Hi audio gurus!
I want to update my center channel speaker and stuck between a couple of them:
Polk Audio CS20 - http://www.newegg.com/Product/Produc...-107-_-Product
Polk Audio CS2 Series II - http://www.newegg.com/Product/Produc...-212-_-Product
Klipsch RC-62 II - http://www.newegg.com/Product/Produc...-064-_-Product
Below are the main technical specs like Frequency Response & Sensitivity for all of them:
Polk CS20: 48Hz-25kHz & 91dB
Polk CS2: 50Hz-25kHz & 90db
Klipsch RC-62 II: 57Hz-24KHz & 98dB
I have YAMAHA RX-V765 7.2-Channel Digital Home Theater Receiver - http://www.newegg.com/Product/Produc...82E16882115197
What is the best center channel from these 3 speakers? Is 98dB sensitivity of Klipsch really important? Klipsch is also 3-4 times more expensive then Polk. Is the price dirrefence really audible?
Or you can advise me another center channel speaker up to $500?
Thanks a lot in advance.
