Originally Posted by Andy238
Thanks for that info, Moggie. It helps a lot!
So if I go with a one motor, IR controlled solution, do I still need the RS485 4ILT Interface? Or can I just connect the #9154205 IR receiver to the motor? Or do I just need the #1870127 ILT Tap? I can't seem to find a clear concise IR integration diagram. I did find the RS485 4ILT Interface at somfymotorstore.com but it was like over $450?! Is it really that expensive?
Andy
Andy
You don't need the 4ILT RS485 interface with one motor. If you want to control via RS485 (or RS232) you will need the Tap #1870127 and a RS485/usb converter for your laptop (I found one for about $35). I don't think you can directly connect the IR to the motor (although I'm guessing here) because it needs power that would normally come from the Tap or the 4ILT controller... worth talking to Somfy directly though.
Remember that if you can make do with two end limits and one intermediate stop, then you can build a much cheaper system with the non ILT motors. You will not get the encoder accuracy but you would save a bundle.
Originally Posted by mbaysing
Is there an LT30 ILT motor? The closest thing I know of the is the Sonesse ST30 RS485. The LT30 is noisier than the Sonesse line, and it only comes in RF and IR varieties, as far as I'm aware. (But I'm just recently started learning about this stuff, so I could be wrong.)
The nice thing about the ST30 RS485 is you don't need buy an extra box (like the 4ILT) to connect it to and RS485 network. I'm not sure what you'd need to control it by IR, though. There are also RF and DCT versions of the ST30.
You are correct, I meant the Sonesse ST30 RS485.
I'm sure there is a way to control via IR but what I see Somfy advertising is an RS485 to z-wave module. Welcome to the world of Somfy where even the dealers don't understand the product line
