Originally Posted by
JonStatt
I will fix the linearity. This was a rough and ready first pass.
I aborted the colour calibration because I just wasn't getting anywhere. I could see luminance adjustments quite easily but I didn't need to change them much as you can see from my original starting point. But I just couldn't get anywhere with hue and saturation at all. So I'm afraid nothing to post. What do you think of the "out of the box" numbers? The greyscale isn't wonderful but I think fairly typical. I have never seen such good luminance figures out of the box though but shame about the red saturation and yellow hue. However I want to test it again as I was using the Duo's built-in test patterns. And I want to check again with the AVS patterns although they should be the same.
I don't really pay much attention to any of the out of the box numbers. To me its irrelevant because no matter how bad or good they are I'm going to dial them in where I want them. For those who don't plan to calibrate, or who won't calibrate until x hours then OOTB results are more important.
For me all that really matters is that a display is capable of being dialed in. We know that's the case with the grayscale. We know that's the case with the RS20 CMS. And we've heard mixed things about the RS50 - both from the same person (umr stating one was shaky, the other was great) and now we have a report from you that the hue and saturation controls do not seem to be working. I assume that's the case with all colors, or did you try one color in particular and then give up (and if so, trythe others). Very odd. Let us know what you find when you are able to test more.
