AVS › AVS Forum › Video Components › Home Theater Computers › XBMC Media Center : Setup Guide, Knowlege Base & Support
XBMC Media Center : Setup Guide, Knowlege Base & Support - Page 97
post #2881 of 2944
Hey everyone, I added a source to videos, selected movies and the scraper, but when i click on Movies on the main page it states that there is an empty collection and that I need to add videos to the source. But I have. I have removed the source, added it again. Changed the content to none and then back again. Not sure what else to try, other than a complete uninstall and re-install.
Any ideas?
post #2882 of 2944
Originally Posted by rsmclay View Post
Any ideas?
are you trying to setup a sync'd mysql library? if so, add the network shared version of your collection rather than the local machine drive folders
post #2883 of 2944
No, no mysql. Just trying to point it to my movies that are on my WHS 2011 via SMB.
post #2884 of 2944
Are you using the following?
  • Movies are in separate folders that match the movie title - Enabled
  • Exclude path from library updates - Disabled
http://wiki.xbmc.org/images/thumb/9/9a/Set_content.movies.png/500px-Set_content.movies.png
post #2885 of 2944
I have the latest version of XBMC. I have a dual screen setup, with one computer screen and one output that goes through HDMI to a receiver and then to a projector. I've been able to get XBMC on the projector, while also having a separate set of windows on my normal computer screen. The problem is that once I start a video on XBMC, the cursor gets caught in the XBMC window and I cannot move the cursor to the other computer screen. Is there a way around this? I'm using Windows 7. (I have a program called the "Maxifier", which I can use for WMC to get around this very problem; the Maxifier allows me to start a video while WMC is maximized on the projector screen, but then move the cursor to the computer screen so that I can keep working.)
I need the ability to move from the XBMC window -- while maximized on the projector screen -- to the computer screen so that I can do work or at least use my computer while my kids watch a show.
post #2886 of 2944
I think it goes away when you disable "Mouse and Touch Screen Support" on the "Input Devices" tab of System Settings
post #2887 of 2944
Any ideas?
Any ideas?
What type of rips are you adding ? MKVs, Blu Ray folder rips, ISOs ? Are they each in a separate folders or just one big folder with all files in them ? Also, after you selected Movies as the type for the source, you press OK and a dialog box comes up asking you "Do you want to refresh bla bla.... " , did you select OK/Yes for that? If you didn`t, the automatic scanning won`t start, and you`ll need to manually do it (when in file mode, got to the source folder, and press "c" to get the context menu, select "Scan for new content".
post #2888 of 2944
Originally Posted by lulimet View Post
So far I am disappointed with frodo 12. It crashes far too often for me. At least 2 times a day.
Did you upgrade from Eden (uninstall Eden without uninstalling the Userdata folder), or did you do a clean install ? Upgrading botched up my install also, random crashes after X (X being a random variable) time of the HTPC just sitting idle, had to do a clean XBMC install to fix it.
post #2889 of 2944
Originally Posted by bswiz View Post
Anyone still using Ember Media Manager and having trouble downloading full-size wallpapers/fanart? I'm using EMM 1.3.0.9 and when I download info for a new movie, the images it's downloading are only 300x188. It used to download large 1920x1080 wallpapers. I don't recall changing any settings that would cause this.
Ideas?
In Ember, Tools Menu - Edit --> Settings
Go to the Movies tab, and select Ember Native Movies Scarpers.
Look for TMBD Extrathumbs size, and change to original.
I had this issue last night and the above sorted it.
post #2890 of 2944
Originally Posted by smokarz View Post
Anyone have problems updating their movies playlists?
So, I've created different playlists for the different genres of movies (e.g. Action, Horror, Kids, etc.)
After I add new movies, XBMC won't find them so I tried to update the playlist and always get the error message "Can't Download Content...blah..blah".
I don't get it, what's there to download? The movie is there, all the posters and backdrops are there. I used MCM to scrape the metadata.
Did I missed any settings or something? Anyone having this problem?
I have been getting this problem too. On the xbmc forums, they say that it's something to do with a movie name not being parsed properly, but i don't believe that because I have two xbmc instances scanning the same sources: one works, the other generates this error.
You can bypass the error as follows:
Create a text file named advancedsettings.xml inside your userdata folder.
Put this text inside it:
Code:
<advancedsettings>
        <videoscanner>
                <ignoreerrors>true</ignoreerrors>
        </videoscanner>
</advancedsettings>
This isn't a complete fix though - something is triggering the error. But you'll at least be able to ignore it.
post #2891 of 2944
That did the trick, thanks!
post #2892 of 2944
Is it possible to downgrade to 11 Eden instead of using 12.0 Frodo? Can't seem to find a download link to downgrade. I'm having problems with (stuttering every like 30 seconds) video playback that I'm only experiencing in XBMC. Searching through forums online, a lot of people who have the same problem state they went back to Eden and playback issues were solved. I would like to keep HD Audio though. In the meantime I'm using Media Browser with WMC, everything works perfectly in this I just would prefer to use XBMC so I can get some Raspberry Pi's throughout the house. I have tried pretty much every configuration in playback in XBMC but can't get SD or HD video to play without what appears to be skipped frames or something. No issues with TMT5/PowerDVD12/WMC at all.
Here is my hardware:
-AMD A8 Trinity 5500 CPU with ATI 7560D GPU (Can do 1080p 2D/3D)
-MSI FM2-A75IA-E53 ITX Motherboard
-16GB Ram
-30GB SSD (Windows 7 Home 64-Bit)
-(2) 3TB WD Red Hard Drives (will expand as I run out of space)
-Lian PC-Q25 ITX (Small and can fit 8 hard drives in it)
-Using a 58-inch Plasma, and a 125-inch 2.35:1 screen with Panasonic PT-AE8000u projector.
post #2893 of 2944
Try here:
http://mirrors.xbmc.org/releases/
scott s.
post #2894 of 2944
Originally Posted by scott967 View Post
Try here:
scott s.
Thanks, I couldn't find that link.
post #2895 of 2944
No, no clean install, just upgraded. It's happening in all 4 of my computers. I am at the point that I may stop using xbmc all together. That's how annoying it has become.
post #2896 of 2944
Does XBMC or OpenElec support "album" FLAC files with CUE file support, either embedded or external? Even better if it support album art (internal or external .jpg as well).
I've been out of the HTPC game so long.....too much to read.
post #2897 of 2944
Dark_Slayer and GreenEyez. Thanks for replying. The movies are MKV's and each movie is in it's own folder. I did select for it to refresh and the exclude path was set for disabled.
What it ended up being was the fact that I was trying to hide the movies, the best of my ability for the kiddos, by burying it in a few subfolders. Well one of those subfolders I named Microsoft Sample Folder, and I guess XMBC looks for certain text strings and will exclude that string. So it picked up the Sample in my folder name, and excluded the folder from being scanned. This makes sense, because I guess you really wouldn't want any files scanned, for instance sample.mkv
I asked over in the XBMC forum if there is a list of all the text strings that may be excluded.
Thanks for the suggestions. It has been driving me crazy for a while now, and I couldn't believe it was the name of the folder that has been making it go crazy. If they point me towards a list of text strings that is excluded, i will post here if anyone is interested.
post #2898 of 2944
Makes sense
FWIW, best practice is to make explicit paths. I'm not sure how far XBMC will go if it's expecting every title to have it's own folder. It will either scrape and match, or scrape and fail. Recursive scanning is a separate setting. Anything that is recursively scanning should be pointed to the deepest path within a directory if possible. For example, a rename/move/metadata grab pointing at a comskip program's directory should only point to the "complete" folder which should be nested within the "queued" directory to prevent it looking where it shouldn't
post #2899 of 2944
Is the a guide I can follow to add Hulu and Amazon prime to XBMC? I just started using XBMC so it's fairly confusing to me at this point.
post #2900 of 2944
I think they are in bluecop's repository. Just google bluecop repository.
post #2901 of 2944
I am running XBMC on a Dell Latitude 10 tablet, which runs on Windows 8 pro, with its Atom Z2760 & Intel Graphics Media Accelerator (533Mhz). Is there any option we can do to its video decoder to fully use the Intel Graphic card to enable smooth video display ?
I am able to configure MPC-HC to use microsoft DTV-DVD video decoder for smooth handling of MKV full HD video files. But not in XBMC, even if I use DXVA rendering method along with enabling Sync Playback to Display. The video still experiencing minor stuttering.
Is there anyway to improve that ?
post #2902 of 2944
Internally there is no way to modify your splitter or decoder choices for XBMC
There is an unofficial build called DSPlayer that allows you to modify your splitter and decoders, and it is supposed to keep your OSD intact. You have to edit your xmls quite a bit to accommodate your library to your liking
If the OSD isn't of utmost importance to you, it's also fairly easy to send all video to MPC-HC as the primary player. You'll need to add an xml file to your userdata folder ( C:\users\YourUsername\AppData\Roaming\XBMC\userdata ). Open a notepad file and copy the code below, and then save it to that directory as playercorefactory.xml
Code:
<playercorefactory>
 <players>
   <player name="MPC-HC" type="ExternalPlayer" audio="false" video="true">
     <filename>C:\Program Files\mpc-hc\mpc-hc64.exe</filename>
     <args>"{1}" /fullscreen /close</args>
     <hidexbmc>false</hidexbmc>
     <hideconsole>false</hideconsole>
     <warpcursor>none</warpcursor>
   </player>
 </players>
 <rules action="prepend">
   <rule video="true" player="MPC-HC"/>
 </rules>
</playercorefactory>
Change the filename path if you are using mpc-hc 32 bit instead of 64
post #2903 of 2944
Thanks a million for the suggestion.
post #2904 of 2944
I am setting up a new machine its fresh install of windows 7 with XBMC.
I converted all my dvd to mp4 through handbrake high profile preset and I have about 10-20 files that will not play. They Play fine in vlc and they also play fine on my appletv2 with xbmc.
The log give me this error ERROR: CDVDDemuxFFmpeg::Open
I am running the latest release of XBMC frodo.
Machine specs if even needed are a old xeon 4 core 1.8ghz and a Geforce gt430 4 gigs of ram. I had this machine lying around and thought just to convert it to a HTPC
Any help would be much appreciated.
thanks.
post #2905 of 2944
Just an FYI for those having problems with Frodo -- read this thread: http://forum.xbmc.org/showthread.php?tid=146911
I did an upgrade, and then a reformat and clean install about a week ago on a Win 7 Pro 32 bit installation. Had all kinds of problems with crashes, jerky video, music files not playing, etc etc... I followed this audio troubleshooting guide and everything is golden now. Give it a try!
post #2906 of 2944
Thank you.
post #2907 of 2944
Ok..so I have just installed an Nvidea gt640 in my Gateway LX6810 - Q 8200 based HTPC. My hope was to be able to bitstream DTSMA and TrueHD but instead I have horribly unwatchable stuttery video on my 1080p files with DTSMA and nothing is passing through. I have been researching online and come to find that I may need the Intel® Management Engine Interface which I don't have and can't seem to get from the Gateway site. The original post says I have to have an i3 to bitstream I believe. I have no more time to research at this point so I'm hoping if someone can just tell me...Am I not able to do this with the hardware that I have? Everything worked fine with Eden and my 9800gt so if I can't bitstream with the PC I have then please tell me and put me out of my misery. I'll go back to what worked before.
THanks!
post #2908 of 2944
THanks!
As far as I know the gt640 should be able to bitstream hd audio, so provided you have connected the hdmi port of your gt640 to your av amp and have downloaded and installed the nvidia drivers from nvidia (not Microsoft update) and selected the nvidia sound device as the default sound device in windows mixer and in xbmc then you should be good to go. Just make sure you only mark the sound formats that your amp can decode in xbmc.
post #2909 of 2944
Be sure to select the WASAPI device in the audio setup if you want to bitstream. That will make the stuttering disappear.
post #2910 of 2944
Dupe.
Edited by nathanddrews - 3/3/13 at 2:10pm
