Originally Posted by aequalszero
Better to set the display (I'm assuming it's a TV) to match the refresh rate of the video. I looked into it and there was a method through advancedsettings.xml using the setting - but according to the XBMC wiki, this function does not work in Dharma releases.
You could always try turning 'Adjust display refresh rate to match video' back on, while leaving 'Sync playback to display' off. Or find out what frame rate the problem videos are encoded at by right clicking each file in Windows Explorer and going to Properties > Details.
They're different. The first asks you to simply remove the TV directory, clean the library, then re-add the TV directory (Nb. Cleaning the library will not delete it - it simply removes old data, links to files that no longer exist etc. and hopefully wiping out any previous reference to your removed TV files).
The second attempts to fool XBMC into re-scanning your TV shows by changing the path they are stored in. If your folder name already is "TV", then why not rename it "TV Shows"? (for example: 'C:\\Media\\TV\\' becomes 'C:\\Media\\TV Shows').
I fixed it! Except for the original problem where 5 tv series wouldn't show up. It shows the title and thumbnail but says there ate mi seasons or episodes. It turned out to be somthing simple. When you edit or add a source and click ok it brings you to a screen that says "set content" and its always been grayed out and said "no content found" or somthing Like that. I always thought I couldn't do anything with that, but it gives you the options of movies or tv and I changed it to tv series. Then I went back to the video home screen and right clicked on tv and "searched for content" and it worked. I had to go back thru settings and readjust some things that I had tweeked also. I know how to at least get back to where I started so I'm going to go thru and clean/remove/import again, see if any or all of those do the trick.
And a gull is a bird - think you meant gall.
- but your right I'll butt out and say nothing further.
