AVS › AVS Forum › Audio › Speakers › If you had $800 to spend on speakers, sub, and receiver what would you get?
If you had $800 to spend on speakers, sub, and receiver what would you get? - Page 2
post #31 of 138
Originally Posted by crazyrob425 View Post
Actually the Denon AVR-591 is the cheapest with ARC that I have seen. Its only a 5.1 receiver though. For $50 dollars more the Denon AVR-1611 is the 7.1 version
Interesting. I don't have time to read up on the 1611, but the 591 looks pretty sweet! Thanks.
post #32 of 138
Originally Posted by jw00dy View Post
I stand corrected. You are right. Sorry about that.
http://reviews.cnet.com/av-receivers...-34079031.html
I'm a bit nervous about the sound quality they mention in that review though.
I think I must have gotten it confused with the Pioneer VSX-1020-K, which does not support ARC.
http://reviews.cnet.com/audio-system....html?tag=also
I also looked at the Denon 1911, but I'm not thrilled with the lack on inputs. I do LOVE that it has HD Radio which is a Plus (not sure why everyone else doesn't have this support).
You know, you have a good point. I have a Vizio XVT553SV and it does have the Digital Audio Out, so I could certainly go that route and save a lot of money... Thank you!
no need to be sorry just didn't want you to count out a good receiver without letting you know it supports arc btw nice tv !
post #33 of 138
Thanks DCM88
post #34 of 138
First off THANK YOU for sharing your suggestions!
I think I may not have been clear on the size of my room (I fixed it in the first post). It's 12'x25' for a total of 300 Sq FT. (2400 cubic feet). It's not that big is it/
The 7.1 could wait, I don't have to get it, but I didn't think my room size dictated that I'd need to spend more money to get speakers that would sound good/fill it up.
Thanks for that info. The Behringer look pretty nice and are not bad priced either. They appear to be a little large though, specifically for the rear speakers? Wondering how well they would wall mount?
No, I could go with 5.1 to start. How big was this small room?
Thank you for your complete information. I will check out monoprice for sure. Dang those infinities are spendy. I am seeing pricing for EACH instead of as a pair, which isn't good for my budget. Do you have some specific recommendations as far as the speakers you suggested?
Thanks for that info. I know I need to decide on what receiver. I think I should do that so I can really decide how much I can spend on speakers. I need to get it 7.1 and it needs to be future proof since I'll be adding speakers as I can get them.
Thanks for the info. I'm very sad to hear that my room is going to take some serious money to fill. Is 2400 Cubic Feet really that much?
I do like those speakers though. Do you know of good source to get these speakers at rock bottom prices? Do they even come in pairs?
Any suggestion on the sub?
Ok, so now I'm really lost. I was on a path that's now changed dramatically. I may just start with 2.1 or 3.1 so I can get good speakers...
My room is 11 by 17. Here is the thread on it.
http://www.avsforum.com/avs-vb/showt...022&highlight=
post #35 of 138
thanks bladerunner6, I'll check it out.
post #36 of 138
so bladerunner6 how do you like you inifinities? I think they might be a tad over my budget, and did you ever get a chance to listen to the Pios at BB? I'm going to try and listen to them in the next day or so. Wondering your thoughts if you did listen to them.
post #37 of 138
I am in southern CA on a business trip and had the chance to go to best buy and frys to audition speakers. Specifically pioneer, klipsch, Polk, and infinity.
First off I do not like klipsch sound. I now understand what people say about them being bright in the highs. They are actually quite harsh and it would be tiring to listen to them for very long.
I really loved the infinitys. I am at the airport so I can't remember what ones they were other than they are in a 5.1 package and there were 2 sets of them (1200 & 700 maybe). I need to see how much they are online but at box store prices they are a bit outside my budget. I believe it included the sub, which was ok but not great.
I like the infinity size and sound. I also like that they are not rear ported which may be a deal breaker for the pios.
I listened to a velodyn impact 12 (sub) which sounded a lot better than the infinity sub. Any thoughts on this sub vs a bic?
I really liked the Polk speakers as well but didn't give them the attention I should have for a proper audition. I was paying too much attention to the pios.
I really like the pios. They are pretty big though and I didn't like the fact that they were rear ported since I need two of them to be in a book shelf and the other two to be against the back wall (or close to it). They were quite a bit quieter than the polks and klipsch i compared them to, so I had to turn them up to really get am idea of how they compared. Which was very good. I really like the sound and they seem pretty crisp and clean. Especially considering the price.
So now I need to see what kinds of prices I can get these (infinity, Polk, & pios) and go from there. Thanks for all the help so far. I'm really glad I got audition the speakers since it really helped. I will never buy without an audition if I can help it.
post #38 of 138
while you were on av express why not look at the bg line of speakers?
post #39 of 138
Probably the biggest reason is that I know nothing about them, but I'll check them out. I'm leaning toward the infinity TSS-1200 due to finding some reasonable prices.
post #40 of 138
Are those BG tweeters similar in sound to the Martin logans? I did not like thy sound at all. Even at those steep discounts I'm at ~1050 before a sub and receiver which is over my budget already.
post #41 of 138
The bg z1 got a c rating from stereophile and they have a good review on them. Msrp $600 but can be had for $150 and spend the rest on receiver and sub. I have them and they get pretty loud but what I like about them is even at low volumes it's very clear.
post #42 of 138
Sorry I forgot you are looking for multichannel Surround
post #43 of 138
Thanks for the info. I'm always open to different options/opinions
post #44 of 138
Just curious, what Polks did you happen to audition? I'm considering Polks as well and wouldn't mind a bit more detail if you can remember
thanks!
post #45 of 138
They are the ones that BB sells.
I didn't pay that much attention to models for the Polks since the price really wasn't in my range. I did really like them though. Much better than Klipsch and louder, but similar quality to the Pios.
The bookshelf I believe were the TSI100.
The center was the CS10
The towers were the TSI300
post #46 of 138
The TSI-100 = Monitor 30's
The CS10 = The CS1
The TSI300 = Monitor 50's
And they are have the price of the stuff bestbuy carries!!!! Go to Newegg! The Polks will be in your budget. Newegg has amazing sales on the Polks!
The CS10 is $99; the CS1 is $99; and the Polk Monitor 50's floor standers are currently $82 per speaker(promo code 'EMCZNYV42')
$362 With Polk Monitor 30's from Amazon and the other speakers from newegg! leaving $438 for receiver and subwoofer!
post #47 of 138
The CS10 = The CS1
Ahh, thank you! I may have just found my solution!!!
post #48 of 138
Ok, so I did some measuring and discovered that despite my desire for floor standing speakers, they won't fit in the allotted space I have next to my TV + Entertainment system (yet to be purchased because they didn't have it in stock, but will be purchased as soon as it's in stock). I have 18" to spare (9" on each side) before I run into a door (on both sides). Soooo...
I also discovered that the Monitor 30's are rear ported Which for the front channel is not going to work since these unfortunately will sit on a shelf in an actual book shelf (part of the entertainment center).
I am heading back to the Infinity setup again... (front ported and I did like the sound a lot).
post #49 of 138
Infinity P162 bookshelves are amazing speakers
post #50 of 138
Can I throw out there that for $800 you should go to www.accessories4less.com and buy either an Onkyo 700 series or Marantz 5003 and then use the rest of the money on 2 speakers. Preferably a set of bookshelfs you can move to the rear of your soundstage later one you save more money and get a pair of towers. Id suggest PSB B5s to start.
post #51 of 138
Now those do look nice. hmm, I wish that price was for a pair. The more I look and the more I learn the more I'm leaning toward just building the system over time.
Start with 2 front (L/R), a Center, a good sub + Good AVR.
I'm thinking of going with the following:
Front L/R: 2 x Infinity P162
Center: Infinity PC350 (looked at the PC250, but for the $50 more it has more speakers and probably sounds better too?)
Sub: YtbD (Yet to be Determined)
Later add the rears.
I also really like the behringer B2030P and can get it for a pretty dang good price (I think for a set) $109.
My questions about the behringer is what would I use as the center channel? And what about the 100w power? I would really like to get 100w P/C AVR, maybe more (110w). Won't that be too much for those speakers?
I think I've about narrowed it down. Once that's done I can work on what sub and AVR. Thanks again for everyone's help.
I do really like that Onkyo you posted. Great price too.
post #52 of 138
Good thinking one doing a bit at a time. As for the PC250 vs the PC350 keep in mind the size of the centers and where it will go.
Careful - some retailers sell them as singles and some sell them as pairs. A year ago you could have found a pair on sale for that price but they've gone up a lot in the last 6 months. The best price I could find was $150/pr shipped.
A third B2030P.
The sensitivity of the P162 is 90db @ 1w @1m (89db or the B2030P). Every additional 3db of above that level volume requires doubling the power - 2w for 93db, 4w for 96db, 8w for 99db etc. That means that the additional 10w will buy you almost nothing. However that higher powered receiver may have more/better features.
It's a non-issue. No law says you have to turn the volume to tilt. When the speaker starts sounding bad turn it down!
post #53 of 138
Thank you sholling, that is good information.
I have spent the better part of the afternoon reading reviews and I think I am going to stick with infinity since I've heard they are a little more Musical than the behringers, which to me is a big plus though music may only be a small part of what these are used for.
I just looked at the size difference between the pc250 and pc350 and the only difference is the width (pc350 being wider). Both are quite tall. Isn't it suggested to put these just below or just above the TV (though my TV is quite large)? I would need to lift the TV quite a bit for these to fit.... dang that sucks. Just when I get excited, I get kicked in the nuts... reality sometimes sucks.
Suggestions...
post #54 of 138
you can put the center below or just at the top of the TV
Here is one option to keep the center below the TV
http://www.polkaudio.com/forums/show...03&postcount=1
post #55 of 138
Thank you. That looks pretty good for a home-made job. palehorse did a nice job.
Ok, now I've got options. I think I'm going to start ordering before I find something else and change my mind...
Then I'll spend some time on subs.
post #56 of 138
Ok, I'm doing it.
I talked to the boss and she has agreed to spend $1000 which gives me a little more wiggle room.
I am going to get the following for a 5.1 setup.
Front L&R
Infinity Primus P162 x 2 (http://store.audioholics.com/product/2019/0/)
Rear L&R
Infinity Primus P162 x 2 (http://store.audioholics.com/product/2019/0/) -- unless anyone can give me a compelling reason to use the P152 or P142 instead -- Are the surrounds really not that important? The P142's are $20 less per speaker.
Center
Infinity Primus PC350 x 1 (http://www.crutchfield.com/p_108PC35...le.html?tp=189) -- I will make this work somehow...
$540 Total for the 5 in the 5.1.
I am still undecided on the sub, but will start looking at HSU and BIC subs shortly, but I'm open to suggestions of course. I have also found quite a few locally that are used... just not sure about going that route.
Still not sure what AVR, but that's going to end up being decided by how much money I have left over...
Let me know what any of you think about that speaker setup as I would like to buy them in the next 24 hours so I can stop obsession about speakers (and can move onto subs )
Thanks again for all of your help.
post #57 of 138
I like you proposed set-up but how much you leaving for a receiver?
FYI the infinity p162 are quite large but sound awesome supposedly. The smaller p152/142 for surrounds would be less obtrusive and in that case I would go with the p152s
post #58 of 138
I'm afraid it won't leave much for the receiver I am going to try and squeeze a little more for a receiver when I get to that point.
The 162 vs 152 size wise:
P162: 8-3/16"W x 14-7/8"H x 11-1/16"D
P152: 7-3/8"W x 12-15/16"H x 10-1/2"D
Which turns out to be ~3/4" wider, ~2" taller, & ~1/2" deeper
Not much difference, though the 152's weight a few pounds less too and cost $20 less as a pair. I'm just not sure the $20 less and smaller (though not much) is worth it for a lesser speaker. When it's close, I usually err on the side of better.
post #59 of 138
Ok, never mind. I did it.
Front L&R: Infinity Primus P162 x 2
Rear L&R: Infinity Primus P152 x 2
Center: Infinity Primus PC350 x 1
I looked around for the best deals possible and found a discount code for using a visa (good for $20 off) and got that order down to a tad (very tad) below $500, with no tax or shipping!!! I went though crutchfield, so if anyone knows of a better place to buy, speak now or forever hold your peace since I would guess it will ship in the morning.
Now the Search for a 5.1 AVR and a good sub for my room size begins.
AVR Wants:
HDMI 1.4a (w/ARC)
4+ HDMI inputs
2+ Component/Composite inputs
100+ Watts per channel output
iPod/iPhone dock or USB compatible iPhone/iPod connection
HD Radio would be a huge plus, but not required.
I think for the $500 I have to spend I'm going to be pretty hard pressed to find something that fits this bill. I'm going to go back over some of the stuff that's already suggested and see if I can come up with something that will work.
post #60 of 138
Congratulations! Ya done good.
For the sub I'd call Hsu Research and have them size you a sub to the room.
AVR Wants:
HDMI 1.4a (w/ARC)
4+ HDMI inputs
A factory refurbished Onkyo TX-NR708 would be a good choice and there is an optional iPod dock add-on available.
  Back to Forum: Speakers
