the illuminator running sitting in its final position up in the hush box to the side...
I have to say that I'm really impressed with the star field and it's quite stunning all finished. It was a lot of working prepping each board and working around the star locations, and especially installing the screws, but worth it. For each screw, I simply cut and L in the felt, pealed it back, put in a screw, then laid the felt back over and smoothed the edges making it disappear.
The only small negative, and it is small, is that the seams of the panels are visible when you are standing directly below one looking up. The MDF is tightly together (I even used the poles horizontally to squeeze them together), but the felt does not touch from each piece. There is no overage at all of the felt. When you look directly up at a seam, you can see the light brown of the MDF panel showing. I think I will take a black sharpie and try to run down the line to color the MDF and see if that works. If I would have known prior, I would have colored it before putting it up!
There you go. If you have any questions about it, just shoot'em out.
