So what happens if I don't have/can't find my appdata folder? Trying to integrate MPC-HC and for the life of me cannot find this folder.
I am using Win7 x64 and the latest official release (Dharma).
Under C:\\program files (x86)\\XBMC I have the following folders:
addons
language
media
sounds
system
userdata
I have a playercore.xml file in the userdata folder, but after following the guide on mediasmartserver.net I would like to be able to set it to only play mkv's which have "DTS-HD" in them. According to the guide, you need an additional playercorefactory.xml file in your user appdata folder. I do not have this folder under c:\\users\\htpc\\
I do have appdata under C:\\windows\\system32\\conig\\systemprofile and there is a roaming folder, but no XBMC folder inside of that, which I need apparently.
Any help is greatly appreciated. The guide I am using is here:
http://www.mediasmartserver.net/2010...layer-in-xbmc/
