AVS › AVS Forum › Audio › Receivers, Amps, and Processors › are NAD receivers more poweful than they say they are?
post #1 of 3
need to replace a blown Pioneer elite sc-27. Here are the receivers I am looking at, opinions?
NAD t747
Integra 40.2
Marantz sr6005
While both the Marantz and Integra are rated around 100w pc, the NAD is only 60w pc but i have been told the NAD will blow them away.....Any truth in this? the NAD is about $300 more than the other two.....what gives? BTW i was never really happy with the Pioneer....too confusing, too many bells and whistles...Just want power and simplicity and of course great sound....
post #2 of 3
With NAD they give you the true output with 7channel simultaneous running. With other companies only 1channel or 2 channels running. I had the NAD 743 model about 4 years ago and wowed me with only 50x5. I used to push that little receiver hard and never had a problem with it and regret selling it.
post #3 of 3
They also list the power as 120x7 FTC. Which is probably a more comparable stat to many companies such as Yamaha (which would be measured with only two channels driven.)
