AVS › AVS Forum › Video Components › Home Theater Computers › XBMC Media Center : Setup Guide, Knowlege Base & Support
XBMC Media Center : Setup Guide, Knowlege Base & Support - Page 63
post #1861 of 2944
Yeah, there are a lot of options. You basically just have to go through each one with a check list and view the results to see if what it's doing is to your liking. Once you get it set up though it is pretty damn lovely. Aeon MQ3 shows the logo downloader plugin as broken so I can't select the logo or show artwork views which are the best looking in my opinion. Can the artwork downloader plugin do the same thing or do I need to wait until logo downloader gets fixed?
post #1862 of 2944
hey quick question: how do i minimize or maximize XBMC?
post #1863 of 2944
ok. just got a big issue.
i tried to play a 1080p MKV file and as soon as I hit play. my projector and AVR went to no signal.
the movie play find if i was watching on my 21" monitor, but if i tried to play it on my projector i got no signal.
must be something wrong with video output setting.
post #1864 of 2944
fixed this. had to go into my ATI's display setting and changed the refresh rate from 60hz to 24hz and it works fine.
post #1865 of 2944
i have several collections of music videos (MP4, AVIs, etc)
how do i set this up?
i like to set it up as different playlist (e.g Rock, Pop, International, etc.)
and when i play them, i like the options to be able to repeat and shuffle.
should i add them under MUSIC or VIDEO? and how?
thanks
post #1866 of 2944
Alt + Tab
post #1867 of 2944
thanks
you can have playlists for music or videos. Music Videos go under videos
post #1868 of 2944
Originally Posted by thewarm View Post
Alt + Tab
or if you really mean how to toggle between fullscreen and windowed mode?
that would the "\\" key
post #1869 of 2944
I hit the windows button if I want to just get out of xbmc.
post #1870 of 2944
yup. i can hit alt+tab or windows key to get out of XBMC.
but i want to minimize it and move it to my secondary display, which is the projector.
you guys running hdtv/projector, do you have to set refresh rate on the display setting to 24hz? it's strange that i have to do this with XBMC.
post #1871 of 2944
There is a setting in XBMC that you can use to tell it to start up and run in whichever display you want.
post #1872 of 2944
do you know where i should look?
post #1873 of 2944
It is in the video settings somewhere, you just need to look around. My wife has four multi-monitor computers at her office and I set each of them up to simply launch/run XBMC in the second monitor which is exactly what they needed. It took less than a few minutes to find the setting and make the change.
post #1874 of 2944
cool. i'll look around. that is a excellent feature to have.
turn my pc on and have XBMC launch in secondary monitor. excellent.
post #1875 of 2944
It is possible it's set during playback in the OSD. I'm not at a PC at the moment so I can't check. I just know it can be done.
post #1876 of 2944
i was playing with the OSD last night and didn't see any options that might handle this. but again, i've spent maybe 2hrs max on XBMC so far so what do i know. lol
was reading over at the XBMC forum and there's an option where you go in and edit the Advancedsettings_monitor.xml file, which i don't want to mess with.
post #1877 of 2944
hey guys, i just added several playlist by gendres (action, drama, comedy, etc.) and i like to use different backdrop pictures for these.
where can i get them?
post #1878 of 2944
Google images or use one of the backdrops from one of your movies of that genre.
post #1879 of 2944
You can find great backdrops here:
http://community.mediabrowser.tv/topics?category_id=7
post #1880 of 2944
System->System->Video Settings-> Video output settings
You can choose screen 1 or screen 2 as well as resolution, etc, here.
post #1881 of 2944
thanks. and this will automatically launch xbmc when i start my htpc?
post #1882 of 2944
No.
Just use the startup folder in windows like you would any other piece of software that you want to run at startup.
Alternatively you can try one of these: http://wiki.xbmc.org/?title=HOW-TO_m...in_Full_Screen
Finally, you can just double click a desktop icon which is what I do and I usually just leave it open. My HTPC draws 30 watts so it is never turned off.
post #1883 of 2944
This Eon skin is damn hard to setup.
Which version are you on? I'm on Aeon MQ3 and I've got everything but music library setup pretty nicely. What issues are you having?
post #1884 of 2944
I managed to find my ways around a bit. It's just that under the settings you have to use arrows instead of mouse and click.
post #1885 of 2944
ok. got a bit of an issue.
on my main menu, i do not have a 'System' option.
did i delete it by accident?
post #1886 of 2944
Yes. XBMC works much better with the keyboard, takes a minute to get used to. A remote can be much easier, especially if you're on a projector.
post #1887 of 2944
Possibly. Go to settings, skin, and then shortcut/backdrops. You can enable/disable your home buttons there.
post #1888 of 2944
Sorry there is no system button that I can find. "System info" can be bound by hitting down while settings is highlighted.
post #1889 of 2944
went there, browse through all the buttons. didn't see 'System' there.
post #1890 of 2944
I went there too. It only display my system's info. Doesn't allow any editing.
