Originally Posted by
dan4081
In the stock Confluence skin it is under System/Skin/Home Window Options...there you Uncheck 'Hide-Movies'.
Have you already added your movie share and set content to Movies, and let XBMC scrape your content?
If so, the option should be where I mentioned.
I added my movies folder, twice. I have to go into files just find the movies themselves, all metadata (but for Never Say Never Again, 007) is available.
I added them the same way I added the TV Shows. The only difference is how its shown on the server.
Movies was: //servername//dvdmovies/movies
I have since moved that folder into the Video folder (WHS 2011) and the source is now: //servername//videos/movies
I think its a source related issue, but I'll check the settings again, thanks.
