Originally Posted by dazz87
I had the same issue like you. I was confused why some of my blu ray iso and blu ray folders structure were not showing the blu ray case. I figure it out by accident. The ones that were not showing up correctly all I had to do was just played the movie. 5 seconds into the movie I exit and guess what the case change from the default to blu ray. I ended up doing this to about 75 of my blu ray and dvds. After doing this now all my movies has the correct case. This was on Aeon Nox 3.5.0
I tried playing them but still no cases, maybe because I'm using an external player? I ending up switching to Aeon MQ3 which automatically got all the correct cases, so it must be something skin related.
I have an issue when backing out of menus in Aeon MQ3 so can't use that skin either lol
I don't really want to go through playing all 400+ movies just to get the correct case
