It's very long, i would say no less than 10 feet, right now i have it bundled underneath the mount bracket but i will pull the cable out when i get home and measure it for you.
oh you betchurazz i am a gamer !
) and found that the same brightness setting was needed for both my 100" (diagonal) 16:9 content and for my 2.35:1 setting (which was effectively 133" diagonal) which is a slightly bigger range than your 70-92" swop. I'm always trying to make sure I get the best out of my projector, so I wouldn't raise the black level unneccesarily, even by one click (it's quite a noticable difference on the HD350 at least) unless it was necessary to see all the flashing bars down to 17IRE on the AVS HD709 disc.
