AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung Panel Version Thread
post #1 of 124
After reading about all this panel version nonsense and possible misinformation, maybe it is time for a thread where owners can post evidence of what they find.
The following information should be collected below.
1) Version sticker on the back can read as follows:
Version "A" panels: AC01, AC02, AC03, AC04, AA01, AA02, AA03, AA04 and BA01 all come from AU Optronics.
Version "S" panels: SQ01, SQ02, SQ03, SQ04, SS01, SS02, SS03, SS04 and SX03 are made by Samsung.
Version "C" panels: CN01, CN02, BN01 and BN02 stand for CMO.
Version "H" panels: H305, H306, H308, unclear what these are, but so far they seem to be made by Samsung (data pending).
2) Enter the Service Menu to find your "Type", which should match up with what is here (be careful, just look, don't do anything else):
55A1UF0E
A — panel manufacturer (A = Samsung; D = CMO; L = AUO; I = CPT)
1 — frequency (6 = 50/60 Hz; 1 = 100/120 Hz; 2 = 200/240 Hz)
U — panel (A = AntiGlare; T = TN; U = Ultra Clear)
F — resolution (F = Full HD; H = HD; U = UD)
0 — 1st, 2nd panel and so on (1st = 0; 2nd = 1 ...)
C — backlight unit (C = CCFL; L = LED; E = Edge LED)
Post in the following format:
Version No: H306
MFD: September 2010
Type: 55A1UF0E
post #2 of 124
And what is the difference in those model?
post #3 of 124
For my UN55C6300SFXZA, per the info on the outside right rear sticker & on the outside end-flap of the box, mine carries a "CN01" panel. Once it was registered it showed it had a mfg. date of 2/28/10.
Per the SM, mine says;
55A1UF0E.
Notice the conflict?
Ken
post #4 of 124
55A1UF0E.
Ken
So as per the service menu, you have a Samsung panel, or so this is what Samsung wants you to believe.
post #5 of 124
I cannot answer that question accurately. As I said in my last post on the other thread, they may or may not be trying to be deceitful. The matrix code does say that that the 3rd character is supposed to be the panel vendor. What do they mean by vendor? Samsung supposedly does design all the panels that go into their units. But we also know they do farm out panels for assembly, etc. This part I will try & get an answer from my Samsung contact & let you know. But again, I am hoping that more & more people will post here with their SM info so we can see just how many show an "A" as the 3rd character. (My bet is that most all will show an "A" here). I'm glad you started this thread. This can help clear a lot of this up.
Ken
post #6 of 124
I have a LN46A850 with an SQ panel beautiful picture. So much so that I pit up with a little light bleed from the corners.
post #7 of 124
Please read the OP's purpose for starting this thread. Look at his 1st post. What he describes & comments relating to that only is the only info he's looking for here.
For "jnpr": I just wanted to clarify for him & others why you started this thread. If not, it will get totally out-of-hand & you'll never get the info you actually started this thread for. Hope you don't mind.
Ken
post #8 of 124
@jnpr
Glad you started this thread. The URL below is from an older thread discussing this issue and lists the different ways of determining the manufacturer of the inside panel. I've never been impressed with Samsungs documentation which is often filled with errors or has numerous omissions, so if their quality control is as bad with their HDTVs then the only sure way of knowing whats inside would be to actually see the sticker on the panel itself.
How to determine whats inside:
1. Sticker info
2. Panel Codename in Service Menu
3. Pixel Photo
4. Most exact evidence - sticker on panel inside TV (Disassembling required in most cases)
Samsung S, A, C Panel Differences: 2009 LCD Line-Up
post #9 of 124
The intent of starting this thread was to share information and knowledge of this ongoing debate on panel versions. Since buying my UN55C6300SFXZA I have been plagued with the idea that I may possibly have an inferior set due to all this talk of non-Samsung panels. This has made me question problems or issues that I think I may be seeing with my set, which is not really fun. The bottom line which was previously stated by Ken is that if you are happy with what you have, do you really care if you have a different panel version? Sure you can debate the differences between AU, CMO, Samsung panels, but in the end if you are happy with what you see, who cares.
So if possible, follow the guidelines of my 1st post in providing the information so we can all get an idea actual differences, if any exist.
post #10 of 124
I'm bumping this up because I want to see folks participating here, particularly those who were agressively disagreeing in the other thread. I truly want to see several results, so we know for sure what's going on..
Ken
post #11 of 124
LN46C600 - outside sticker says SQ01, I will get to the SM to see what it says.
Q: How to enter SM?
A: {DISPLAY} {P.STD} {MUTE} {POWER} on the remote while TV is in standby
- is it still valid?
post #12 of 124
Q: How to enter SM?
MUTE-1-8-2-POWER
Use caution, don't hit any other buttons, just check where it says "Type"
post #13 of 124
I believe Samsung started using different panels in their TVs back in 2006/07 and wouldnt admit they were doing so until several years later.
Regarding hearrean's comment (My bet is that most all will show an "A" here) I suspect its a move by Samsung to prevent panel identity and All "service menu types" will show Samsung in the future, regardless of who manufactured the panel.
Its also possible that Hxxx will be the only identifier used. Interesting to see what will happen in the next few months and in the following year.
post #14 of 124
MUTE-1-8-2-POWER
Thank you.
Type: 46A1AF0C
UPC outside the box SQ01
Manufacture date 2010-09-15
So, it is a Sammy panel.
post #15 of 124
I believe I've said both of those things from the start, but noone chose to believe me. His starting of this thread should settle this issue once & for all.
Ken
post #16 of 124
The Samsung S, A, C Panel Lottery thread is very helpful. I don't see why we can't post it all on there?
post #17 of 124
Thank you.
Type: 46A1AF0C
Wrong!!!
Ken
Well Ken, I believe it is a Samsung panel.
Why do you think its not?
post #18 of 124
Doesn't matter to me, but I'm afraid the data the OP is looking for will just get lost in that huge thread. He started this thread because there is a growing number of folks over on the 6300, 6400 & 6500 thread who are starting to believe that this decoding technique found in the SM tells you the true panel (or panel maker) of your unit, even though you may have a sticker on the outside rear that says something else. And my point is that it doesn't. But that will be up to "jnpr" if he chooses to move this thread.
Ken
post #19 of 124
You're absolutely correct! I had an absolute brain-fart! It does show to be in agreement with his sticker and be a "S" panel, which is Samsung. Again, my apologies.
Let's see how many more we get that hold true. So far, there is shown to be (1) that agrees & (2) that don't match including mine (one was in the other thread). He needs to post that over here.
Ken
post #20 of 124
Thank you.
Type: 46A1AF0C
Yes, you are correct!
Ken
post #21 of 124
You're absolutely correct! I had an absolute brain-fart!Ken
I hope those are infrequent. I find as I get older, they happen more often
If as we suspect, the 3rd character of all/most menu types will show a Samsung panel, then all TVs labeled with a Samsung version sticker will agree.
I think the service menu type was a reliable method to determine the panel in the past, however it now seems that it may no longer be so. If all types now read Samsung, it would be interesting to find out when it started as I believe its very recent happening, possibly early this year.
post #22 of 124
When I go into the service menu this is what I have:
Version: C600
MFD: 8-30-2010
Type: 46L1AF0C
Panel: AA02
Breakdown:
L - AUO panel
1 - 100/120 HZ
A - Antiglare
F - Full HD
0 - 1st Panel (what does this mean?)
C - CCFL
post #23 of 124
Mine is a 46C650 SQ01 March build
menu type 46A1UF0C
Here are a few that I dug out of a French forum. There were probably 10 Samsungs and all matched the menu type.
There were a few with xxPxxxxx that nobody could identify but seeing that they had BN and CN stickers, I imagine the P identifies them as CMO panels.
CMO has at least one plant in Europe so my best guess is "P' is a European CMO panel and "D" is Asian.
There was also one with a BN sticker but a Samsung menu type - I believe their response to this one is the outer label isnt always 100%
UE40C6000RWXZG
Version No: CN01
Internal menu type : 40D1UF0E
Model: UE40C6000RWXZF
So a CMO panel
Model: 46B650
Version : CN02
Type : 46D1UF0C
Model Code: UE40C6000RWXZG
version no : CN01
32UEB6000VWXXC
Version: CN01
32P1UF0E 32P1UF0E
CMO panel
AA panel
post #24 of 124
Don't believe anyone has figured it out. At first I assumed the 0 = first panel would mean the first panel in that particular version, ie AA01, but I later discovered that wasnt it.
I cant recall how many of those menu types that I saw but only one had a 1 in that position.
post #25 of 124
I may not be understanding what you're saying, but that is just the opposite of what I have been saying. I've been saying that per this matrix code that so many now seem to be relying on, my contention is that in the SM, most 3rd characters will say "A" but could have an outside sticker that says something else like mine which has a sticker that says version "CN01", but in the SM, the 3rd character shows an A. We know that "C" panels are made by Chei Mei Electronics, not Samsung. And we've already found (2) others with the same conflict.
Ken
post #26 of 124
Version: C600
MFD: 8-30-2010
Type: 46L1AF0C
Panel: AA02
Breakdown:
L - AUO panel
1 - 100/120 HZ
A - Antiglare
F - Full HD
C - CCFL
This one agrees, 3rd character shows a "L" and his panel version sticker shows a "A."
I may end up being wrong about most 3rd characters showing as "A."
Ken
post #27 of 124
Ken
Maybe you have a Samsung panel after all.
Even from my findings on a display model in a local store, the sticker on the rear of the set clearly said "CN01", but the SM said "A", which stands for Samsung. It is funny that your example, and the example I found in the store match perfectly. The only thing in common between these is they are newer sets, and are C6300 series. The debate continues....
I also know that nobody has been able to determine 100% what these "H" versions stand for, though the SM clearly states "A", which again is for Samsung. Maybe someone has enough guts to take one of these "H" versions apart to get the real answer, if that will even prove anything.
post #28 of 124
As I said earlier the service menu type was a reliable way to determine the panels inside and now that I've looked at this closer I believe it still is.
So far as you say it appears to be with the c6300 units and if Im not mistaken they are all 55".
Its too soon to tell but Im suspecting a glitch when the service menu entry is entered/embedded during assembly.
H3xx panels have been installed in some of the smaller models, so Im hoping the menu types on those are correct and you may eventually find out who manufactures H3xx panels.
Another way to check a panel is to take a photo of the panels pixel structure, according to those in the know a panel can be identified this way.
EDIT
H3xx may very well identify Samsung panels.
HQ01 - matrix S-PVA from Samsung
HQxx is a Samsung identifier and I believe there was another
H?xx Samsung panel
post #29 of 124
Model: LN40C610 (AA03 on box)
Type: 40L1AF0C (adheres to the logic here that its an AUO panel)
I had read somewhere else that someone thought AA03 was still made by Samsung, but its hard to distill the accurate information.
post #30 of 124
EDIT
H?xx Samsung panel
I guess we just have to sit and wait for more data to become available on these "H3*" panels. If Ken wants to jump in, he may know something more.
Interestingly enough I went to a local BB today to take some panel version inventory and noticed that 9 series sets had "HQ" panel versions, which would go along with what you were mentioning.
