AVS › AVS Forum › Audio › Audio theory, Setup and Chat › In need of short power cables
post #1 of 21
I am considering running a less than ideal setup with my rack. Long story but to keep things clean looking I need shorter power cables.
I need some no longer than 3 feet. As short as a .5-1ft would be even better. I am sick of rigging everything and prefer to not cut an solder.
Is there anywhere to get affordable short power cables?
post #2 of 21
post #3 of 21
post #4 of 21
post #5 of 21
If you are asking about the typicle IEC cables,
http://www.parts-express.com/pe/show...number=119-020
post #6 of 21
post #7 of 21
Even monoprice has them...
post #8 of 21
Are these super cheap cables decent?
post #9 of 21
Why are these so much?
post #10 of 21
They aren't super cheap. Monoprice is about a third the price. Quality is probably the same as what you are replacing. Decent power cables are not expensive.
Actually, monoprice might be better. Theirs are 14 AWG. Most are 18 AWG.
post #11 of 21
Because they are color coded? Because there are four of them for the price? Doesn't seem to be anything special otherwise. Because people will pay that price?
post #12 of 21
I need the kind for a blu ray player, cable box ect.
post #13 of 21
Would that be the kind with the large D shaped IEC connector (like on a computer)? If so, should be no problem at all. If its the kind with the skinny figure 8 shaped IEC connector, might be more of a problem.
Even though you are tired of cutting and soldering, cutting your existing cable might be simplest. No need to solder. Just use a plug from your local home improvement store. The terminals screw down (preferable) or are insulation displacement.
post #14 of 21
Figure 8 types...
This is making me think I just sell my power conditioner and then I wont need shorter cables (no use explaining my whole odd setup but long story short the output devices will be stacked on top of the conditioner). I got it so cheap and never got to use it yet so selling it won't be a problem and I wont miss it since i never used it
post #15 of 21
Probably don't need the power conditioner anyway...
post #16 of 21
ha I see what side of the power debate you fall on...
I origonally bought it for a rack mount setup but the expense of doing that doesn't make sense for me.
I have the apc h15 - For what I got it for it was a steal and I could sell without losing much
post #17 of 21
Yep, I believe that the engineers that designed the power supplies of our AV equipment knew what they were doing in the first place and that most of us don't need power conditioning. Sure, there are exceptions, mostly in 3rd world countries IMHO. The power sequencing capabilities of some units can be useful, and it gives up a bunch of receptacles without having to rewire your house. And the gear looks neat. Sure can't hurt anything. If you like it, more power to you.
post #18 of 21
I never used it so dont know if I like it.
I do fear the talk about them compressing dynamics or limiting them (whatever you want to call it.)
It was only 140-150 so it was a steal and I bought with little research
post #19 of 21
this is what i did for many of my power cables... hacked them down to the desired length, and stuck a screw down plug on the end...
works for me...
post #20 of 21
Figure 8 types...
http://www.amazon.com/Notebook-Power...1565838&sr=8-3
Here's another:
http://cableorganizer.com/outlet/EFL...y?=recommended
post #21 of 21
BTW be aware that these come in polarized and non-polarized versions. One end of the figure 8 is square in the polarized versions. You want to use the correct type.
