Originally Posted by
GreenEyez
Partial succes. On my Zacate HTPC when bitstreaming i get no audio, just static. Have no clue why it doesn`t work, if anybody with a Zacate E350 APU has this working, please let me know,
Anyway, here`s the configuration for LAV CUVID + LAV Audio + LAV Splitters (Nvidia only, since LAV CUVID is a CUDA based decoder)
LAV filters download :
http://files.1f0.de/lavf/LAVFilters-0.42.exe
Mediasconfig.xml :
http://www.mediafire.com/?1gvajzxvgd8dvc7
Advancedsettings.xml :
http://www.mediafire.com/?kkpvid6o3dpgj6v
After you install LAV filters, go to Star Menu orb -> All Programs -> Lav Filters COnfiguration
[*]For LAV Video -> Select Hardware decoder to use -> CUVID
[*] For LAV Audio -> Select the bitstreaming options you want, or leave everything as it is if you decode audio on your HTPC
Put the mediasconfig.xml in your C:\\Users\\Alex\\AppData\\Roaming\\XBMC\\userdata\\dsplayer folder.
Put the advancedsettings in your C:\\Users\\Alex\\AppData\\Roaming\\XBMC\\userdata folder
During playback of an MKV file, press "o" on the keyboard to get the info. Should look like this :
Hey greeneyez, thanks for this info. I havnt been able to get it going yet. I posted my below info over at xbmc but thought I would throw it up here as well in case I can get feedback on it. One thing I was wondering(maybe steelman can answer as well) is that your files are much smaller than the ones steelman has in his post below to me. They are like the ones in the program files (86) path not the userdata path. Since I thought those were already there and steelman also said they were included in the build, I was confused as why the two different type mediaconfig and advance settings files are different. Also, where you say to put the mediasconfig file in the dsplayer folder in the userdata path, there was no dsplaer file. I had to create a dsplayer file to put the mediasconfig file into. The only dsplaer file is in the program files (86) path. Let me know if you see the problem. In the meantime I'm going to keep at it and read up on the instructions given here:
http://dsplayer.wikia.com/wiki/HOW-TO:_Using_DSPlayer
- Im trying to install all lav filters and lav cuvid in dsplaer build. when i hit the c button, "play using"shows dsplayer but when i press on it nothing happens. I installed the mediasconfig.xmlin my C:\\Users\\Alex\\AppData\\Roaming\\XBMC\\userdata\\dsplay er folder. and Put the advancedsettings in your C:\\Users\\Alex\\AppData\\Roaming\\XBMC\\userdata folder. there was no dsplayer folder in the users\
ame\\appdata\
oaming\\xbmc\\userdata\\so i created oneand put the file in that. Here is the mediasconfig fileI used: ---
and here is the advance settings file i used: - - dsplayer
I didnt do anything to the C\\program files(86)\\xbmc\\system\\players\\dsplayer files but i will show them anyway.
here is the filter config file that is located there:
http://pastebin.com/HhLddcSs
here is the mediasconfig filethatis there :
http://pastebin.com/9EzdEFU9
and here is my error log:
http://pastebin.com/wC2uDu5Q
any ideas?
Edit: I actually looked at steelmans indepth for the first time and realized they are the same as yours I believe except he was just giving me one for many file types.
