Originally Posted by Guinness77
I am trying to figure out the best way to store my movies.
I store my music like this :
music/artist/album/
What is the standard way to store movies? I am going to start organizing, and just want to make sure i do this correctly before I start XBMC. Is there a certain way to name the cover files?
I have another question:
Is there a way to have XBMC store the cover art for the movies and music locally on my HTPC SSD instead of relying on the server?
music/artist/album/
It's changing in Frodo, though the old way is still supported, since you are starting out follow Frodo style. Root folder, then single movie folder with movie name and optional (year). In the individual movie title folder, extrafanart and .actors folders. There are filenaming conventions, if you want you can include media info in the filename (see xmbc wiki). The new artwork standard names are variations of moviefilename-poster.jpg, moviefilename-banner.jpg, etc.
The per-xbmc client artwork/thumbnail cache setup is changing. Note that XBMC currently has a local store for the cache (in your userdata). Frodo has option for centralized cache storage that can be shared. I think in most cases if you use a movie "scrapper" what you get is a URL pointing to the artwork, not a download copy (there is an addon artwork downloader for that). XBMC will download from the URL to your cache. I guess if you then use library->export you can get XBMC to copy out the cached artwork to your media file folders. Now that Frodo is at beta 2 I am just starting to seriously play with the features (still using default Confluence skin in it).
I've found it helpful to use an offline media manager (media companion on windows, other options are ember media manager or media center master). I would suggest getting your movies set first, before working on TV shows. Also there are some considerations about "stacked" movie files, and movie "sets", capabilities I don't use so you might want to read up on those before starting to set things up.
scott s.
None of my trilogies or anthologies show up as collections. Only mildly annoying, but I'd be interested in a fix as well
